SimplexInCoxeterTriangulation.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Siargey Kachanovich
4 *
5 * Copyright (C) 2019 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef CONCEPT_COXETER_TRIANGULATION_SIMPLEX_IN_COXETER_TRIANGULATION_H_
12#define CONCEPT_COXETER_TRIANGULATION_SIMPLEX_IN_COXETER_TRIANGULATION_H_
13
14#include <cstdlib> // for std::size_t
15
16#include <gudhi/Permutahedral_representation.h>
17
18namespace Gudhi {
19
20namespace coxeter_triangulation {
21
28 typedef Vertex_ Vertex;
29
31 typedef Ordered_set_partition_ OrderedSetPartition;
32
34 unsigned dimension() const;
35
37 typedef Vertex_range;
38
42
46 typedef Face_range;
47
51 Face_range face_range(std::size_t k) const;
52
57
61 typedef Coface_range;
62
66 Coface_range coface_range(std::size_t k) const;
67
72
74 bool is_face_of(const Permutahedral_representation& other) const;
75};
76
77} // namespace coxeter_triangulation
78
79} // namespace Gudhi
80
81#endif
A class that stores the permutahedral representation of a simplex in a Coxeter triangulation or a Fre...
Definition: Permutahedral_representation.h:38
The concept SimplexInCoxeterTriangulation describes the requirements for a type to implement a repres...
Definition: SimplexInCoxeterTriangulation.h:26
Returns a range of permutahedral representations of k-dimensional cofaces of the simplex for some giv...
Dimension of the simplex.
Face_range facet_range() const
Returns a range of permutahedral representations of facets of the simplex. The dimension of the simpl...
Returns a range of permutahedral representations of k-dimensional faces of the simplex for some given...
bool is_face_of(const Permutahedral_representation &other) const
Returns true, if the simplex is a face of other simplex.
Type of a range of vertices, each of type Vertex.
Definition: SimplexInCoxeterTriangulation.h:37
Vertex_range vertex_range() const
Returns a range of vertices of the simplex.
Type of a range of cofaces, each of type that is a model of the concept SimplexInCoxeterTriangulation...
Definition: SimplexInCoxeterTriangulation.h:61
Type of the ordered partition.
Definition: SimplexInCoxeterTriangulation.h:31
Coface_range cofacet_range() const
Returns a range of permutahedral representations of cofacets of the simplex. The dimension of the sim...
typedef Face_range
Type of a range of faces, each of type that is a model of the concept SimplexInCoxeterTriangulation.
Definition: SimplexInCoxeterTriangulation.h:46
Vertex_ Vertex
Type of the vertex.
Definition: SimplexInCoxeterTriangulation.h:28
