Graph_matching.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author: Francois Godi
4 *
5 * Copyright (C) 2015 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef GRAPH_MATCHING_H_
12#define GRAPH_MATCHING_H_
13
14#include <gudhi/Neighbors_finder.h>
15
16#include <vector>
17#include <unordered_set>
18#include <algorithm>
19
20namespace Gudhi {
21
22namespace persistence_diagram {
23
28class Graph_matching {
29 public:
31 explicit Graph_matching(Persistence_graph &g);
33 bool perfect() const;
35 bool multi_augment();
37 void set_r(double r);
38
39 private:
40 Persistence_graph* gp;
41 double r;
43 std::vector<int> v_to_u;
45 std::unordered_set<int> unmatched_in_u;
46
48 Layered_neighbors_finder layering() const;
50 bool augment(Layered_neighbors_finder & layered_nf, int u_start_index, int max_depth);
52 void update(std::vector<int> & path);
53};
54
55inline Graph_matching::Graph_matching(Persistence_graph& g)
56 : gp(&g), r(0.), v_to_u(g.size(), null_point_index()), unmatched_in_u(g.size()) {
57 for (int u_point_index = 0; u_point_index < g.size(); ++u_point_index)
58 unmatched_in_u.insert(u_point_index);
59}
60
61inline bool Graph_matching::perfect() const {
62 return unmatched_in_u.empty();
63}
64
65inline bool Graph_matching::multi_augment() {
66 if (perfect())
67 return false;
68 Layered_neighbors_finder layered_nf(layering());
69 int max_depth = layered_nf.vlayers_number()*2 - 1;
70 double rn = sqrt(gp->size());
71 // verification of a necessary criterion in order to shortcut if possible
72 if (max_depth < 0 || (unmatched_in_u.size() > rn && max_depth >= rn))
73 return false;
74 bool successful = false;
75 std::vector<int> tries(unmatched_in_u.cbegin(), unmatched_in_u.cend());
76 for (auto it = tries.cbegin(); it != tries.cend(); it++)
77 // 'augment' has side-effects which have to be always executed, don't change order
78 successful = augment(layered_nf, *it, max_depth) || successful;
79 return successful;
80}
81
82inline void Graph_matching::set_r(double r) {
83 this->r = r;
84}
85
86inline bool Graph_matching::augment(Layered_neighbors_finder & layered_nf, int u_start_index, int max_depth) {
87 // V vertices have at most one successor, thus when we backtrack from U we can directly pop_back 2 vertices.
88 std::vector<int> path;
89 path.emplace_back(u_start_index);
90 do {
91 if (static_cast<int> (path.size()) > max_depth) {
92 path.pop_back();
93 path.pop_back();
94 }
95 if (path.empty())
96 return false;
97 path.emplace_back(layered_nf.pull_near(path.back(), static_cast<int> (path.size()) / 2));
98 while (path.back() == null_point_index()) {
99 path.pop_back();
100 path.pop_back();
101 if (path.empty())
102 return false;
103 path.pop_back();
104 path.emplace_back(layered_nf.pull_near(path.back(), path.size() / 2));
105 }
106 path.emplace_back(v_to_u.at(path.back()));
107 } while (path.back() != null_point_index());
108 // if v_to_u.at(path.back()) has no successor, path.back() is an exposed vertex
109 path.pop_back();
110 update(path);
111 return true;
112}
113
114inline Layered_neighbors_finder Graph_matching::layering() const {
115 std::vector<int> u_vertices(unmatched_in_u.cbegin(), unmatched_in_u.cend());
116 std::vector<int> v_vertices;
117 Neighbors_finder nf(*gp, r);
118 for (int v_point_index = 0; v_point_index < gp->size(); ++v_point_index)
119 nf.add(v_point_index);
120 Layered_neighbors_finder layered_nf(*gp, r);
121 for (int layer = 0; !u_vertices.empty(); layer++) {
122 // one layer is one step in the BFS
123 for (auto it1 = u_vertices.cbegin(); it1 != u_vertices.cend(); ++it1) {
124 std::vector<int> u_succ(nf.pull_all_near(*it1));
125 for (auto it2 = u_succ.begin(); it2 != u_succ.end(); ++it2) {
126 layered_nf.add(*it2, layer);
127 v_vertices.emplace_back(*it2);
128 }
129 }
130 // When the above for finishes, we have progress of one half-step (from U to V) in the BFS
131 u_vertices.clear();
132 bool end = false;
133 for (auto it = v_vertices.cbegin(); it != v_vertices.cend(); it++)
134 if (v_to_u.at(*it) == null_point_index())
135 // we stop when a nearest exposed V vertex (from U exposed vertices) has been found
136 end = true;
137 else
138 u_vertices.emplace_back(v_to_u.at(*it));
139 // When the above for finishes, we have progress of one half-step (from V to U) in the BFS
140 if (end)
141 return layered_nf;
142 v_vertices.clear();
143 }
144 return layered_nf;
145}
146
147inline void Graph_matching::update(std::vector<int>& path) {
148 // Must return 1.
149 unmatched_in_u.erase(path.front());
150 for (auto it = path.cbegin(); it != path.cend(); ++it) {
151 // Be careful, the iterator is incremented twice each time
152 int tmp = *it;
153 v_to_u[*(++it)] = tmp;
154 }
155}
156
157
158} // namespace persistence_diagram
159
160} // namespace Gudhi
161
162#endif // GRAPH_MATCHING_H_
