Skeleton_blocker_contractor.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): David Salinas
4 *
5 * Copyright (C) 2014 Inria
6 *
7 * Modification(s):
8 * - 2019/08 Vincent Rouvreau: Fix issue #10 for CGAL
9 * - YYYY/MM Author: Description of the modification
10 */
11
12#ifndef SKELETON_BLOCKER_CONTRACTOR_H_
13#define SKELETON_BLOCKER_CONTRACTOR_H_
14
15#include <gudhi/Contraction/Edge_profile.h>
16#include <gudhi/Contraction/policies/Cost_policy.h>
17#include <gudhi/Contraction/policies/Edge_length_cost.h>
18#include <gudhi/Contraction/policies/Placement_policy.h>
19#include <gudhi/Contraction/policies/First_vertex_placement.h>
20#include <gudhi/Contraction/policies/Valid_contraction_policy.h>
21#include <gudhi/Contraction/policies/Dummy_valid_contraction.h> // xxx remove
22#include <gudhi/Contraction/policies/Link_condition_valid_contraction.h> // xxx remove
23#include <gudhi/Contraction/policies/Contraction_visitor.h>
24
25#include <gudhi/Skeleton_blocker/Skeleton_blocker_complex_visitor.h>
26#include <gudhi/Debug_utils.h>
27
28// todo remove the queue to be independent from cgal
29#include <CGAL/Modifiable_priority_queue.h>
30#include <CGAL/version.h> // for CGAL_VERSION_NR
31
32#include <boost/scoped_array.hpp>
33#include <boost/scoped_ptr.hpp>
34
35#include <memory>
36#include <cassert>
37#include <list>
38#include <utility> // for pair
39#include <vector>
40
41// Make compilation fail - required for external projects - https://github.com/GUDHI/gudhi-devel/issues/10
42#if CGAL_VERSION_NR < 1041101000
43# error Skeleton_blocker_contractor is only available for CGAL >= 4.11
44#endif
45
46namespace Gudhi {
47
48namespace contraction {
49
50template <class Profile>
51Placement_policy<Profile>* make_first_vertex_placement() {
52 return new First_vertex_placement<Profile>();
53}
54
55template <class Profile>
56Valid_contraction_policy<Profile>* make_link_valid_contraction() {
57 return new Link_condition_valid_contraction<Profile>();
58}
59
63template <class Profile>
65 public:
66 typedef typename Profile::Point Point;
67 typedef typename Profile::Complex Complex;
69
70 void on_contracted(const Profile &profile, boost::optional< Point > placement) override {
71 profile.complex().remove_all_popable_blockers(profile.v0_handle());
72 }
73};
74
75template <class Profile>
76Contraction_visitor<Profile>* make_remove_popable_blockers_visitor() {
78}
79
96template<class GeometricSimplifiableComplex, class EdgeProfile = Edge_profile<GeometricSimplifiableComplex>>
98typename GeometricSimplifiableComplex::Vertex_handle> {
99 GeometricSimplifiableComplex& complex_;
100
101 public:
102 typedef typename GeometricSimplifiableComplex::Graph_vertex Graph_vertex;
103 typedef typename GeometricSimplifiableComplex::Vertex_handle Vertex_handle;
104 typedef typename GeometricSimplifiableComplex::Simplex Simplex;
105 typedef typename GeometricSimplifiableComplex::Root_vertex_handle Root_vertex_handle;
106 typedef typename GeometricSimplifiableComplex::Graph_edge Graph_edge;
107 typedef typename GeometricSimplifiableComplex::Edge_handle Edge_handle;
108 typedef typename GeometricSimplifiableComplex::Point Point;
109
110 typedef EdgeProfile Profile;
111
112
117 typedef Edge_profile_factory<EdgeProfile> Edge_profile_factory_;
118
119
120
121 typedef boost::optional<double> Cost_type;
122 typedef boost::optional<Point> Placement_type;
123
124 typedef size_t size_type;
125
127
128 private:
129 struct Compare_id {
130 Compare_id() : algorithm_(0) { }
131
132 Compare_id(Self const* aAlgorithm) : algorithm_(aAlgorithm) { }
133
134 bool operator()(Edge_handle a, Edge_handle b) const {
135 return algorithm_->get_undirected_edge_id(a) < algorithm_->get_undirected_edge_id(b);
136 }
137
138 Self const* algorithm_;
139 };
140
141 struct Compare_cost {
142 Compare_cost() : algorithm_(0) { }
143
144 Compare_cost(Self const* aAlgorithm) : algorithm_(aAlgorithm) { }
145
146 bool operator()(Edge_handle a, Edge_handle b) const {
147 // NOTE: A cost is an optional<> value.
148 // Absent optionals are ordered first; that is, "none < T" and "T > none" for any defined T != none.
149 // In consequence, edges with undefined costs will be promoted to the top of the priority queue and popped out
150 // first.
151 return algorithm_->get_data(a).cost() < algorithm_->get_data(b).cost();
152 }
153
154 Self const* algorithm_;
155 };
156
157 struct Undirected_edge_id : boost::put_get_helper<size_type, Undirected_edge_id> {
158 typedef boost::readable_property_map_tag category;
159 typedef size_type value_type;
160 typedef size_type reference;
161 typedef Edge_handle key_type;
162
163 Undirected_edge_id() : algorithm_(0) { }
164
165 Undirected_edge_id(Self const* aAlgorithm) : algorithm_(aAlgorithm) { }
166
167 size_type operator[](Edge_handle e) const {
168 return algorithm_->get_undirected_edge_id(e);
169 }
170
171 Self const* algorithm_;
172 };
173
174#if CGAL_VERSION_NR < 1050500000
175 typedef CGAL::Modifiable_priority_queue<Edge_handle, Compare_cost, Undirected_edge_id> PQ;
176#else
177 typedef CGAL::Modifiable_priority_queue<Edge_handle, Compare_cost, Undirected_edge_id, CGAL::CGAL_BOOST_PENDING_RELAXED_HEAP> PQ;
178#endif
179
180 typedef bool pq_handle;
181
182
183 // An Edge_data is associated with EVERY edge in the complex (collapsible or not).
184 // It relates the edge with the PQ-handle needed to update the priority queue
185 // It also relates the edge with a policy-based cache
186
187 class Edge_data {
188 public:
189 Edge_data() : PQHandle_(), cost_() { }
190
191 Cost_type const& cost() const {
192 return cost_;
193 }
194
195 Cost_type & cost() {
196 return cost_;
197 }
198
199 pq_handle PQ_handle() const {
200 return PQHandle_;
201 }
202
203 bool is_in_PQ() const {
204 return PQHandle_ != false;
205 }
206
207 void set_PQ_handle(pq_handle h) {
208 PQHandle_ = h;
209 }
210
211 void reset_PQ_handle() {
212 PQHandle_ = false;
213 }
214
215 private:
216 pq_handle PQHandle_;
217 Cost_type cost_;
218 };
219 typedef Edge_data* Edge_data_ptr;
220 typedef boost::scoped_array<Edge_data> Edge_data_array;
221
222 int get_undirected_edge_id(Edge_handle edge) const {
223 return complex_[edge].index();
224 }
225
226 const Edge_data& get_data(Edge_handle edge) const {
227 return edge_data_array_[get_undirected_edge_id(edge)];
228 }
229
230 Edge_data& get_data(Edge_handle edge) {
231 return edge_data_array_[get_undirected_edge_id(edge)];
232 }
233
234 Cost_type get_cost(const Profile & profile) const {
235 return (*cost_policy_)(profile, get_placement(profile));
236 }
237
238 Profile create_profile(Edge_handle edge) const {
239 if (edge_profile_factory_)
240 return edge_profile_factory_->make_profile(complex_, edge);
241 else
242 return Profile(complex_, edge);
243 }
244
245 void insert_in_PQ(Edge_handle edge, Edge_data& data) {
246 heap_PQ_->push(edge);
247 data.set_PQ_handle(true);
248 ++current_num_edges_heap_;
249 }
250
251 void update_in_PQ(Edge_handle edge, Edge_data& data) {
252#if CGAL_VERSION_NR < 1050500000
253 data.set_PQ_handle(heap_PQ_->update(edge, data.PQ_handle()));
254#else
255 heap_PQ_->update(edge);
256#endif
257 }
258
259 void remove_from_PQ(Edge_handle edge, Edge_data& data) {
260 heap_PQ_->erase(edge);
261 data.set_PQ_handle(false);
262 --current_num_edges_heap_;
263 }
264
265 boost::optional<Edge_handle> pop_from_PQ() {
266 boost::optional<Edge_handle> edge = heap_PQ_->extract_top();
267 if (edge)
268 get_data(*edge).reset_PQ_handle();
269 return edge;
270 }
271
272 private:
280 void collect_edges() {
281 //
282 // Loop over all the edges in the complex in the heap
283 //
284 size_type size = complex_.num_edges();
285 DBG("Collecting edges ...");
286 DBGMSG("num edges :", size);
287
288 edge_data_array_.reset(new Edge_data[size]);
289
290 heap_PQ_.reset(new PQ(size, Compare_cost(this), Undirected_edge_id(this)));
291
292 std::size_t id = 0;
293
294 // xxx do a parallel for
295 for (auto edge : complex_.edge_range()) {
296 complex_[edge].index() = id++;
297 Profile const& profile = create_profile(edge);
298 Edge_data& data = get_data(edge);
299 data.cost() = get_cost(profile);
300 ++initial_num_edges_heap_;
301 insert_in_PQ(edge, data);
302 if (contraction_visitor_) contraction_visitor_->on_collected(profile, data.cost());
303 }
304
305 DBG("Edges collected.");
306 }
307
308 bool should_stop(double lCost, const Profile &profile) const {
309 return false;
310 }
311
312 boost::optional<Point> get_placement(const Profile& profile) const {
313 return (*placement_policy_)(profile);
314 }
315
316 bool is_contraction_valid(Profile const& profile, Placement_type placement) const {
317 if (!valid_contraction_policy_) return true;
318 return (*valid_contraction_policy_)(profile, placement);
319 }
320
321
322 public:
331 void contract_edges(int num_max_contractions = -1) {
332 DBG("\n\nContract edges");
333 int num_contraction = 0;
334
335 bool unspecified_num_contractions = (num_max_contractions == -1);
336 //
337 // Pops and processes each edge from the PQ
338 //
339 boost::optional<Edge_handle> edge;
340 while ((edge = pop_from_PQ()) && ((num_contraction < num_max_contractions) || (unspecified_num_contractions))) {
341 Profile const& profile = create_profile(*edge);
342 Cost_type cost(get_data(*edge).cost());
343 if (contraction_visitor_) contraction_visitor_->on_selected(profile, cost, 0, 0);
344
345 DBGMSG("\n\n---- Pop edge - num vertices :", complex_.num_vertices());
346
347 if (cost) {
348 DBGMSG("sqrt(cost):", std::sqrt(*cost));
349 if (should_stop(*cost, profile)) {
350 if (contraction_visitor_) contraction_visitor_->on_stop_condition_reached();
351 DBG("should_stop");
352 break;
353 }
354 Placement_type placement = get_placement(profile);
355 if (is_contraction_valid(profile, placement) && placement) {
356 DBG("contraction_valid");
357 contract_edge(profile, placement);
358 ++num_contraction;
359 } else {
360 DBG("contraction not valid");
361 if (contraction_visitor_) contraction_visitor_->on_non_valid(profile);
362 }
363 } else {
364 DBG("uncomputable cost");
365 }
366 }
367 if (contraction_visitor_) contraction_visitor_->on_stop_condition_reached();
368 }
369
370 bool is_in_heap(Edge_handle edge) const {
371 if (heap_PQ_->empty()) {
372 return false;
373 } else {
374 return edge_data_array_[get_undirected_edge_id(edge)].is_in_PQ();
375 }
376 }
377
378 bool is_heap_empty() const {
379 return heap_PQ_->empty();
380 }
381
387 boost::optional<std::pair<Edge_handle, Placement_type > > top_edge() {
388 boost::optional<std::pair<Edge_handle, Placement_type > > res;
389
390 if (!heap_PQ_->empty()) {
391 auto edge = heap_PQ_->top();
392 Profile const& profile = create_profile(edge);
393 Placement_type placement = get_placement(profile);
394 res = std::make_pair(edge, placement);
395 DBGMSG("top edge:", complex_[edge]);
396 }
397 return res;
398 }
399
406 Skeleton_blocker_contractor(GeometricSimplifiableComplex& complex)
407 : complex_(complex),
408 cost_policy_(new Edge_length_cost<Profile>),
409 placement_policy_(new First_vertex_placement<Profile>),
410 valid_contraction_policy_(new Link_condition_valid_contraction<Profile>),
411 contraction_visitor_(new Contraction_visitor_()),
412 edge_profile_factory_(0),
413 initial_num_edges_heap_(0),
414 current_num_edges_heap_(0) {
415 complex_.set_visitor(this);
416 if (contraction_visitor_) contraction_visitor_->on_started(complex);
417 collect_edges();
418 }
419
424 Skeleton_blocker_contractor(GeometricSimplifiableComplex& complex,
425 Cost_policy_ *cost_policy,
426 Placement_policy_ * placement_policy = new First_vertex_placement<Profile>,
427 Valid_contraction_policy_ * valid_contraction_policy =
429 Contraction_visitor_* contraction_visitor = new Contraction_visitor_(),
430 Edge_profile_factory_* edge_profile_factory = NULL) :
431 complex_(complex),
432 cost_policy_(cost_policy),
433 placement_policy_(placement_policy),
434 valid_contraction_policy_(valid_contraction_policy),
435 contraction_visitor_(contraction_visitor),
436 edge_profile_factory_(edge_profile_factory),
437 initial_num_edges_heap_(0),
438 current_num_edges_heap_(0) {
439 complex_.set_visitor(this);
440 if (contraction_visitor) contraction_visitor->on_started(complex);
441 collect_edges();
442 }
443
445 complex_.set_visitor(0);
446 }
447
448 private:
449 void contract_edge(const Profile& profile, Placement_type placement) {
450 if (contraction_visitor_) contraction_visitor_->on_contracting(profile, placement);
451
452 assert(complex_.contains_vertex(profile.v0_handle()));
453 assert(complex_.contains_vertex(profile.v1_handle()));
454 assert(placement);
455
456 profile.complex().point(profile.v0_handle()) = *placement;
457
458 // remark : this is not necessary since v1 will be deactivated
459 // profile.complex().point(profile.v1_handle()) = *placement;
460
461 complex_.contract_edge(profile.v0_handle(), profile.v1_handle());
462
463 assert(complex_.contains_vertex(profile.v0_handle()));
464 assert(!complex_.contains_vertex(profile.v1_handle()));
465
466 update_changed_edges();
467
468 // the visitor could do something as complex_.remove_popable_blockers();
469 if (contraction_visitor_) contraction_visitor_->on_contracted(profile, placement);
470 }
471
472 private:
473 // every time the visitor's method on_changed_edge is called, it adds an
474 // edge to changed_edges_
475 std::vector< Edge_handle > changed_edges_;
476
481 inline void on_changed_edge(Vertex_handle a, Vertex_handle b) override {
482 boost::optional<Edge_handle> ab(complex_[std::make_pair(a, b)]);
483 assert(ab);
484 changed_edges_.push_back(*ab);
485 }
486
487 void update_changed_edges() {
488 // xxx do a parallel for
489 DBG("update edges");
490
491 // sequential loop
492 for (auto ab : changed_edges_) {
493 // 1-get the Edge_handle corresponding to ab
494 // 2-change the data in mEdgeArray[ab.id()]
495 // 3-update the heap
496 Edge_data& data = get_data(ab);
497 Profile const& profile = create_profile(ab);
498 data.cost() = get_cost(profile);
499 if (data.is_in_PQ()) {
500 update_in_PQ(ab, data);
501 } else {
502 insert_in_PQ(ab, data);
503 }
504 }
505 changed_edges_.clear();
506 }
507
508
509 private:
510 void on_remove_edge(Vertex_handle a, Vertex_handle b) override {
511 boost::optional<Edge_handle> ab((complex_[std::make_pair(a, b)]));
512 assert(ab);
513 Edge_data& lData = get_data(*ab);
514 if (lData.is_in_PQ()) {
515 remove_from_PQ(*ab, lData);
516 }
517 }
518
519 private:
525 void on_swaped_edge(Vertex_handle a, Vertex_handle b, Vertex_handle x) override {
526 boost::optional<Edge_handle> ax(complex_[std::make_pair(a, x)]);
527 boost::optional<Edge_handle> bx(complex_[std::make_pair(b, x)]);
528 assert(ax && bx);
529 complex_[*ax].index() = complex_[*bx].index();
530 }
531
532 private:
538 void on_delete_blocker(const Simplex * blocker) override {
539 // we go for all pairs xy that belongs to the blocker
540 // note that such pairs xy are necessarily edges of the complex
541 // by definition of a blocker
542
543 // todo uniqument utile pour la link condition
544 // laisser a l'utilisateur ? boolean update_heap_on_removed_blocker?
545 Simplex blocker_copy(*blocker);
546 for (auto x = blocker_copy.begin(); x != blocker_copy.end(); ++x) {
547 for (auto y = x; ++y != blocker_copy.end();) {
548 auto edge_descr(complex_[std::make_pair(*x, *y)]);
549 assert(edge_descr);
550 Edge_data& data = get_data(*edge_descr);
551 Profile const& profile = create_profile(*edge_descr);
552 data.cost() = get_cost(profile);
553
554 // If the edge is already in the heap
555 // its priority has not changed.
556 // If the edge is not present, we reinsert it
557 // remark : we could also reinsert the edge
558 // only if it is valid
559 if (!data.is_in_PQ()) {
560 insert_in_PQ(*edge_descr, data);
561 }
562 }
563 }
564 }
565
566
567 private:
568 std::shared_ptr<Cost_policy_> cost_policy_;
569 std::shared_ptr<Placement_policy_> placement_policy_;
570 std::shared_ptr<Valid_contraction_policy_> valid_contraction_policy_;
571 std::shared_ptr<Contraction_visitor_> contraction_visitor_;
572
573 // in case the user wants to do something special when the edge profile
574 // are created (for instance add some info)
575 std::shared_ptr<Edge_profile_factory_> edge_profile_factory_;
576 Edge_data_array edge_data_array_;
577
578 boost::scoped_ptr<PQ> heap_PQ_;
579 int initial_num_edges_heap_;
580 int current_num_edges_heap_;
581};
582
583} // namespace contraction
584
585} // namespace Gudhi
586
587#endif // SKELETON_BLOCKER_CONTRACTOR_H_
Visitor to remove popable blockers after an edge contraction.
Definition: Skeleton_blocker_contractor.h:64
Interface for a visitor of the edge contraction process.
Definition: Contraction_visitor.h:27
Policy to specify the cost of contracting an edge.
Definition: Cost_policy.h:25
return a cost corresponding to the squared length of the edge
Definition: Edge_length_cost.h:24
Places the contracted point onto the first point of the edge.
Definition: First_vertex_placement.h:24
Policy to specify where the merged point had to be placed after an edge contraction.
Definition: Placement_policy.h:25
Class that allows to contract iteratively edges of a simplicial complex.
Definition: Skeleton_blocker_contractor.h:98
void contract_edges(int num_max_contractions=-1)
Contract edges.
Definition: Skeleton_blocker_contractor.h:331
Skeleton_blocker_contractor(GeometricSimplifiableComplex &complex, Cost_policy_ *cost_policy, Placement_policy_ *placement_policy=new First_vertex_placement< Profile >, Valid_contraction_policy_ *valid_contraction_policy=new Link_condition_valid_contraction< Profile >, Contraction_visitor_ *contraction_visitor=new Contraction_visitor_(), Edge_profile_factory_ *edge_profile_factory=NULL)
Constructor with customed policies.
Definition: Skeleton_blocker_contractor.h:424
Skeleton_blocker_contractor(GeometricSimplifiableComplex &complex)
Constructor with default policies.
Definition: Skeleton_blocker_contractor.h:406
boost::optional< std::pair< Edge_handle, Placement_type > > top_edge()
Returns an Edge_handle and a Placement_type. This pair consists in the edge with the lowest cost in t...
Definition: Skeleton_blocker_contractor.h:387
Policy to specify if an edge contraction is valid or not.
Definition: Valid_contraction_policy.h:23
A dummy visitor of a simplicial complex that does nothing.
Definition: Skeleton_blocker_complex_visitor.h:65
Handle type for the vertices of a cell complex.
Definition: VertexHandle.h:15
