All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Field_Zp.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Clément Maria
4 *
5 * Copyright (C) 2014 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef PERSISTENT_COHOMOLOGY_FIELD_ZP_H_
12#define PERSISTENT_COHOMOLOGY_FIELD_ZP_H_
13
14#include <utility>
15#include <vector>
16#include <stdexcept>
17
18namespace Gudhi {
19
20namespace persistent_cohomology {
21
27class Field_Zp {
28 public:
29 typedef int Element;
30
31 Field_Zp()
32 : Prime(0),
33 inverse_() {
34 }
35
36 void init(int charac) {
37 Prime = charac;
38
39 // Check that the provided prime is less than the maximum allowed as int, calculation below, and 'plus_times_equal' function : 46337 ; i.e (max_prime-1)*max_prime <= INT_MAX
40 if(Prime > 46337)
41 throw std::invalid_argument("Maximum homology_coeff_field allowed value is 46337");
42
43 // Check for primality
44 if (Prime <= 1)
45 throw std::invalid_argument("homology_coeff_field must be a prime number");
46
47 inverse_.clear();
48 inverse_.reserve(charac);
49 inverse_.push_back(0);
50 for (int i = 1; i < Prime; ++i) {
51 int inv = 1;
52 int mult = inv * i;
53 while ( (mult % Prime) != 1) {
54 ++inv;
55 if(mult == Prime)
56 throw std::invalid_argument("homology_coeff_field must be a prime number");
57 mult = inv * i;
58 }
59 inverse_.push_back(inv);
60 }
61 }
62
64 Element plus_times_equal(const Element& x, const Element& y, const Element& w) {
65 assert(Prime > 0); // division by zero + non negative values
66 Element result = (x + w * y) % Prime;
67 if (result < 0)
68 result += Prime;
69 return result;
70 }
71
72// operator= defined on Element
73
75 Element times(const Element& y, const Element& w) {
76 return plus_times_equal(0, y, (Element)w);
77 }
78
79 Element plus_equal(const Element& x, const Element& y) {
80 return plus_times_equal(x, y, (Element)1);
81 }
82
84 Element additive_identity() const {
85 return 0;
86 }
88 Element multiplicative_identity(Element = 0) const {
89 return 1;
90 }
92 std::pair<Element, Element> inverse(Element x, Element P) {
93 return std::pair<Element, Element>(inverse_[x], P);
94 } // <------ return the product of field characteristic for which x is invertible
95
97 Element times_minus(Element x, Element y) {
98 assert(Prime > 0); // division by zero + non negative values
99 Element out = (-x * y) % Prime;
100 return (out < 0) ? out + Prime : out;
101 }
102
104 int characteristic() const {
105 return Prime;
106 }
107
108 private:
109 int Prime;
111 std::vector<Element> inverse_;
112};
113
114} // namespace persistent_cohomology
115
116} // namespace Gudhi
117
118#endif // PERSISTENT_COHOMOLOGY_FIELD_ZP_H_
Structure representing the coefficient field .
Definition: Field_Zp.h:27
Definition: Field_Zp.h:97
Element plus_times_equal(const Element &x, const Element &y, const Element &w)
Definition: Field_Zp.h:64
Returns the additive idendity of the field.
Definition: Field_Zp.h:84
std::pair< Element, Element > inverse(Element x, Element P)
Definition: Field_Zp.h:92
Element multiplicative_identity(Element=0) const
Returns the multiplicative identity of the field.
Definition: Field_Zp.h:88
Element times(const Element &y, const Element &w)
Definition: Field_Zp.h:75
Returns the characteristic of the field.
Definition: Field_Zp.h:104
