Combination_iterator.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Siargey Kachanovich
4 *
5 * Copyright (C) 2019 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef PERMUTAHEDRAL_REPRESENTATION_COMBINATION_ITERATOR_H_
12#define PERMUTAHEDRAL_REPRESENTATION_COMBINATION_ITERATOR_H_
13
14#include <vector>
15#include <boost/range/iterator_range.hpp>
16
17namespace Gudhi {
18
19namespace coxeter_triangulation {
20
21typedef unsigned uint;
22
28 : public boost::iterator_facade<Combination_iterator, std::vector<uint> const, boost::forward_traversal_tag> {
29 typedef std::vector<uint> value_t;
30
31 protected:
32 friend class boost::iterator_core_access;
33
34 bool equal(Combination_iterator const& other) const { return (is_end_ && other.is_end_); }
35
36 value_t const& dereference() const { return value_; }
37
38 void increment() {
39 if (value_[0] == n_ - k_) {
40 is_end_ = true;
41 return;
42 }
43 uint j = k_ - 1;
44 if (value_[j] < n_ - 1) {
45 value_[j]++;
46 return;
47 }
48 for (; j > 0; --j)
49 if (value_[j - 1] < n_ - k_ + j - 1) {
50 value_[j - 1]++;
51 for (uint s = j; s < k_; s++) value_[s] = value_[j - 1] + s - (j - 1);
52 return;
53 }
54 }
55
56 public:
57 Combination_iterator(const uint& n, const uint& k) : value_(k), is_end_(n == 0), n_(n), k_(k) {
58 for (uint i = 0; i < k; ++i) value_[i] = i;
59 }
60
61 // Used for the creating an end iterator
62 Combination_iterator() : is_end_(true), n_(0), k_(0) {}
63
64 void reinitialize() {
65 if (n_ > 0) {
66 is_end_ = false;
67 for (uint i = 0; i < n_; ++i) value_[i] = i;
68 }
69 }
70
71 private:
72 value_t value_; // the dereference value
73 bool is_end_; // is true when the current permutation is the final one
74
75 uint n_;
76 uint k_;
77};
78
79} // namespace coxeter_triangulation
80
81} // namespace Gudhi
82
83#endif
Class that allows the user to generate combinations of k elements in a set of n elements....
Definition: Combination_iterator.h:28
