Persistence_graph.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author: Francois Godi
4 *
5 * Copyright (C) 2015 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef PERSISTENCE_GRAPH_H_
12#define PERSISTENCE_GRAPH_H_
13
14#include <gudhi/Internal_point.h>
15
16#ifdef GUDHI_USE_TBB
17#include <tbb/parallel_sort.h>
18#endif
19
20#include <vector>
21#include <algorithm>
22#include <limits> // for numeric_limits
23
24namespace Gudhi {
25
26namespace persistence_diagram {
27
33class Persistence_graph {
34 public:
36 template<typename Persistence_diagram1, typename Persistence_diagram2>
37 Persistence_graph(const Persistence_diagram1& diag1, const Persistence_diagram2& diag2, double e);
39 bool on_the_u_diagonal(int u_point_index) const;
41 bool on_the_v_diagonal(int v_point_index) const;
43 int corresponding_point_in_u(int v_point_index) const;
45 int corresponding_point_in_v(int u_point_index) const;
47 double distance(int u_point_index, int v_point_index) const;
49 int size() const;
51 double bottleneck_alive() const;
53 std::vector<double> sorted_distances() const;
55 double max_dist_to_diagonal() const;
57 Internal_point get_u_point(int u_point_index) const;
59 Internal_point get_v_point(int v_point_index) const;
60
61 private:
62 std::vector<Internal_point> u;
63 std::vector<Internal_point> v;
64 double b_alive;
65};
66
67template<typename Persistence_diagram1, typename Persistence_diagram2>
68Persistence_graph::Persistence_graph(const Persistence_diagram1 &diag1,
69 const Persistence_diagram2 &diag2, double e)
70 : u(), v(), b_alive(0.) {
71 std::vector<double> u_alive;
72 std::vector<double> v_alive;
73 for (auto it = std::begin(diag1); it != std::end(diag1); ++it) {
74 if (std::get<1>(*it) == std::numeric_limits<double>::infinity())
75 u_alive.push_back(std::get<0>(*it));
76 else if (std::get<1>(*it) - std::get<0>(*it) > e)
77 u.push_back(Internal_point(std::get<0>(*it), std::get<1>(*it), u.size()));
78 }
79 for (auto it = std::begin(diag2); it != std::end(diag2); ++it) {
80 if (std::get<1>(*it) == std::numeric_limits<double>::infinity())
81 v_alive.push_back(std::get<0>(*it));
82 else if (std::get<1>(*it) - std::get<0>(*it) > e)
83 v.push_back(Internal_point(std::get<0>(*it), std::get<1>(*it), v.size()));
84 }
85 if (u.size() < v.size())
86 swap(u, v);
87 std::sort(u_alive.begin(), u_alive.end());
88 std::sort(v_alive.begin(), v_alive.end());
89 if (u_alive.size() != v_alive.size()) {
90 b_alive = std::numeric_limits<double>::infinity();
91 } else {
92 for (auto it_u = u_alive.cbegin(), it_v = v_alive.cbegin(); it_u != u_alive.cend(); ++it_u, ++it_v)
93 b_alive = (std::max)(b_alive, std::fabs(*it_u - *it_v));
94 }
95}
96
97inline bool Persistence_graph::on_the_u_diagonal(int u_point_index) const {
98 return u_point_index >= static_cast<int> (u.size());
99}
100
101inline bool Persistence_graph::on_the_v_diagonal(int v_point_index) const {
102 return v_point_index >= static_cast<int> (v.size());
103}
104
105inline int Persistence_graph::corresponding_point_in_u(int v_point_index) const {
106 return on_the_v_diagonal(v_point_index) ?
107 v_point_index - static_cast<int> (v.size()) : v_point_index + static_cast<int> (u.size());
108}
109
110inline int Persistence_graph::corresponding_point_in_v(int u_point_index) const {
111 return on_the_u_diagonal(u_point_index) ?
112 u_point_index - static_cast<int> (u.size()) : u_point_index + static_cast<int> (v.size());
113}
114
115inline double Persistence_graph::distance(int u_point_index, int v_point_index) const {
116 if (on_the_u_diagonal(u_point_index) && on_the_v_diagonal(v_point_index))
117 return 0.;
118 Internal_point p_u = get_u_point(u_point_index);
119 Internal_point p_v = get_v_point(v_point_index);
120 return (std::max)(std::fabs(p_u.x() - p_v.x()), std::fabs(p_u.y() - p_v.y()));
121}
122
123inline int Persistence_graph::size() const {
124 return static_cast<int> (u.size() + v.size());
125}
126
127inline double Persistence_graph::bottleneck_alive() const {
128 return b_alive;
129}
130
131inline std::vector<double> Persistence_graph::sorted_distances() const {
132 std::vector<double> distances;
133 distances.push_back(0.); // for empty diagrams
134 for (int u_point_index = 0; u_point_index < size(); ++u_point_index) {
135 distances.push_back(distance(u_point_index, corresponding_point_in_v(u_point_index)));
136 for (int v_point_index = 0; v_point_index < size(); ++v_point_index)
137 distances.push_back(distance(u_point_index, v_point_index));
138 }
139#ifdef GUDHI_USE_TBB
140 tbb::parallel_sort(distances.begin(), distances.end());
141#else
142 std::sort(distances.begin(), distances.end());
143#endif
144 return distances;
145}
146
147inline Internal_point Persistence_graph::get_u_point(int u_point_index) const {
148 if (!on_the_u_diagonal(u_point_index))
149 return u.at(u_point_index);
150 Internal_point projector = v.at(corresponding_point_in_v(u_point_index));
151 double m = (projector.x() + projector.y()) / 2.;
152 return Internal_point(m, m, u_point_index);
153}
154
155inline Internal_point Persistence_graph::get_v_point(int v_point_index) const {
156 if (!on_the_v_diagonal(v_point_index))
157 return v.at(v_point_index);
158 Internal_point projector = u.at(corresponding_point_in_u(v_point_index));
159 double m = (projector.x() + projector.y()) / 2.;
160 return Internal_point(m, m, v_point_index);
161}
162
163inline double Persistence_graph::max_dist_to_diagonal() const {
164 double max = 0.;
165 for (auto& p : u)
166 max = (std::max)(max, p.y() - p.x());
167 for (auto& p : v)
168 max = (std::max)(max, p.y() - p.x());
169 return max / 2;
170}
171
172} // namespace persistence_diagram
173
174} // namespace Gudhi
175
176#endif // PERSISTENCE_GRAPH_H_
