Ordered_set_partition_iterator.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Siargey Kachanovich
4 *
5 * Copyright (C) 2019 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef PERMUTAHEDRAL_REPRESENTATION_ORDERED_SET_PARTITION_ITERATOR_H_
12#define PERMUTAHEDRAL_REPRESENTATION_ORDERED_SET_PARTITION_ITERATOR_H_
13
14#include <vector>
15#include <limits>
16
17#include <gudhi/Permutahedral_representation/Permutation_iterator.h>
18#include <gudhi/Permutahedral_representation/Set_partition_iterator.h>
19
20#include <boost/range/iterator_range.hpp>
21
22namespace Gudhi {
23
24namespace coxeter_triangulation {
25
26typedef unsigned uint;
27
35
36 // Ordered_set_partition(const Set_partition_iterator& s_it, const Permutation_iterator& p_it)
37 // : s_it_(s_it), p_it_(p_it) {}
38
39 const std::vector<uint> operator[](const uint& i) const { return (*s_it_)[(*p_it_)[i]]; }
40
41 std::size_t size() const { return s_it_->size(); }
42};
43
48 : public boost::iterator_facade<Ordered_set_partition_iterator, Ordered_set_partition const,
49 boost::forward_traversal_tag> {
51
52 private:
53 friend class boost::iterator_core_access;
54
55 bool equal(Ordered_set_partition_iterator const& other) const { return (is_end_ && other.is_end_); }
56
57 value_t const& dereference() const { return value_; }
58
59 void increment() {
60 if (++value_.p_it_ == p_end_) {
61 if (++value_.s_it_ == s_end_) {
62 is_end_ = true;
63 return;
64 } else
65 value_.p_it_.reinitialize();
66 }
67 }
68
69 public:
70 Ordered_set_partition_iterator(const uint& n, const uint& k)
71 : value_({Set_partition_iterator(n, k), Permutation_iterator(k)}), is_end_(n == 0) {}
72
73 // Used for the creating an end iterator
74 Ordered_set_partition_iterator() : is_end_(true) {}
75
76 void reinitialize() {
77 is_end_ = false;
78 value_.p_it_.reinitialize();
79 value_.s_it_.reinitialize();
80 }
81
82 private:
83 Set_partition_iterator s_end_; // Set partition iterator and the corresponding end iterator
84 Permutation_iterator p_end_; // Permutation iterator and the corresponding end iterator
85 value_t value_; // the dereference value
86 bool is_end_; // is true when the current permutation is the final one
87};
88
89} // namespace coxeter_triangulation
90
91} // namespace Gudhi
92
93#endif
Class that allows the user to generate set partitions of a set {0,...,n-1} in k parts.
Definition: Ordered_set_partition_iterator.h:49
Class that allows the user to generate permutations. Based on the optimization of the Heap's algorith...
Definition: Permutation_iterator.h:29
Definition: Set_partition_iterator.h:29
Class that represents an ordered set partition of a set {0,...,n-1} in k parts as a pair of an unorde...
Definition: Ordered_set_partition_iterator.h:32
