All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
custom_persistence_sort.cpp
/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
* See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
* Author(s): Vincent Rouvreau
* Copyright (C) 2014 Inria
* Modification(s):
* - YYYY/MM Author: Description of the modification
#include <CGAL/Epick_d.h>
#include <CGAL/point_generators_d.h>
#include <CGAL/algorithm.h>
#include <CGAL/assertions.h>
#include <gudhi/Alpha_complex.h>
#include <gudhi/Persistent_cohomology.h>
// to construct a simplex_tree from alpha complex
#include <gudhi/Simplex_tree.h>
#include <iostream>
#include <iterator>
#include <vector>
#include <fstream> // for std::ofstream
#include <algorithm> // for std::sort
using Kernel = CGAL::Epick_d< CGAL::Dimension_tag<3> >;
using Point = Kernel::Point_d;
std::vector<Point> random_points() {
// Instantiate a random point generator
CGAL::Random rng(0);
// Generate "points_number" random points in a vector
std::vector<Point> points;
// Generates 1000 random 3D points on a sphere of radius 4.0
CGAL::Random_points_on_sphere_d<Point> rand_outside(3, 4.0, rng);
CGAL::cpp11::copy_n(rand_outside, 1000, std::back_inserter(points));
// Generates 2000 random 3D points in a sphere of radius 3.0
CGAL::Random_points_in_ball_d<Point> rand_inside(3, 3.0, rng);
CGAL::cpp11::copy_n(rand_inside, 2000, std::back_inserter(points));
return points;
* Compare two intervals by dimension, then by length.
struct cmp_intervals_by_dim_then_length {
explicit cmp_intervals_by_dim_then_length(Simplex_tree * sc)
: sc_(sc) { }
template<typename Persistent_interval>
bool operator()(const Persistent_interval & p1, const Persistent_interval & p2) {
if (sc_->dimension(get < 0 > (p1)) == sc_->dimension(get < 0 > (p2)))
return (sc_->filtration(get < 1 > (p1)) - sc_->filtration(get < 0 > (p1))
> sc_->filtration(get < 1 > (p2)) - sc_->filtration(get < 0 > (p2)));
else
return (sc_->dimension(get < 0 > (p1)) > sc_->dimension(get < 0 > (p2)));
int main(int argc, char **argv) {
std::vector<Point> points = random_points();
std::clog << "Points size=" << points.size() << std::endl;
// Alpha complex persistence computation from generated points
Alpha_complex alpha_complex_from_points(points);
std::clog << "alpha_complex_from_points" << std::endl;
Simplex_tree simplex;
std::clog << "simplex" << std::endl;
if (alpha_complex_from_points.create_complex(simplex, 0.6)) {
// Display information about the alpha complex
std::clog << "Simplicial complex is of dimension " << simplex.dimension() <<
" - " << simplex.num_simplices() << " simplices - " <<
simplex.num_vertices() << " vertices." << std::endl;
std::clog << "Simplex_tree dim: " << simplex.dimension() << std::endl;
Persistent_cohomology pcoh(simplex);
// initializes the coefficient field for homology - Z/3Z
pcoh.init_coefficients(3);
pcoh.compute_persistent_cohomology(0.2);
// Custom sort and output persistence
cmp_intervals_by_dim_then_length cmp(&simplex);
auto persistent_pairs = pcoh.get_persistent_pairs();
std::sort(std::begin(persistent_pairs), std::end(persistent_pairs), cmp);
for (auto pair : persistent_pairs) {
std::clog << simplex.dimension(get<0>(pair)) << " "
<< simplex.filtration(get<0>(pair)) << " "
<< simplex.filtration(get<1>(pair)) << std::endl;
// Persistent Betti numbers
std::clog << "The persistent Betti numbers in interval [0.40, 0.41] are : ";
for (int dim = 0; dim < simplex.dimension(); dim++)
std::clog << "b" << dim << " = " << pcoh.persistent_betti_number(dim, 0.40, 0.41) << " ; ";
std::clog << std::endl;
// Betti numbers
std::vector<int> betti_numbers = pcoh.betti_numbers();
std::clog << "The Betti numbers are : ";
for (std::size_t i = 0; i < betti_numbers.size(); i++)
std::clog << "b" << i << " = " << betti_numbers[i] << " ; ";
return 0;
static Filtration_value filtration(Simplex_handle sh)
Returns the filtration value of a simplex.
Definition: Simplex_tree.h:535
size_t num_vertices() const
Returns the number of vertices in the complex.
Definition: Simplex_tree.h:572
int dimension(Simplex_handle sh)
Returns the dimension of a simplex.
Definition: Simplex_tree.h:600
size_t num_simplices()
returns the number of simplices in the simplex_tree.
Definition: Simplex_tree.h:578
Alpha complex data structure.
Definition: Alpha_complex.h:103
Structure representing the coefficient field .
Definition: Field_Zp.h:27
Computes the persistent cohomology of a filtered complex.
Definition: Persistent_cohomology.h:52
