Skeleton_blocker_off_io.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): David Salinas
4 *
5 * Copyright (C) 2014 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef SKELETON_BLOCKER_SKELETON_BLOCKER_OFF_IO_H_
12#define SKELETON_BLOCKER_SKELETON_BLOCKER_OFF_IO_H_
13
14#include <gudhi/Off_reader.h>
15
16#include <string>
17#include <vector>
18#include <map>
19
20namespace Gudhi {
21
22namespace skeleton_blocker {
23
27template<typename Complex>
29 Complex& complex_;
31 typedef typename Complex::Point Point;
32
33 const bool load_only_points_;
34
35 public:
36 explicit Skeleton_blocker_off_flag_visitor_reader(Complex& complex, bool load_only_points = false) :
37 complex_(complex),
38 load_only_points_(load_only_points) { }
39
40 void init(int dim, int num_vertices, int num_faces, int num_edges) {
41 // TODO(DS): do an assert to check that this number are correctly read
42 // TODO(DS): reserve size for vector points
43 }
44
45 void point(const std::vector<double>& point) {
46 complex_.add_vertex(Point(point.begin(), point.end()));
47 }
48
49 void maximal_face(const std::vector<int>& face) {
50 if (!load_only_points_) {
51 for (size_t i = 0; i < face.size(); ++i)
52 for (size_t j = i + 1; j < face.size(); ++j) {
53 complex_.add_edge_without_blockers(Vertex_handle(face[i]), Vertex_handle(face[j]));
54 }
55 }
56 }
57
58 void done() { }
59};
60
64template<typename Complex>
66 Complex& complex_;
68 typedef typename Complex::Simplex Simplex;
69 typedef typename Complex::Point Point;
70
71 const bool load_only_points_;
72 std::vector<Point> points_;
73 std::vector<Simplex> maximal_faces_;
74
75 public:
76 explicit Skeleton_blocker_off_visitor_reader(Complex& complex, bool load_only_points = false) :
77 complex_(complex),
78 load_only_points_(load_only_points) { }
79
80 void init(int dim, int num_vertices, int num_faces, int num_edges) {
81 maximal_faces_.reserve(num_faces);
82 points_.reserve(num_vertices);
83 }
84
85 void point(const std::vector<double>& point) {
86 points_.emplace_back(point.begin(), point.end());
87 }
88
89 void maximal_face(const std::vector<int>& face) {
90 if (!load_only_points_) {
91 Simplex s;
92 for (auto x : face)
94 maximal_faces_.emplace_back(s);
95 }
96 }
97
98 void done() {
99 complex_ = make_complex_from_top_faces<Complex>(maximal_faces_.begin(), maximal_faces_.end(),
100 points_.begin(), points_.end());
101 }
102};
103
107template<typename Complex>
109 public:
115 Skeleton_blocker_off_reader(const std::string & name_file, Complex& read_complex,
116 bool read_only_points = false, bool is_flag = false) : valid_(false) {
117 std::ifstream stream(name_file);
118 if (stream.is_open()) {
119 if (is_flag || read_only_points) {
120 Skeleton_blocker_off_flag_visitor_reader<Complex> off_visitor(read_complex, read_only_points);
121 Off_reader off_reader(stream);
122 valid_ = off_reader.read(off_visitor);
123 } else {
124 Skeleton_blocker_off_visitor_reader<Complex> off_visitor(read_complex, read_only_points);
125 Off_reader off_reader(stream);
126 valid_ = off_reader.read(off_visitor);
127 }
128 }
129 }
130
134 bool is_valid() const {
135 return valid_;
136 }
137
138 private:
139 bool valid_;
140};
141
142template<typename Complex>
143class Skeleton_blocker_off_writer {
144 public:
150 Skeleton_blocker_off_writer(const std::string & name_file, const Complex& save_complex) {
151 typedef typename Complex::Vertex_handle Vertex_handle;
152
153 std::ofstream stream(name_file);
154 if (stream.is_open()) {
155 stream << "OFF\n";
156 size_t num_triangles = std::distance(save_complex.triangle_range().begin(), save_complex.triangle_range().end());
157 stream << save_complex.num_vertices() << " " << num_triangles << " 0 \n";
158
159 // in case the complex has deactivated some vertices, eg only has vertices 0 2 5 7 for instance
160 // we compute a map from 0 2 5 7 to 0 1 2 3
161 std::map<Vertex_handle, size_t> vertex_num;
162 size_t current_vertex = 0;
163
164 for (auto v : save_complex.vertex_range()) {
165 vertex_num[v] = current_vertex++;
166 const auto& pt(save_complex.point(v));
167 for (auto x : pt)
168 stream << x << " ";
169 stream << std::endl;
170 }
171
172 for (const auto & t : save_complex.triangle_range()) {
173 stream << "3 ";
174 for (auto x : t)
175 stream << vertex_num[x] << " ";
176 stream << std::endl;
177 }
178 stream.close();
179 } else {
180 std::cerr << "could not open file " << name_file << std::endl;
181 }
182 }
183};
184
185} // namespace skeleton_blocker
186
187namespace skbl = skeleton_blocker;
188
189} // namespace Gudhi
190
191#endif // SKELETON_BLOCKER_SKELETON_BLOCKER_OFF_IO_H_
OFF file reader top class visitor.
Definition: Off_reader.h:29
bool read(OffVisitor &off_visitor)
Read an OFF file and calls the following methods :
Definition: Off_reader.h:51
Edge_handle add_edge_without_blockers(Vertex_handle a, Vertex_handle b)
Adds an edge between vertices a and b without blockers.
Definition: Skeleton_blocker_complex.h:566
Complex_triangle_around_vertex_range triangle_range(Vertex_handle v) const
Range over triangles around a vertex of the simplicial complex. Methods .begin() and ....
Definition: Skeleton_blocker_complex.h:1358
Complex_vertex_range vertex_range() const
Returns a Complex_vertex_range over all vertices of the complex.
Definition: Skeleton_blocker_complex.h:1282
Class that represents a geometric complex that can be simplified. The class allows access to points o...
Definition: Skeleton_blocker_geometric_complex.h:29
Vertex_handle add_vertex()
Add a vertex to the complex with a default constructed associated point.
Definition: Skeleton_blocker_geometric_complex.h:85
const Point & point(Vertex_handle v) const
Returns the Point associated to the vertex v.
Definition: Skeleton_blocker_geometric_complex.h:101
Off reader visitor that can be passed to Off_reader to read a Skeleton_blocker_complex.
Definition: Skeleton_blocker_off_io.h:28
Class that allows to load a Skeleton_blocker_complex from an off file.
Definition: Skeleton_blocker_off_io.h:108
Skeleton_blocker_off_reader(const std::string &name_file, Complex &read_complex, bool read_only_points=false, bool is_flag=false)
Definition: Skeleton_blocker_off_io.h:115
Definition: Skeleton_blocker_off_io.h:134
Definition: Skeleton_blocker_off_io.h:65
Handle type for the vertices of a cell complex.
Definition: VertexHandle.h:15
