allocator.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Marc Glisse
4 *
5 * Copyright (C) 2015 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef ALLOCATOR_H_
12#define ALLOCATOR_H_
13
14#include <memory>
15#include <utility>
16
17namespace Gudhi {
18
22template <class T, class Base = std::allocator<T>>
23struct no_init_allocator : Base {
24 typedef std::allocator_traits<Base> Base_traits;
25 template <class U> struct rebind {
26 typedef no_init_allocator<U, typename Base_traits::template rebind_alloc<U>> other;
27 };
28
29 // Inherit constructors.
30 using Base::Base;
31
32 // Do nothing: that's the whole point!
33 template<class P>
34 void construct(P*) noexcept {}
35
36 template<class P, class...U> void construct(P*p, U&&...u) {
37 Base_traits::construct(*(Base*)this, p, std::forward<U>(u)...);
38 }
39};
40
41} // namespace Gudhi
42
43#endif // ALLOCATOR_H_
