SimplicialComplexForAlpha3d.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Vincent Rouvreau
4 *
5 * Copyright (C) 2018 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef CONCEPT_ALPHA_COMPLEX_SIMPLICIAL_COMPLEX_FOR_ALPHA_3D_H_
12#define CONCEPT_ALPHA_COMPLEX_SIMPLICIAL_COMPLEX_FOR_ALPHA_3D_H_
13
14namespace Gudhi {
15
16namespace alpha_complex {
17
23 typedef unspecified Vertex_handle;
25 typedef unspecified Filtration_value;
26
28 std::size_t num_vertices();
29
32 void insert_simplex(std::vector<Vertex_handle> const& vertex_range, Filtration_value filtration);
33
36
39};
40
41} // namespace alpha_complex
42
43} // namespace Gudhi
44
45#endif // CONCEPT_ALPHA_COMPLEX_SIMPLICIAL_COMPLEX_FOR_ALPHA_3D_H_
The concept SimplicialComplexForAlpha3d describes the requirements for a type to implement a simplici...
Definition: SimplicialComplexForAlpha3d.h:21
void insert_simplex(std::vector< Vertex_handle > const &vertex_range, Filtration_value filtration)
Inserts a simplex from a given simplex (represented by a vector of Vertex_handle) in the simplicial c...
Definition: SimplicialComplexForAlpha3d.h:25
Definition: SimplicialComplexForAlpha3d.h:23
void prune_above_filtration(Filtration_value filtration)
