Trie.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): David Salinas
4 *
5 * Copyright (C) 2014 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef SKELETON_BLOCKER_INTERNAL_TRIE_H_
12#define SKELETON_BLOCKER_INTERNAL_TRIE_H_
13
14#include <memory>
15#include <vector>
16#include <deque>
17#include <set>
18
19namespace Gudhi {
20
21namespace skeleton_blocker {
22
23template<typename SimplexHandle>
24struct Trie {
25 typedef SimplexHandle Simplex;
26 typedef typename SimplexHandle::Vertex_handle Vertex_handle;
27
29 std::vector<std::shared_ptr<Trie> > childs;
30 // std::vector<std::unique_ptr<Trie> > childs; -> use of deleted function
31 private:
32 const Trie* parent_;
33
34 public:
35 Trie() : parent_(0) { }
36
37 Trie(Vertex_handle v_) : v(v_), parent_(0) { }
38
39 Trie(Vertex_handle v_, Trie* parent) : v(v_), parent_(parent) { }
40
41 bool operator==(const Trie& other) const {
42 return (v == other.v);
43 }
44
45 void add_child(Trie* child) {
46 if (child) {
47 std::shared_ptr<Trie> ptr_to_add(child);
48 childs.push_back(ptr_to_add);
49 child->parent_ = this;
50 }
51 }
52
53 typedef typename Simplex::Simplex_vertex_const_iterator Simplex_vertex_const_iterator;
54
55 Trie* make_trie(Simplex_vertex_const_iterator s_it, Simplex_vertex_const_iterator s_end) {
56 if (s_it == s_end) {
57 return 0;
58 } else {
59 Trie* res = new Trie(*s_it);
60 Trie* child = make_trie(++s_it, s_end);
61 res->add_child(child);
62 return res;
63 }
64 }
65
66 private:
67 // go down recursively in the tree while advancing the simplex iterator.
68 // when it reaches a leaf, it inserts the remaining that is not present
69 void add_simplex_helper(Simplex_vertex_const_iterator s_it, Simplex_vertex_const_iterator s_end) {
70 assert(*s_it == v);
71 ++s_it;
72 if (s_it == s_end) return;
73 if (!is_leaf()) {
74 for (auto child : childs) {
75 if (child->v == *s_it)
76 return child->add_simplex_helper(s_it, s_end);
77 }
78 // s_it is not found and needs to be inserted
79 }
80 // not leaf -> remaining of s needs to be inserted
81 Trie * son_with_what_remains_of_s(make_trie(s_it, s_end));
82 add_child(son_with_what_remains_of_s);
83 return;
84 }
85
86 void maximal_faces_helper(std::vector<Simplex>& res) const {
87 if (is_leaf()) res.push_back(simplex());
88 else
89 for (auto child : childs)
90 child->maximal_faces_helper(res);
91 }
92
93 public:
97 void add_simplex(const Simplex& s) {
98 if (s.empty()) return;
99 assert(v == s.first_vertex());
100 add_simplex_helper(s.begin(), s.end());
101 }
102
103 std::vector<Simplex> maximal_faces() const {
104 std::vector<Simplex> res;
105 maximal_faces_helper(res);
106 return res;
107 }
108
112 void add_vertices_up_to_the_root(Simplex& res) const {
113 res.add_vertex(v);
114 if (parent_)
115 parent_->add_vertices_up_to_the_root(res);
116 }
117
118 Simplex simplex() const {
119 Simplex res;
120 add_vertices_up_to_the_root(res);
121 return res;
122 }
123
124 bool is_leaf() const {
125 return childs.empty();
126 }
127
128 bool is_root() const {
129 return parent_ == 0;
130 }
131
132 const Trie* parent() {
133 return parent_;
134 }
135
136 void remove_leaf() {
137 assert(is_leaf());
138 if (!is_root())
139 parent_->childs.erase(this);
140 }
141
145 bool contains(const Simplex& s) const {
146 Trie const* current = this;
147 if (s.empty()) return true;
148 if (current->v != s.first_vertex()) return false;
149 auto s_pos = s.begin();
150 ++s_pos;
151 while (s_pos != s.end() && current != 0) {
152 bool found = false;
153 for (const auto child : current->childs) {
154 if (child->v == *s_pos) {
155 ++s_pos;
156 current = child.get();
157 found = true;
158 break;
159 }
160 }
161 if (!found) return false;
162 }
163 return current != 0;
164 }
165
166 Trie* go_bottom_left() {
167 if (is_leaf())
168 return this;
169 else
170 return (*childs.begin())->go_bottom_left();
171 }
172
173 friend std::ostream& operator<<(std::ostream& stream, const Trie& trie) {
174 stream << "T( " << trie.v << " ";
175 for (auto t : trie.childs)
176 stream << *t;
177 stream << ")";
178 return stream;
179 }
180};
181
182template<typename SimplexHandle>
183struct Tries {
184 typedef typename SimplexHandle::Vertex_handle Vertex_handle;
185 typedef SimplexHandle Simplex;
186
187 typedef Trie<Simplex> STrie;
188
189 template<typename SimpleHandleOutputIterator>
190 Tries(unsigned num_vertices, SimpleHandleOutputIterator simplex_begin, SimpleHandleOutputIterator simplex_end) :
191 cofaces_(num_vertices, 0) {
192 for (auto i = 0u; i < num_vertices; ++i)
193 cofaces_[i] = new STrie(Vertex_handle(i));
194 for (auto s_it = simplex_begin; s_it != simplex_end; ++s_it) {
195 if (s_it->dimension() >= 1)
196 cofaces_[s_it->first_vertex()]->add_simplex(*s_it);
197 }
198 }
199
200 ~Tries() {
201 for (STrie* t : cofaces_)
202 delete t;
203 }
204
205 // return a simplex that consists in all u such uv is an edge and u>v
206
207 Simplex positive_neighbors(Vertex_handle v) const {
208 Simplex res;
209 for (auto child : cofaces_[v]->childs)
210 res.add_vertex(child->v);
211 return res;
212 }
213
214 bool contains(const Simplex& s) const {
215 auto first_v = s.first_vertex();
216 return cofaces_[first_v]->contains(s);
217 }
218
219 friend std::ostream& operator<<(std::ostream& stream, const Tries& tries) {
220 for (auto trie : tries.cofaces_)
221 stream << *trie << std::endl;
222 return stream;
223 }
224
225 // init_next_dimension must be called first
226
227 std::vector<Simplex> next_dimension_simplices() const {
228 std::vector<Simplex> res;
229 while (!(to_see_.empty()) && (to_see_.front()->simplex().dimension() == current_dimension_)) {
230 res.emplace_back(to_see_.front()->simplex());
231 for (auto child : to_see_.front()->childs)
232 to_see_.push_back(child.get());
233 to_see_.pop_front();
234 }
235 ++current_dimension_;
236 return res;
237 }
238
239 void init_next_dimension() const {
240 for (auto trie : cofaces_)
241 to_see_.push_back(trie);
242 }
243
244 private:
245 mutable std::deque<STrie*> to_see_;
246 mutable int current_dimension_ = 0;
247 std::vector<STrie*> cofaces_;
248};
249
250} // namespace skeleton_blocker
251
252namespace skbl = skeleton_blocker;
253
254} // namespace Gudhi
255
256#endif // SKELETON_BLOCKER_INTERNAL_TRIE_H_
std::ostream & operator<<(std::ostream &os, const Permutahedral_representation< Vertex, OrderedSetPartition > &simplex)
Print a permutahedral representation to a stream.
Definition: Permutahedral_representation.h:173
Handle type for the vertices of a cell complex.
Definition: VertexHandle.h:15
