Function_torus_in_R3.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Siargey Kachanovich
4 *
5 * Copyright (C) 2019 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef FUNCTIONS_FUNCTION_TORUS_IN_R3_H_
12#define FUNCTIONS_FUNCTION_TORUS_IN_R3_H_
13
14#include <cstdlib> // for std::size_t
15#include <cmath> // for std::sqrt
16
17#include <Eigen/Dense>
18
19namespace Gudhi {
20
21namespace coxeter_triangulation {
22
33 Eigen::VectorXd operator()(const Eigen::VectorXd& p) const {
34 double x = p(0) - off_[0], y = p(1) - off_[1], z = p(2) - off_[2];
35 Eigen::VectorXd result(cod_d());
36 result(0) = (z * z + (std::sqrt(x * x + y * y) - r_) * (std::sqrt(x * x + y * y) - r_) - R_ * R_);
37 return result;
38 }
39
41 std::size_t amb_d() const { return 3; };
42
44 std::size_t cod_d() const { return 1; };
45
47 Eigen::VectorXd seed() const {
48 Eigen::Vector3d result(R_ + r_ + off_[0], off_[1], off_[2]);
49 return result;
50 }
51
59 Function_torus_in_R3(double R = 1, double r = 0.5, Eigen::Vector3d off = Eigen::Vector3d::Zero())
60 : R_(R), r_(r), off_(off) {}
61
62 private:
63 double R_, r_;
64 Eigen::Vector3d off_;
65};
66
67} // namespace coxeter_triangulation
68
69} // namespace Gudhi
70
71#endif
A class that encodes the function, the zero-set of which is a torus surface embedded in R^3.
Definition: Function_torus_in_R3.h:28
Returns the domain (ambient) dimension.
Definition: Function_torus_in_R3.h:41
Function_torus_in_R3(double R=1, double r=0.5, Eigen::Vector3d off=Eigen::Vector3d::Zero())
Constructor of the function that defines a torus embedded in R^3.
Definition: Function_torus_in_R3.h:59
Returns the codomain dimension.
Definition: Function_torus_in_R3.h:44
Returns a point on the surface.
Definition: Function_torus_in_R3.h:47
Eigen::VectorXd operator()(const Eigen::VectorXd &p) const
Value of the function at a specified point.
Definition: Function_torus_in_R3.h:33
