Simplex_tree_node_explicit_storage.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Clément Maria
4 *
5 * Copyright (C) 2014 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef SIMPLEX_TREE_SIMPLEX_TREE_NODE_EXPLICIT_STORAGE_H_
12#define SIMPLEX_TREE_SIMPLEX_TREE_NODE_EXPLICIT_STORAGE_H_
13
14#include <vector>
15
16namespace Gudhi {
17
28template<class SimplexTree>
29struct Simplex_tree_node_explicit_storage : SimplexTree::Filtration_simplex_base, SimplexTree::Key_simplex_base {
30 typedef typename SimplexTree::Siblings Siblings;
33
35 Filtration_value filtration = 0)
36 : children_(sib) {
37 this->assign_filtration(filtration);
38 }
39
40 /*
41 * Assign children to the node
42 */
43 void assign_children(Siblings * children) {
44 children_ = children;
45 }
46
47 /* Careful -> children_ can be NULL*/
48 Siblings * children() {
49 return children_;
50 }
51
52 private:
53 Siblings * children_;
54};
55 // end addtogroup simplex_tree
57
58} // namespace Gudhi
59
60#endif // SIMPLEX_TREE_SIMPLEX_TREE_NODE_EXPLICIT_STORAGE_H_
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
Node of a simplex tree with filtration value and simplex key.
Definition: Simplex_tree_node_explicit_storage.h:29
Key type used as simplex identifier.
Definition: SimplexKey.h:15
