Contraction_visitor.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): David Salinas
4 *
5 * Copyright (C) 2014 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef CONTRACTION_POLICIES_CONTRACTION_VISITOR_H_
12#define CONTRACTION_POLICIES_CONTRACTION_VISITOR_H_
13
14#include <gudhi/Contraction/Edge_profile.h>
15#include <boost/optional.hpp>
16
17namespace Gudhi {
18
19namespace contraction {
20
26template <typename EdgeProfile>
27class Contraction_visitor { // : public Dummy_complex_visitor<typename EdgeProfile::Vertex_handle> {
28 public:
29 // typedef typename ComplexType::GeometryTrait GT;
30 typedef EdgeProfile Profile;
31 typedef double FT;
32 typedef typename Profile::Complex Complex;
33 typedef Complex ComplexType;
34 typedef typename ComplexType::Point Point;
35
36 virtual ~Contraction_visitor() { }
37
41 virtual void on_started(ComplexType & complex) { }
42
46 virtual void on_stop_condition_reached() { }
47
51 virtual void on_collected(const Profile &profile, boost::optional< FT > cost) { }
52
56 virtual void on_selected(const Profile &profile, boost::optional< FT > cost, int initial_count, int current_count) { }
57
61 virtual void on_contracting(const Profile &profile, boost::optional< Point > placement) { }
62
67 virtual void on_contracted(const Profile &profile, boost::optional< Point > placement) { }
68
72 virtual void on_non_valid(const Profile &profile) { }
73};
74
75} // namespace contraction
76
77} // namespace Gudhi
78
79#endif // CONTRACTION_POLICIES_CONTRACTION_VISITOR_H_
Interface for a visitor of the edge contraction process.
Definition: Contraction_visitor.h:27
Called when the algorithm stops.
Definition: Contraction_visitor.h:46
Called when after an edge has been contracted onto a new point placement. A possibility would to remo...
Definition: Contraction_visitor.h:67
virtual void on_started(ComplexType &complex)
Called before the edge contraction process starts.
Definition: Contraction_visitor.h:41
Called when an edge is about to be contracted and replaced by a vertex whose position is *placement.
Definition: Contraction_visitor.h:61
Called for each selected edge which cannot be contracted because the ValidContractionPredicate is fal...
Definition: Contraction_visitor.h:72
Called during the processing phase (when edges are contracted), for each edge that is selected.
Definition: Contraction_visitor.h:56
Called during the collecting phase (when a cost is assigned to the edges), for each edge collected.
Definition: Contraction_visitor.h:51
