generators.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Siargey Kachanovich
4 *
5 * Copyright (C) 2015 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef GENERATORS_H_
12#define GENERATORS_H_
13
14#include <CGAL/Epick_d.h>
15#include <CGAL/point_generators_d.h>
16#include <CGAL/Random.h>
17
18#include <fstream>
19#include <string>
20#include <vector>
21#include <cmath>
22
23using K = CGAL::Epick_d<CGAL::Dynamic_dimension_tag>;
24using FT = K::FT;
25using Point_d = K::Point_d;
26using Point_Vector = std::vector<Point_d>;
27using Random_cube_iterator = CGAL::Random_points_in_cube_d<Point_d>;
28using Random_point_iterator = CGAL::Random_points_in_ball_d<Point_d>;
29
34inline void
35off_reader_cust(std::string file_name, std::vector<Point_d> & points) {
36 std::ifstream in_file(file_name.c_str(), std::ios::in);
37 if (!in_file.is_open()) {
38 std::cerr << "Unable to open file " << file_name << std::endl;
39 return;
40 }
41 std::string line;
42 double x;
43 // Line OFF. No need in it
44 if (!getline(in_file, line)) {
45 std::cerr << "No line OFF\n";
46 return;
47 }
48 // Line with 3 numbers. No need
49 if (!getline(in_file, line)) {
50 std::cerr << "No line with 3 numbers\n";
51 return;
52 }
53 // Reading points
54 while (getline(in_file, line)) {
55 std::vector< double > point;
56 std::istringstream iss(line);
57 while (iss >> x) {
58 point.push_back(x);
59 }
60 points.push_back(Point_d(point));
61 }
62 in_file.close();
63}
64
70inline void
71read_points_cust(std::string file_name, Point_Vector & points) {
72 std::ifstream in_file(file_name.c_str(), std::ios::in);
73 if (!in_file.is_open()) {
74 std::cerr << "Unable to open file " << file_name << std::endl;
75 return;
76 }
77 std::string line;
78 double x;
79 while (getline(in_file, line)) {
80 std::vector< double > point;
81 std::istringstream iss(line);
82 while (iss >> x) {
83 point.push_back(x);
84 }
85 Point_d p(point.begin(), point.end());
86 if (point.size() != 1)
87 points.push_back(p);
88 }
89 in_file.close();
90}
91
99void generate_points_grid(Point_Vector& W, int width, int D, bool torus) {
100 int nb_points = 1;
101 for (int i = 0; i < D; ++i)
102 nb_points *= width;
103 for (int i = 0; i < nb_points; ++i) {
104 std::vector<double> point;
105 int cell_i = i;
106 for (int l = 0; l < D; ++l) {
107 if (torus)
108 point.push_back(-1 + (2.0 / (width - 1))*(cell_i % width));
109 else
110 point.push_back(-1 + (2.0 / width)*(cell_i % width));
111 // attention: the bottom and the right are covered too!
112 cell_i /= width;
113 }
114 W.push_back(point);
115 }
116}
117
121void generate_points_random_box(Point_Vector& W, int nbP, int dim) {
122 Random_cube_iterator rp(dim, 1.0);
123 for (int i = 0; i < nbP; i++) {
124 W.push_back(*rp++);
125 }
126}
127
131void generate_points_sphere(Point_Vector& W, int nbP, int dim) {
132 CGAL::Random_points_on_sphere_d<Point_d> rp(dim, 1);
133 for (int i = 0; i < nbP; i++)
134 W.push_back(*rp++);
135}
136
140void generate_points_torus(Point_Vector& W, int nbP, int dim) {
141 CGAL::Random rand;
142 const double pi = std::acos(-1);
143 for (int i = 0; i < nbP; i++) {
144 std::vector<FT> point;
145 for (int j = 0; j < dim; j++) {
146 double alpha = rand.uniform_real(static_cast<double>(0), 2*pi);
147 point.push_back(sin(alpha));
148 point.push_back(cos(alpha));
149 }
150 W.push_back(Point_d(point));
151 }
152}
153
154#endif // GENERATORS_H_
