Neighbors_finder.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author: Francois Godi
4 *
5 * Copyright (C) 2015 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef NEIGHBORS_FINDER_H_
12#define NEIGHBORS_FINDER_H_
13
14// Inclusion order is important for CGAL patch
15#include <CGAL/Kd_tree.h>
16#include <CGAL/Search_traits.h>
17
18#include <gudhi/Persistence_graph.h>
19#include <gudhi/Internal_point.h>
20
21#include <unordered_set>
22#include <vector>
23#include <algorithm> // for std::max
24#include <cmath> // for std::abs
25
26namespace Gudhi {
27
28namespace persistence_diagram {
29
32struct Square_query {
33 typedef CGAL::Dimension_tag<2> D;
34 typedef Internal_point Point_d;
35 typedef double FT;
36 bool contains(Point_d p) const {
37 return (std::max)(std::abs(p.x()-c.x()), std::abs(p.y()-c.y())) <= size;
38 }
39 bool inner_range_intersects(CGAL::Kd_tree_rectangle<FT, D> const&r) const {
40 return
41 r.max_coord(0) >= c.x() - size &&
42 r.min_coord(0) <= c.x() + size &&
43 r.max_coord(1) >= c.y() - size &&
44 r.min_coord(1) <= c.y() + size;
45 }
46 bool outer_range_contains(CGAL::Kd_tree_rectangle<FT, D> const&r) const {
47 return
48 r.min_coord(0) >= c.x() - size &&
49 r.max_coord(0) <= c.x() + size &&
50 r.min_coord(1) >= c.y() - size &&
51 r.max_coord(1) <= c.y() + size;
52 }
53 Point_d c;
54 FT size;
55};
56
65class Neighbors_finder {
66 typedef CGAL::Dimension_tag<2> D;
67 typedef CGAL::Search_traits<double, Internal_point, const double*, Construct_coord_iterator, D> Traits;
68 typedef CGAL::Kd_tree<Traits> Kd_tree;
69
70 public:
72 Neighbors_finder(const Persistence_graph& g, double r);
74 void add(int v_point_index);
77 int pull_near(int u_point_index);
79 std::vector<int> pull_all_near(int u_point_index);
80
81 private:
82 const Persistence_graph& g;
83 const double r;
84 Kd_tree kd_t;
85 std::unordered_set<int> projections_f;
86};
87
96class Layered_neighbors_finder {
97 public:
99 Layered_neighbors_finder(const Persistence_graph& g, double r);
101 void add(int v_point_index, int vlayer);
104 int pull_near(int u_point_index, int vlayer);
106 int vlayers_number() const;
107
108 private:
109 const Persistence_graph& g;
110 const double r;
111 std::vector<std::unique_ptr<Neighbors_finder>> neighbors_finder;
112};
113
114inline Neighbors_finder::Neighbors_finder(const Persistence_graph& g, double r) :
115 g(g), r(r), kd_t(), projections_f() { }
116
117inline void Neighbors_finder::add(int v_point_index) {
118 if (g.on_the_v_diagonal(v_point_index))
119 projections_f.emplace(v_point_index);
120 else
121 kd_t.insert(g.get_v_point(v_point_index));
122}
123
124inline int Neighbors_finder::pull_near(int u_point_index) {
125 int tmp;
126 int c = g.corresponding_point_in_v(u_point_index);
127 if (g.on_the_u_diagonal(u_point_index) && !projections_f.empty()) {
128 // Any pair of projection is at distance 0
129 tmp = *projections_f.cbegin();
130 projections_f.erase(tmp);
131 } else if (projections_f.count(c) && (g.distance(u_point_index, c) <= r)) {
132 // Is the query point near to its projection ?
133 tmp = c;
134 projections_f.erase(tmp);
135 } else {
136 // Is the query point near to a V point in the plane ?
137 Internal_point u_point = g.get_u_point(u_point_index);
138 auto neighbor = kd_t.search_any_point(Square_query{u_point, r});
139 if (!neighbor)
140 return null_point_index();
141 tmp = neighbor->point_index;
142 auto point = g.get_v_point(tmp);
143 int idx = point.point_index;
144 kd_t.remove(point, [idx](Internal_point const&p){return p.point_index == idx;});
145 }
146 return tmp;
147}
148
149inline std::vector<int> Neighbors_finder::pull_all_near(int u_point_index) {
150 std::vector<int> all_pull;
151 int last_pull = pull_near(u_point_index);
152 while (last_pull != null_point_index()) {
153 all_pull.emplace_back(last_pull);
154 last_pull = pull_near(u_point_index);
155 }
156 return all_pull;
157}
158
159inline Layered_neighbors_finder::Layered_neighbors_finder(const Persistence_graph& g, double r) :
160 g(g), r(r), neighbors_finder() { }
161
162inline void Layered_neighbors_finder::add(int v_point_index, int vlayer) {
163 for (int l = neighbors_finder.size(); l <= vlayer; l++)
164 neighbors_finder.emplace_back(std::unique_ptr<Neighbors_finder>(new Neighbors_finder(g, r)));
165 neighbors_finder.at(vlayer)->add(v_point_index);
166}
167
168inline int Layered_neighbors_finder::pull_near(int u_point_index, int vlayer) {
169 if (static_cast<int> (neighbors_finder.size()) <= vlayer)
170 return null_point_index();
171 return neighbors_finder.at(vlayer)->pull_near(u_point_index);
172}
173
174inline int Layered_neighbors_finder::vlayers_number() const {
175 return static_cast<int> (neighbors_finder.size());
176}
177
178} // namespace persistence_diagram
179
180} // namespace Gudhi
181
182#endif // NEIGHBORS_FINDER_H_
