Skeleton_blockers_vertices_iterators.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): David Salinas
4 *
5 * Copyright (C) 2014 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef SKELETON_BLOCKER_ITERATORS_SKELETON_BLOCKERS_VERTICES_ITERATORS_H_
12#define SKELETON_BLOCKER_ITERATORS_SKELETON_BLOCKERS_VERTICES_ITERATORS_H_
13
14#include <boost/iterator/iterator_facade.hpp>
15
16#include <utility> // for pair<>
17
18namespace Gudhi {
19
20namespace skeleton_blocker {
21
27template<typename SkeletonBlockerComplex>
28class Vertex_iterator : public boost::iterator_facade< Vertex_iterator <SkeletonBlockerComplex>
29, typename SkeletonBlockerComplex::Vertex_handle const
30, boost::forward_traversal_tag
31, typename SkeletonBlockerComplex::Vertex_handle const> {
32 friend class boost::iterator_core_access;
33
34 typedef typename SkeletonBlockerComplex::boost_vertex_iterator boost_vertex_iterator;
35 typedef typename SkeletonBlockerComplex::Vertex_handle Vertex_handle;
36 private:
37 const SkeletonBlockerComplex* complex;
38 std::pair<boost_vertex_iterator, boost_vertex_iterator> vertexIterator;
39
40
41 public:
42 Vertex_iterator() : complex(NULL) { }
43
44 Vertex_iterator(const SkeletonBlockerComplex* complex_) :
45 complex(complex_),
46 vertexIterator(vertices(complex_->skeleton)) {
47 if (!finished() && !is_active()) {
48 goto_next_valid();
49 }
50 }
51
55 Vertex_iterator(const SkeletonBlockerComplex* complex_, int end) :
56 complex(complex_), vertexIterator(vertices(complex_->skeleton)) {
57 vertexIterator.first = vertexIterator.second;
58 }
59
60 public:
61 void increment() {
62 goto_next_valid();
63 }
64
65 Vertex_handle dereference() const {
66 return (Vertex_handle(*(vertexIterator.first)));
67 }
68
69 bool equal(const Vertex_iterator& other) const {
70 return vertexIterator == other.vertexIterator && complex == other.complex;
71 }
72
73 bool operator<(const Vertex_iterator& other) const {
74 return dereference() < other.dereference();
75 }
76
77 private:
78 bool finished() const {
79 return vertexIterator.first == vertexIterator.second;
80 }
81
82 void goto_next_valid() {
83 ++vertexIterator.first;
84 if (!finished() && !is_active()) {
85 goto_next_valid();
86 }
87 }
88
89 bool is_active() const {
90 return ((*complex)[Vertex_handle(*vertexIterator.first)]).is_active();
91 }
92};
93
94template<typename SkeletonBlockerComplex>
95class Neighbors_vertices_iterator : public boost::iterator_facade < Neighbors_vertices_iterator<SkeletonBlockerComplex>
96, typename SkeletonBlockerComplex::Vertex_handle const
97, boost::forward_traversal_tag
98, typename SkeletonBlockerComplex::Vertex_handle const> {
99 friend class boost::iterator_core_access;
100
101 typedef SkeletonBlockerComplex Complex;
102 typedef typename Complex::boost_adjacency_iterator boost_adjacency_iterator;
103 typedef typename Complex::Vertex_handle Vertex_handle;
104 typedef typename Complex::Edge_handle Edge_handle;
105
106 private:
107 const Complex* complex;
109
110 boost_adjacency_iterator current_;
111 boost_adjacency_iterator end_;
112
113 public:
114 Neighbors_vertices_iterator() : complex(NULL) { }
115
116 Neighbors_vertices_iterator(const Complex* complex_, Vertex_handle v_) :
117 complex(complex_),
118 v(v_) {
119 tie(current_, end_) = adjacent_vertices(v.vertex, complex->skeleton);
120 }
121
125 Neighbors_vertices_iterator(const Complex* complex_, Vertex_handle v_, int end) :
126 complex(complex_),
127 v(v_) {
128 tie(current_, end_) = adjacent_vertices(v.vertex, complex->skeleton);
129 set_end();
130 }
131
132 void increment() {
133 if (current_ != end_)
134 ++current_;
135 }
136
137 Vertex_handle dereference() const {
138 return (Vertex_handle(*current_));
139 }
140
141 bool equal(const Neighbors_vertices_iterator& other) const {
142 return (complex == other.complex) && (v == other.v) && (current_ == other.current_) && (end_ == other.end_);
143 }
144
145 private:
146 // TODO(DS): remove this ugly hack
147 void set_end() {
148 current_ = end_;
149 }
150};
151
152} // namespace skeleton_blocker
153
154namespace skbl = skeleton_blocker;
155
156} // namespace Gudhi
157
158#endif // SKELETON_BLOCKER_ITERATORS_SKELETON_BLOCKERS_VERTICES_ITERATORS_H_
Class that represents a geometric complex that can be simplified. The class allows access to points o...
Definition: Skeleton_blocker_geometric_complex.h:29
Iterator on the vertices of a simplicial complex.
Definition: Skeleton_blockers_vertices_iterators.h:31
Vertex_iterator(const SkeletonBlockerComplex *complex_, int end)
Definition: Skeleton_blockers_vertices_iterators.h:55
Handle type for the vertices of a cell complex.
Definition: VertexHandle.h:15
