face_from_indices.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Siargey Kachanovich
4 *
5 * Copyright (C) 2019 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef PERMUTAHEDRAL_REPRESENTATION_FACE_FROM_INDICES_H_
12#define PERMUTAHEDRAL_REPRESENTATION_FACE_FROM_INDICES_H_
13
14#include <cstdlib> // for std::size_t
15#include <algorithm>
16
17namespace Gudhi {
18
19namespace coxeter_triangulation {
20
31template <class Permutahedral_representation, class Index_range>
32Permutahedral_representation face_from_indices(const Permutahedral_representation& simplex,
33 const Index_range& indices) {
34 using range_index = typename Index_range::value_type;
35 using Ordered_set_partition = typename Permutahedral_representation::OrderedSetPartition;
36 using Part = typename Ordered_set_partition::value_type;
37 using part_index = typename Part::value_type;
38 Permutahedral_representation value;
39 std::size_t d = simplex.vertex().size();
40 value.vertex() = simplex.vertex();
41 std::size_t k = indices.size() - 1;
42 value.partition().resize(k + 1);
43 std::size_t l = simplex.partition().size() - 1;
44 for (std::size_t h = 1; h < k + 1; h++)
45 for (range_index i = indices[h - 1]; i < indices[h]; i++)
46 for (part_index j : simplex.partition()[i]) value.partition()[h - 1].push_back(j);
47 for (range_index i = indices[k]; i < l + 1; i++)
48 for (part_index j : simplex.partition()[i]) value.partition()[k].push_back(j);
49 for (range_index i = 0; i < indices[0]; i++)
50 for (part_index j : simplex.partition()[i]) {
51 if (j != d)
52 value.vertex()[j]++;
53 else
54 for (std::size_t l = 0; l < d; l++) value.vertex()[l]--;
55 value.partition()[k].push_back(j);
56 }
57 // sort the values in each part (probably not needed)
58 for (auto& part : value.partition()) std::sort(part.begin(), part.end());
59 return value;
60}
61
62} // namespace coxeter_triangulation
63
64} // namespace Gudhi
65
66#endif
Ordered_set_partition_ OrderedSetPartition
Type of the ordered partition.
Definition: Permutahedral_representation.h:46
