Integer_combination_iterator.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Siargey Kachanovich
4 *
5 * Copyright (C) 2019 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef PERMUTAHEDRAL_REPRESENTATION_INTEGER_COMBINATION_ITERATOR_H_
12#define PERMUTAHEDRAL_REPRESENTATION_INTEGER_COMBINATION_ITERATOR_H_
13
14#include <vector>
15#include <boost/range/iterator_range.hpp>
16
17namespace Gudhi {
18
19namespace coxeter_triangulation {
20
21typedef unsigned uint;
22
28 : public boost::iterator_facade<Integer_combination_iterator, std::vector<uint> const,
29 boost::forward_traversal_tag> {
30 using value_t = std::vector<uint>;
31
32 private:
33 friend class boost::iterator_core_access;
34
35 bool equal(Integer_combination_iterator const& other) const { return (is_end_ && other.is_end_); }
36
37 value_t const& dereference() const { return value_; }
38
39 void increment() {
40 uint j1 = 0;
41 uint s = 0;
42 while (value_[j1] == 0 && j1 < k_) j1++;
43 uint j2 = j1 + 1;
44 while (value_[j2] == bounds_[j2]) {
45 if (bounds_[j2] != 0) {
46 s += value_[j1];
47 value_[j1] = 0;
48 j1 = j2;
49 }
50 j2++;
51 }
52 if (j2 >= k_) {
53 is_end_ = true;
54 return;
55 }
56 s += value_[j1] - 1;
57 value_[j1] = 0;
58 value_[j2]++;
59 uint i = 0;
60 while (s >= bounds_[i]) {
61 value_[i] = bounds_[i];
62 s -= bounds_[i];
63 i++;
64 }
65 value_[i++] = s;
66 }
67
68 public:
69 template <class Bound_range>
70 Integer_combination_iterator(const uint& n, const uint& k, const Bound_range& bounds)
71 : value_(k + 2), is_end_(n == 0 || k == 0), n_(n), k_(k) {
72 bounds_.reserve(k + 2);
73 uint sum_radices = 0;
74 for (auto b : bounds) {
75 bounds_.push_back(b);
76 sum_radices += b;
77 }
78 bounds_.push_back(2);
79 bounds_.push_back(1);
80 if (n > sum_radices) {
81 is_end_ = true;
82 return;
83 }
84 uint i = 0;
85 uint s = n;
86 while (s >= bounds_[i]) {
87 value_[i] = bounds_[i];
88 s -= bounds_[i];
89 i++;
90 }
91 value_[i++] = s;
92
93 while (i < k_) value_[i++] = 0;
94 value_[k] = 1;
95 value_[k + 1] = 0;
96 }
97
98 // Used for the creating an end iterator
99 Integer_combination_iterator() : is_end_(true), n_(0), k_(0) {}
100
101 private:
102 value_t value_; // the dereference value
103 bool is_end_; // is true when the current integer combination is the final one
104
105 uint n_;
106 uint k_;
107 std::vector<uint> bounds_;
108};
109
110} // namespace coxeter_triangulation
111
112} // namespace Gudhi
113
114#endif
Class that allows the user to generate combinations of k elements in a set of n elements....
Definition: Integer_combination_iterator.h:29
