Skeleton_blocker_complex_visitor.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): David Salinas
4 *
5 * Copyright (C) 2014 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef SKELETON_BLOCKER_SKELETON_BLOCKER_COMPLEX_VISITOR_H_
12#define SKELETON_BLOCKER_SKELETON_BLOCKER_COMPLEX_VISITOR_H_
13
14#include <gudhi/Skeleton_blocker/Skeleton_blocker_simplex.h>
15
16namespace Gudhi {
17
18namespace skeleton_blocker {
19// TODO(DS): to be constified
20
25template<typename Vertex_handle>
27 public:
29
30 virtual void on_add_vertex(Vertex_handle) = 0;
31 virtual void on_remove_vertex(Vertex_handle) = 0;
32
33 virtual void on_add_edge_without_blockers(Vertex_handle a, Vertex_handle b) = 0;
34 virtual void on_remove_edge(Vertex_handle a, Vertex_handle b) = 0;
35
41
51 Vertex_handle x) = 0;
52 virtual void on_add_blocker(
54 virtual void on_delete_blocker(
56};
57
63template<typename Vertex_handle>
65Vertex_handle> {
66 public:
67 void on_add_vertex(Vertex_handle) { }
68
69 void on_remove_vertex(Vertex_handle) { }
70
71 void on_add_edge_without_blockers(Vertex_handle a, Vertex_handle b) { }
72
73 void on_remove_edge(Vertex_handle a, Vertex_handle b) { }
74
76
78
79 void on_add_blocker(const Skeleton_blocker_simplex<Vertex_handle>&) { }
80
81 void on_delete_blocker(const Skeleton_blocker_simplex<Vertex_handle>*) { }
82};
83
89template<typename Vertex_handle>
91Vertex_handle> {
92 public:
93 void on_add_vertex(Vertex_handle v) {
94 std::cerr << "on_add_vertex:" << v << std::endl;
95 }
96
97 void on_remove_vertex(Vertex_handle v) {
98 std::cerr << "on_remove_vertex:" << v << std::endl;
99 }
100
101 void on_add_edge_without_blockers(Vertex_handle a, Vertex_handle b) {
102 std::cerr << "on_add_edge_without_blockers:" << a << "," << b << std::endl;
103 }
104
105 void on_remove_edge(Vertex_handle a, Vertex_handle b) {
106 std::cerr << "on_remove_edge:" << a << "," << b << std::endl;
107 }
108
110 std::cerr << "on_changed_edge:" << a << "," << b << std::endl;
111 }
112
114 std::cerr << "on_swaped_edge:" << a << "," << b << "," << x << std::endl;
115 }
116
117 void on_add_blocker(const Skeleton_blocker_simplex<Vertex_handle>& b) {
118 std::cerr << "on_add_blocker:" << b << std::endl;
119 }
120
121 void on_delete_blocker(const Skeleton_blocker_simplex<Vertex_handle>* b) {
122 std::cerr << "on_delete_blocker:" << b << std::endl;
123 }
124};
125
126} // namespace skeleton_blocker
127
128namespace skbl = skeleton_blocker;
129
130} // namespace Gudhi
131
132#endif // SKELETON_BLOCKER_SKELETON_BLOCKER_COMPLEX_VISITOR_H_
A dummy visitor of a simplicial complex that does nothing.
Definition: Skeleton_blocker_complex_visitor.h:65
void on_changed_edge(Vertex_handle a, Vertex_handle b)
Called when an edge changes, during the contraction of an edge.
Definition: Skeleton_blocker_complex_visitor.h:75
void on_swaped_edge(Vertex_handle a, Vertex_handle b, Vertex_handle x)
Called when performing an edge contraction when an edge bx is replaced by an edge ax (not already pre...
Definition: Skeleton_blocker_complex_visitor.h:77
A visitor that prints the visit information.
Definition: Skeleton_blocker_complex_visitor.h:91
Definition: Skeleton_blocker_complex_visitor.h:109
Definition: Skeleton_blocker_complex_visitor.h:113
Interface for a visitor of a simplicial complex.
Definition: Skeleton_blocker_complex_visitor.h:26
virtual void on_changed_edge(Vertex_handle a, Vertex_handle b)=0
virtual void on_swaped_edge(Vertex_handle a, Vertex_handle b, Vertex_handle x)=0
Abstract simplex used in Skeleton blockers data-structure.
Definition: Skeleton_blocker_simplex.h:38
Handle type for the vertices of a cell complex.
Definition: VertexHandle.h:15
