Simplicial_complex.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Clement Jamin
4 *
5 * Copyright (C) 2016 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef TANGENTIAL_COMPLEX_SIMPLICIAL_COMPLEX_H_
12#define TANGENTIAL_COMPLEX_SIMPLICIAL_COMPLEX_H_
13
14#include <gudhi/Tangential_complex/config.h>
15#include <gudhi/Tangential_complex/utilities.h>
16#include <gudhi/Debug_utils.h>
17#include <gudhi/console_color.h>
18
19#include <CGAL/iterator.h>
20
21// For is_pure_pseudomanifold
22#include <boost/graph/graph_traits.hpp>
23#include <boost/graph/adjacency_list.hpp>
24#include <boost/graph/connected_components.hpp>
25#include <boost/container/flat_set.hpp>
26
27#include <algorithm>
28#include <string>
29#include <fstream>
30#include <map> // for map<>
31#include <vector> // for vector<>
32#include <set> // for set<>
33
34namespace Gudhi {
35namespace tangential_complex {
36namespace internal {
37
38class Simplicial_complex {
39 public:
40 typedef boost::container::flat_set<std::size_t> Simplex;
41 typedef std::set<Simplex> Simplex_set;
42
43 // If perform_checks = true, the function:
44 // - won't insert the simplex if it is already in a higher dim simplex
45 // - will erase any lower-dim simplices that are faces of the new simplex
46 // Returns true if the simplex was added
47 bool add_simplex(
48 const Simplex &s, bool perform_checks = true) {
49 if (perform_checks) {
50 unsigned int num_pts = static_cast<int> (s.size());
51 std::vector<Complex::iterator> to_erase;
52 bool check_higher_dim_simpl = true;
53 for (Complex::iterator it_simplex = m_complex.begin(),
54 it_simplex_end = m_complex.end();
55 it_simplex != it_simplex_end;
56 ++it_simplex) {
57 // Check if the simplex is not already in a higher dim simplex
58 if (check_higher_dim_simpl
59 && it_simplex->size() > num_pts
60 && std::includes(it_simplex->begin(), it_simplex->end(),
61 s.begin(), s.end())) {
62 // No need to insert it, then
63 return false;
64 }
65 // Check if the simplex includes some lower-dim simplices
66 if (it_simplex->size() < num_pts
67 && std::includes(s.begin(), s.end(),
68 it_simplex->begin(), it_simplex->end())) {
69 to_erase.push_back(it_simplex);
70 // We don't need to check higher-sim simplices any more
71 check_higher_dim_simpl = false;
72 }
73 }
74 for (std::vector<Complex::iterator>::const_iterator it = to_erase.begin();
75 it != to_erase.end(); ++it) {
76 m_complex.erase(*it);
77 }
78 }
79 return m_complex.insert(s).second;
80 }
81
82 const Simplex_set &simplex_range() const {
83 return m_complex;
84 }
85
86 bool empty() {
87 return m_complex.empty();
88 }
89
90 void clear() {
91 m_complex.clear();
92 }
93
94 template <typename Test, typename Output_it>
95 void get_simplices_matching_test(Test test, Output_it out) {
96 for (Complex::const_iterator it_simplex = m_complex.begin(),
97 it_simplex_end = m_complex.end();
98 it_simplex != it_simplex_end;
99 ++it_simplex) {
100 if (test(*it_simplex))
101 *out++ = *it_simplex;
102 }
103 }
104
105 // When a simplex S has only one co-face C, we can remove S and C
106 // without changing the topology
107
108 void collapse(int max_simplex_dim, bool quiet = false) {
109#ifdef DEBUG_TRACES
110 if (!quiet)
111 std::cerr << "Collapsing... ";
112#endif
113 // We note k = max_simplex_dim - 1
114 int k = max_simplex_dim - 1;
115
116 typedef Complex::iterator Simplex_iterator;
117 typedef std::vector<Simplex_iterator> Simplex_iterator_list;
118 typedef std::map<Simplex, Simplex_iterator_list> Cofaces_map;
119
120 std::size_t num_collapsed_maximal_simplices = 0;
121 do {
122 num_collapsed_maximal_simplices = 0;
123 // Create a map associating each non-maximal k-faces to the list of its
124 // maximal cofaces
125 Cofaces_map cofaces_map;
126 for (Complex::const_iterator it_simplex = m_complex.begin(),
127 it_simplex_end = m_complex.end();
128 it_simplex != it_simplex_end;
129 ++it_simplex) {
130 if (static_cast<int> (it_simplex->size()) > k + 1) {
131 std::vector<Simplex> k_faces;
132 // Get the k-faces composing the simplex
133 combinations(*it_simplex, k + 1, std::back_inserter(k_faces));
134 for (const auto &comb : k_faces)
135 cofaces_map[comb].push_back(it_simplex);
136 }
137 }
138
139 // For each non-maximal k-face F, if F has only one maximal coface Cf:
140 // - Look for the other k-faces F2, F3... of Cf in the map and:
141 // * if the list contains only Cf, clear the list (we don't remove the
142 // list since it creates troubles with the iterators) and add the F2,
143 // F3... to the complex
144 // * otherwise, remove Cf from the associated list
145 // - Remove Cf from the complex
146 for (Cofaces_map::const_iterator it_map_elt = cofaces_map.begin(),
147 it_map_end = cofaces_map.end();
148 it_map_elt != it_map_end;
149 ++it_map_elt) {
150 if (it_map_elt->second.size() == 1) {
151 std::vector<Simplex> k_faces;
152 const Simplex_iterator_list::value_type &it_Cf =
153 *it_map_elt->second.begin();
154 GUDHI_CHECK(it_Cf->size() == max_simplex_dim + 1,
155 std::logic_error("Wrong dimension"));
156 // Get the k-faces composing the simplex
157 combinations(*it_Cf, k + 1, std::back_inserter(k_faces));
158 for (const auto &f2 : k_faces) {
159 // Skip F
160 if (f2 != it_map_elt->first) {
161 Cofaces_map::iterator it_comb_in_map = cofaces_map.find(f2);
162 if (it_comb_in_map->second.size() == 1) {
163 it_comb_in_map->second.clear();
164 m_complex.insert(f2);
165 } else { // it_comb_in_map->second.size() > 1
166 Simplex_iterator_list::iterator it = std::find(it_comb_in_map->second.begin(),
167 it_comb_in_map->second.end(),
168 it_Cf);
169 GUDHI_CHECK(it != it_comb_in_map->second.end(),
170 std::logic_error("Error: it == it_comb_in_map->second.end()"));
171 it_comb_in_map->second.erase(it);
172 }
173 }
174 }
175 m_complex.erase(it_Cf);
176 ++num_collapsed_maximal_simplices;
177 }
178 }
179 // Repeat until no maximal simplex got removed
180 } while (num_collapsed_maximal_simplices > 0);
181
182 // Collapse the lower dimension simplices
183 if (k > 0)
184 collapse(max_simplex_dim - 1, true);
185
186#ifdef DEBUG_TRACES
187 if (!quiet)
188 std::cerr << "done.\n";
189#endif
190 }
191
192 void display_stats() const {
193 std::cerr << yellow << "Complex stats:\n" << white;
194
195 if (m_complex.empty()) {
196 std::cerr << " * No simplices.\n";
197 } else {
198 // Number of simplex for each dimension
199 std::map<int, std::size_t> simplex_stats;
200
201 for (Complex::const_iterator it_simplex = m_complex.begin(),
202 it_simplex_end = m_complex.end();
203 it_simplex != it_simplex_end;
204 ++it_simplex) {
205 ++simplex_stats[static_cast<int> (it_simplex->size()) - 1];
206 }
207
208 for (std::map<int, std::size_t>::const_iterator it_map = simplex_stats.begin();
209 it_map != simplex_stats.end(); ++it_map) {
210 std::cerr << " * " << it_map->first << "-simplices: "
211 << it_map->second << "\n";
212 }
213 }
214 }
215
216 // verbose_level = 0, 1 or 2
217 bool is_pure_pseudomanifold__do_not_check_if_stars_are_connected(int simplex_dim,
218 bool allow_borders = false,
219 bool exit_at_the_first_problem = false,
220 int verbose_level = 0,
221 std::size_t *p_num_wrong_dim_simplices = NULL,
222 std::size_t *p_num_wrong_number_of_cofaces = NULL) const {
223 typedef Simplex K_1_face;
224 typedef std::map<K_1_face, std::size_t> Cofaces_map;
225
226 std::size_t num_wrong_dim_simplices = 0;
227 std::size_t num_wrong_number_of_cofaces = 0;
228
229 // Counts the number of cofaces of each K_1_face
230
231 // Create a map associating each non-maximal k-faces to the list of its
232 // maximal cofaces
233 Cofaces_map cofaces_map;
234 for (Complex::const_iterator it_simplex = m_complex.begin(),
235 it_simplex_end = m_complex.end();
236 it_simplex != it_simplex_end;
237 ++it_simplex) {
238 if (static_cast<int> (it_simplex->size()) != simplex_dim + 1) {
239 if (verbose_level >= 2)
240 std::cerr << "Found a simplex with dim = "
241 << it_simplex->size() - 1 << "\n";
242 ++num_wrong_dim_simplices;
243 } else {
244 std::vector<K_1_face> k_1_faces;
245 // Get the facets composing the simplex
246 combinations(
247 *it_simplex, simplex_dim, std::back_inserter(k_1_faces));
248 for (const auto &k_1_face : k_1_faces) {
249 ++cofaces_map[k_1_face];
250 }
251 }
252 }
253
254 for (Cofaces_map::const_iterator it_map_elt = cofaces_map.begin(),
255 it_map_end = cofaces_map.end();
256 it_map_elt != it_map_end;
257 ++it_map_elt) {
258 if (it_map_elt->second != 2
259 && (!allow_borders || it_map_elt->second != 1)) {
260 if (verbose_level >= 2)
261 std::cerr << "Found a k-1-face with "
262 << it_map_elt->second << " cofaces\n";
263
264 if (exit_at_the_first_problem)
265 return false;
266 else
267 ++num_wrong_number_of_cofaces;
268 }
269 }
270
271 bool ret = num_wrong_dim_simplices == 0 && num_wrong_number_of_cofaces == 0;
272
273 if (verbose_level >= 1) {
274 std::cerr << "Pure pseudo-manifold: ";
275 if (ret) {
276 std::cerr << green << "YES" << white << "\n";
277 } else {
278 std::cerr << red << "NO" << white << "\n"
279 << " * Number of wrong dimension simplices: "
280 << num_wrong_dim_simplices << "\n"
281 << " * Number of wrong number of cofaces: "
282 << num_wrong_number_of_cofaces << "\n";
283 }
284 }
285
286 if (p_num_wrong_dim_simplices)
287 *p_num_wrong_dim_simplices = num_wrong_dim_simplices;
288 if (p_num_wrong_number_of_cofaces)
289 *p_num_wrong_number_of_cofaces = num_wrong_number_of_cofaces;
290
291 return ret;
292 }
293
294 template <int K>
295 std::size_t num_K_simplices() const {
296 Simplex_set k_simplices;
297
298 for (Complex::const_iterator it_simplex = m_complex.begin(),
299 it_simplex_end = m_complex.end();
300 it_simplex != it_simplex_end;
301 ++it_simplex) {
302 if (it_simplex->size() == K + 1) {
303 k_simplices.insert(*it_simplex);
304 } else if (it_simplex->size() > K + 1) {
305 // Get the k-faces composing the simplex
306 combinations(
307 *it_simplex, K + 1, std::inserter(k_simplices, k_simplices.begin()));
308 }
309 }
310
311 return k_simplices.size();
312 }
313
314 std::ptrdiff_t euler_characteristic(bool verbose = false) const {
315 if (verbose)
316 std::cerr << "\nComputing Euler characteristic of the complex...\n";
317
318 std::size_t num_vertices = num_K_simplices<0>();
319 std::size_t num_edges = num_K_simplices<1>();
320 std::size_t num_triangles = num_K_simplices<2>();
321
322 std::ptrdiff_t ec =
323 (std::ptrdiff_t) num_vertices
324 - (std::ptrdiff_t) num_edges
325 + (std::ptrdiff_t) num_triangles;
326
327 if (verbose)
328 std::cerr << "Euler characteristic: V - E + F = "
329 << num_vertices << " - " << num_edges << " + " << num_triangles << " = "
330 << blue
331 << ec
332 << white << "\n";
333
334 return ec;
335 }
336
337 // TODO(CJ): ADD COMMENTS
338
339 bool is_pure_pseudomanifold(
340 int simplex_dim,
341 std::size_t num_vertices,
342 bool allow_borders = false,
343 bool exit_at_the_first_problem = false,
344 int verbose_level = 0,
345 std::size_t *p_num_wrong_dim_simplices = NULL,
346 std::size_t *p_num_wrong_number_of_cofaces = NULL,
347 std::size_t *p_num_unconnected_stars = NULL,
348 Simplex_set *p_wrong_dim_simplices = NULL,
349 Simplex_set *p_wrong_number_of_cofaces_simplices = NULL,
350 Simplex_set *p_unconnected_stars_simplices = NULL) const {
351 // If simplex_dim == 1, we do not need to check if stars are connected
352 if (simplex_dim == 1) {
353 if (p_num_unconnected_stars)
354 *p_num_unconnected_stars = 0;
355 return is_pure_pseudomanifold__do_not_check_if_stars_are_connected(simplex_dim,
356 allow_borders,
357 exit_at_the_first_problem,
358 verbose_level,
359 p_num_wrong_dim_simplices,
360 p_num_wrong_number_of_cofaces);
361 }
362 // Associates each vertex (= the index in the vector)
363 // to its star (list of simplices)
364 typedef std::vector<std::vector<Complex::const_iterator> > Stars;
365 std::size_t num_wrong_dim_simplices = 0;
366 std::size_t num_wrong_number_of_cofaces = 0;
367 std::size_t num_unconnected_stars = 0;
368
369 // Fills a Stars data structure
370 Stars stars;
371 stars.resize(num_vertices);
372 for (Complex::const_iterator it_simplex = m_complex.begin(),
373 it_simplex_end = m_complex.end();
374 it_simplex != it_simplex_end;
375 ++it_simplex) {
376 if (static_cast<int> (it_simplex->size()) != simplex_dim + 1) {
377 if (verbose_level >= 2)
378 std::cerr << "Found a simplex with dim = "
379 << it_simplex->size() - 1 << "\n";
380 ++num_wrong_dim_simplices;
381 if (p_wrong_dim_simplices)
382 p_wrong_dim_simplices->insert(*it_simplex);
383 } else {
384 for (Simplex::const_iterator it_point_idx = it_simplex->begin();
385 it_point_idx != it_simplex->end();
386 ++it_point_idx) {
387 stars[*it_point_idx].push_back(it_simplex);
388 }
389 }
390 }
391
392 // Now, for each star, we have a vector of its d-simplices
393 // i.e. one index for each d-simplex
394 // Boost Graph only deals with indexes, so we also need indexes for the
395 // (d-1)-simplices
396 std::size_t center_vertex_index = 0;
397 for (Stars::const_iterator it_star = stars.begin();
398 it_star != stars.end();
399 ++it_star, ++center_vertex_index) {
400 typedef std::map<Simplex, std::vector<std::size_t> >
401 Dm1_faces_to_adj_D_faces;
402 Dm1_faces_to_adj_D_faces dm1_faces_to_adj_d_faces;
403
404 for (std::size_t i_dsimpl = 0; i_dsimpl < it_star->size(); ++i_dsimpl) {
405 Simplex dm1_simpl_of_link = *((*it_star)[i_dsimpl]);
406 dm1_simpl_of_link.erase(center_vertex_index);
407 // Copy it to a vector so that we can use operator[] on it
408 std::vector<std::size_t> dm1_simpl_of_link_vec(
409 dm1_simpl_of_link.begin(), dm1_simpl_of_link.end());
410
411 CGAL::Combination_enumerator<int> dm2_simplices(
412 simplex_dim - 1, 0, simplex_dim);
413 for (; !dm2_simplices.finished(); ++dm2_simplices) {
414 Simplex dm2_simpl;
415 for (int j = 0; j < simplex_dim - 1; ++j)
416 dm2_simpl.insert(dm1_simpl_of_link_vec[dm2_simplices[j]]);
417 dm1_faces_to_adj_d_faces[dm2_simpl].push_back(i_dsimpl);
418 }
419 }
420
421 Adj_graph adj_graph;
422 std::vector<Graph_vertex> d_faces_descriptors;
423 d_faces_descriptors.resize(it_star->size());
424 for (std::size_t j = 0; j < it_star->size(); ++j)
425 d_faces_descriptors[j] = boost::add_vertex(adj_graph);
426
427 Dm1_faces_to_adj_D_faces::const_iterator dm1_to_d_it =
428 dm1_faces_to_adj_d_faces.begin();
429 Dm1_faces_to_adj_D_faces::const_iterator dm1_to_d_it_end =
430 dm1_faces_to_adj_d_faces.end();
431 for (std::size_t i_km1_face = 0;
432 dm1_to_d_it != dm1_to_d_it_end;
433 ++dm1_to_d_it, ++i_km1_face) {
434 Graph_vertex km1_gv = boost::add_vertex(adj_graph);
435
436 for (std::vector<std::size_t>::const_iterator kface_it =
437 dm1_to_d_it->second.begin();
438 kface_it != dm1_to_d_it->second.end();
439 ++kface_it) {
440 boost::add_edge(km1_gv, *kface_it, adj_graph);
441 }
442
443 if (dm1_to_d_it->second.size() != 2
444 && (!allow_borders || dm1_to_d_it->second.size() != 1)) {
445 ++num_wrong_number_of_cofaces;
446 if (p_wrong_number_of_cofaces_simplices) {
447 for (auto idx : dm1_to_d_it->second)
448 p_wrong_number_of_cofaces_simplices->insert(*((*it_star)[idx]));
449 }
450 }
451 }
452
453 // What is left is to check the connexity
454 bool is_connected = true;
455 if (boost::num_vertices(adj_graph) > 0) {
456 std::vector<int> components(boost::num_vertices(adj_graph));
457 is_connected =
458 (boost::connected_components(adj_graph, &components[0]) == 1);
459 }
460
461 if (!is_connected) {
462 if (verbose_level >= 2)
463 std::cerr << "Error: star #" << center_vertex_index
464 << " is not connected\n";
465 ++num_unconnected_stars;
466 if (p_unconnected_stars_simplices) {
467 for (std::vector<Complex::const_iterator>::const_iterator
468 it_simpl = it_star->begin(),
469 it_simpl_end = it_star->end();
470 it_simpl != it_simpl_end;
471 ++it_simpl) {
472 p_unconnected_stars_simplices->insert(**it_simpl);
473 }
474 }
475 }
476 }
477
478 // Each one has been counted several times ("simplex_dim" times)
479 num_wrong_number_of_cofaces /= simplex_dim;
480
481 bool ret =
482 num_wrong_dim_simplices == 0
483 && num_wrong_number_of_cofaces == 0
484 && num_unconnected_stars == 0;
485
486 if (verbose_level >= 1) {
487 std::cerr << "Pure pseudo-manifold: ";
488 if (ret) {
489 std::cerr << green << "YES" << white << "\n";
490 } else {
491 std::cerr << red << "NO" << white << "\n"
492 << " * Number of wrong dimension simplices: "
493 << num_wrong_dim_simplices << "\n"
494 << " * Number of wrong number of cofaces: "
495 << num_wrong_number_of_cofaces << "\n"
496 << " * Number of not-connected stars: "
497 << num_unconnected_stars << "\n";
498 }
499 }
500
501 if (p_num_wrong_dim_simplices)
502 *p_num_wrong_dim_simplices = num_wrong_dim_simplices;
503 if (p_num_wrong_number_of_cofaces)
504 *p_num_wrong_number_of_cofaces = num_wrong_number_of_cofaces;
505 if (p_num_unconnected_stars)
506 *p_num_unconnected_stars = num_unconnected_stars;
507
508 return ret;
509 }
510
511 private:
512 typedef Simplex_set Complex;
513
514 // graph is an adjacency list
515 typedef boost::adjacency_list<boost::vecS, boost::vecS, boost::undirectedS> Adj_graph;
516 // map that gives to a certain simplex its node in graph and its dimension
517 typedef boost::graph_traits<Adj_graph>::vertex_descriptor Graph_vertex;
518 typedef boost::graph_traits<Adj_graph>::edge_descriptor Graph_edge;
519
520 Complex m_complex;
521}; // class Simplicial_complex
522
523} // namespace internal
524} // namespace tangential_complex
525} // namespace Gudhi
526
527#endif // TANGENTIAL_COMPLEX_SIMPLICIAL_COMPLEX_H_
Class that represents a geometric complex that can be simplified. The class allows access to points o...
Definition: Skeleton_blocker_geometric_complex.h:29
