build_mesh_from_cell_complex.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Siargey Kachanovich
4 *
5 * Copyright (C) 2019 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef IO_BUILD_MESH_FROM_CELL_COMPLEX_H_
12#define IO_BUILD_MESH_FROM_CELL_COMPLEX_H_
13
14#include <gudhi/IO/output_debug_traces_to_html.h> // for DEBUG_TRACES
15#include <gudhi/IO/Mesh_medit.h>
16
17#include <Eigen/Dense>
18
19#include <cstdlib> // for std::size_t
20#include <map>
21#include <set>
22#include <string>
23#include <utility> // for std::make_pair
24#include <algorithm> // for std::min
25
26namespace Gudhi {
27
28namespace coxeter_triangulation {
29
30struct Configuration {
31 Configuration(bool t_edges, bool t_triangles, bool t_tetrahedra, std::size_t r_edges, std::size_t r_triangles,
32 std::size_t r_tetrahedra)
33 : toggle_edges(t_edges),
34 toggle_triangles(t_triangles),
35 toggle_tetrahedra(t_tetrahedra),
36 ref_edges(r_edges),
37 ref_triangles(r_triangles),
38 ref_tetrahedra(r_tetrahedra) {}
39
40 Configuration() {}
41
42 bool toggle_edges = true, toggle_triangles = true, toggle_tetrahedra = true;
43 std::size_t ref_edges = 1, ref_triangles = 1, ref_tetrahedra = 1;
44};
45
46template <class Hasse_cell, class Simplex_cell_map>
47void populate_mesh(Mesh_medit& output, Simplex_cell_map& sc_map, Configuration configuration, std::size_t amb_d,
48 std::map<Hasse_cell*, std::size_t> vi_map) {
49 using Mesh_element_vertices = Mesh_medit::Mesh_elements::value_type::first_type;
50 std::map<Hasse_cell*, std::size_t> ci_map;
51 std::size_t index = vi_map.size() + 1; // current size of output.vertex_points
52 if (sc_map.size() >= 3)
53 for (const auto& sc_pair : sc_map[2]) {
54 Eigen::VectorXd barycenter = Eigen::VectorXd::Zero(amb_d);
55 std::set<std::size_t> vertex_indices;
56 Hasse_cell* cell = sc_pair.second;
57 for (const auto& ei_pair : cell->get_boundary())
58 for (const auto& vi_pair : ei_pair.first->get_boundary()) vertex_indices.emplace(vi_map[vi_pair.first]);
59 for (const std::size_t& v : vertex_indices) barycenter += output.vertex_points[v - 1];
60 ci_map.emplace(cell, index++);
61 output.vertex_points.emplace_back((1. / vertex_indices.size()) * barycenter);
62#ifdef DEBUG_TRACES
63 std::string vlist = " (" + std::to_string(index - 1) + ")";
64 for (const std::size_t& v : vertex_indices) vlist += " " + std::to_string(v);
65 cell_vlist_map.emplace(to_string(cell), vlist);
66#endif
67 }
68
69 if (configuration.toggle_edges && sc_map.size() >= 2)
70 for (const auto& sc_pair : sc_map[1]) {
71 Hasse_cell* edge_cell = sc_pair.second;
72 Mesh_element_vertices edge;
73 for (const auto& vi_pair : edge_cell->get_boundary()) edge.push_back(vi_map[vi_pair.first]);
74 output.edges.emplace_back(edge, configuration.ref_edges);
75#ifdef DEBUG_TRACES
76 std::string vlist;
77 for (const std::size_t& v : edge) vlist += " " + std::to_string(v);
78 cell_vlist_map.emplace(to_string(edge_cell), vlist);
79#endif
80 }
81
82 if (configuration.toggle_triangles && sc_map.size() >= 3)
83 for (const auto& sc_pair : sc_map[2]) {
84 for (const auto& ei_pair : sc_pair.second->get_boundary()) {
85 Mesh_element_vertices triangle(1, ci_map[sc_pair.second]);
86 for (const auto& vi_pair : ei_pair.first->get_boundary()) triangle.push_back(vi_map[vi_pair.first]);
87 output.triangles.emplace_back(triangle, configuration.ref_triangles);
88 }
89 }
90
91 if (configuration.toggle_tetrahedra && sc_map.size() >= 4)
92 for (const auto& sc_pair : sc_map[3]) {
93 Eigen::VectorXd barycenter = Eigen::VectorXd::Zero(amb_d);
94 std::set<std::size_t> vertex_indices;
95 Hasse_cell* cell = sc_pair.second;
96 for (const auto& ci_pair : cell->get_boundary())
97 for (const auto& ei_pair : ci_pair.first->get_boundary())
98 for (const auto& vi_pair : ei_pair.first->get_boundary()) vertex_indices.emplace(vi_map[vi_pair.first]);
99 for (const std::size_t& v : vertex_indices) barycenter += output.vertex_points[v - 1];
100 output.vertex_points.emplace_back((1. / vertex_indices.size()) * barycenter);
101#ifdef DEBUG_TRACES
102 std::string vlist = " (" + std::to_string(index) + ")";
103 for (const std::size_t& v : vertex_indices) vlist += " " + std::to_string(v);
104 cell_vlist_map.emplace(to_string(cell), vlist);
105#endif
106
107 for (const auto& ci_pair : cell->get_boundary())
108 for (const auto& ei_pair : ci_pair.first->get_boundary()) {
109 Mesh_element_vertices tetrahedron = {index, ci_map[sc_pair.second]};
110 for (const auto& vi_pair : ei_pair.first->get_boundary()) tetrahedron.push_back(vi_map[vi_pair.first]);
111 output.tetrahedra.emplace_back(tetrahedron, configuration.ref_tetrahedra);
112 }
113 index++;
114 }
115}
116
121template <class Cell_complex>
123 Configuration i_configuration = Configuration(),
124 Configuration b_configuration = Configuration()) {
125 using Hasse_cell = typename Cell_complex::Hasse_cell;
126 Mesh_medit output;
127 std::map<Hasse_cell*, std::size_t> vi_map; // one for vertices, other for 2d-cells
128 std::size_t index = 1; // current size of output.vertex_points
129
130 if (cell_complex.cell_point_map().empty()) return output;
131 std::size_t amb_d = std::min((int)cell_complex.cell_point_map().begin()->second.size(), 3);
132
133 for (const auto& cp_pair : cell_complex.cell_point_map()) {
134#ifdef DEBUG_TRACES
135 std::string vlist;
136 vlist += " " + std::to_string(index);
137 cell_vlist_map.emplace(to_string(cp_pair.first), vlist);
138#endif
139 vi_map.emplace(cp_pair.first, index++);
140 output.vertex_points.push_back(cp_pair.second);
141 output.vertex_points.back().conservativeResize(amb_d);
142 }
143
144 populate_mesh(output, cell_complex.interior_simplex_cell_maps(), i_configuration, amb_d, vi_map);
145#ifdef DEBUG_TRACES
146 for (const auto& sc_map : cell_complex.interior_simplex_cell_maps())
147 for (const auto& sc_pair : sc_map) {
148 std::string simplex = "I" + to_string(sc_pair.first);
149 std::string cell = to_string(sc_pair.second);
150 std::string vlist = cell_vlist_map.at(cell).substr(1);
151 simplex_vlist_map.emplace(simplex, vlist);
152 }
153#endif
154 populate_mesh(output, cell_complex.boundary_simplex_cell_maps(), b_configuration, amb_d, vi_map);
155#ifdef DEBUG_TRACES
156 for (const auto& sc_map : cell_complex.boundary_simplex_cell_maps())
157 for (const auto& sc_pair : sc_map) {
158 std::string simplex = "B" + to_string(sc_pair.first);
159 std::string cell = to_string(sc_pair.second);
160 std::string vlist = cell_vlist_map.at(cell).substr(1);
161 simplex_vlist_map.emplace(simplex, vlist);
162 }
163#endif
164 return output;
165}
166
167} // namespace coxeter_triangulation
168
169} // namespace Gudhi
170
171#endif
A class that constructs the cell complex from the output provided by the class Gudhi::coxeter_triangu...
Definition: Cell_complex.h:38
const Cell_point_map & cell_point_map() const
Returns a map from the vertex cells in the cell complex of type Gudhi::Hasse_cell to their Cartesian ...
Definition: Cell_complex.h:315
const Simplex_cell_maps & interior_simplex_cell_maps() const
Returns a vector of maps from the cells of various dimensions in the interior of the cell complex of ...
Definition: Cell_complex.h:273
const Simplex_cell_maps & boundary_simplex_cell_maps() const
Returns a vector of maps from the cells of various dimensions on the boundary of the cell complex of ...
Definition: Cell_complex.h:280
Gudhi::Hasse_diagram::Hasse_diagram_cell< int, double, bool > Hasse_cell
Type of a cell in the cell complex. Always is Gudhi::Hasse_cell from the Hasse diagram module....
Definition: Cell_complex.h:49
Mesh_medit build_mesh_from_cell_complex(const Cell_complex &cell_complex, Configuration i_configuration=Configuration(), Configuration b_configuration=Configuration())
Builds a Gudhi::coxeter_triangulation::Mesh_medit from a Gudhi::coxeter_triangulation::Cell_complex.
Definition: build_mesh_from_cell_complex.h:122
Structure to store a mesh that can be output in Medit .mesh file format using the output_meshes_to_me...
Definition: Mesh_medit.h:29
Vertex_points vertex_points
Range of vertices of type Eigen::VectorXd to output.
Definition: Mesh_medit.h:43
