Cech_complex_blocker.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Vincent Rouvreau
4 *
5 * Copyright (C) 2018 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef CECH_COMPLEX_BLOCKER_H_
12#define CECH_COMPLEX_BLOCKER_H_
13
14#include <CGAL/NT_converter.h> // for casting from FT to Filtration_value
15#include <CGAL/Lazy_exact_nt.h> // for CGAL::exact
16
17#include <iostream>
18#include <vector>
19#include <set>
20#include <cmath> // for std::sqrt
21
22namespace Gudhi {
23
24namespace cech_complex {
25
42template <typename SimplicialComplexForCech, typename Cech_complex, typename Kernel>
43class Cech_blocker {
44
45 public:
46
47 using Point_d = typename Kernel::Point_d;
48 // Numeric type of coordinates in the kernel
49 using FT = typename Kernel::FT;
50 // Sphere is a pair of point and squared radius.
51 using Sphere = typename std::pair<Point_d, FT>;
52
53 private:
54
55 using Simplex_handle = typename SimplicialComplexForCech::Simplex_handle;
57 using Simplex_key = typename SimplicialComplexForCech::Simplex_key;
58
59 template<class PointIterator>
60 Sphere get_sphere(PointIterator begin, PointIterator end) const {
61 Point_d c = kernel_.construct_circumcenter_d_object()(begin, end);
62 FT r = kernel_.squared_distance_d_object()(c, *begin);
63 return std::make_pair(std::move(c), std::move(r));
64 }
65
66 public:
67
72 bool operator()(Simplex_handle sh) {
73 using Point_cloud = std::vector<Point_d>;
74 Filtration_value radius = 0;
75 bool is_min_enclos_ball = false;
76 Point_cloud points;
77 points.reserve(sc_ptr_->dimension(sh)+1);
78
79 // for each face of simplex sh, test outsider point is indeed inside enclosing ball, if yes, take it and exit loop, otherwise, new sphere is circumsphere of all vertices
80 for (auto face_opposite_vertex : sc_ptr_->boundary_opposite_vertex_simplex_range(sh)) {
81 auto k = sc_ptr_->key(face_opposite_vertex.first);
82 Simplex_key sph_key;
83 if(k != sc_ptr_->null_key()) {
84 sph_key = k;
85 }
86 else {
87 for (auto vertex : sc_ptr_->simplex_vertex_range(face_opposite_vertex.first)) {
88 points.push_back(cc_ptr_->get_point(vertex));
89#ifdef DEBUG_TRACES
90 std::clog << "#(" << vertex << ")#";
91#endif // DEBUG_TRACES
92 }
93 // Put edge sphere in cache
94 sph_key = cc_ptr_->get_cache().size();
95 sc_ptr_->assign_key(face_opposite_vertex.first, sph_key);
96 cc_ptr_->get_cache().push_back(get_sphere(points.cbegin(), points.cend()));
97 // Clear face points
98 points.clear();
99 }
100 // Check if the minimal enclosing ball of current face contains the extra point/opposite vertex
101 Sphere const& sph = cc_ptr_->get_cache()[sph_key];
102 if (kernel_.squared_distance_d_object()(sph.first, cc_ptr_->get_point(face_opposite_vertex.second)) <= sph.second) {
103 is_min_enclos_ball = true;
104 sc_ptr_->assign_key(sh, sph_key);
105 radius = sc_ptr_->filtration(face_opposite_vertex.first);
106#ifdef DEBUG_TRACES
107 std::clog << "center: " << sph.first << ", radius: " << radius << std::endl;
108#endif // DEBUG_TRACES
109 break;
110 }
111 }
112 // Spheres of each face don't contain the whole simplex
113 if(!is_min_enclos_ball) {
114 for (auto vertex : sc_ptr_->simplex_vertex_range(sh)) {
115 points.push_back(cc_ptr_->get_point(vertex));
116 }
117 Sphere sph = get_sphere(points.cbegin(), points.cend());
118#if CGAL_VERSION_NR >= 1050000000
119 if(cc_ptr_->is_exact()) CGAL::exact(sph.second);
120#endif
121 CGAL::NT_converter<FT, Filtration_value> cast_to_fv;
122 radius = std::sqrt(cast_to_fv(sph.second));
123
124 sc_ptr_->assign_key(sh, cc_ptr_->get_cache().size());
125 cc_ptr_->get_cache().push_back(std::move(sph));
126 }
127
128#ifdef DEBUG_TRACES
129 if (radius > cc_ptr_->max_radius()) std::clog << "radius > max_radius => expansion is blocked\n";
130#endif // DEBUG_TRACES
131 // Check that the filtration to be assigned (radius) would be valid
132 if (radius > sc_ptr_->filtration(sh)) sc_ptr_->assign_filtration(sh, radius);
133 return (radius > cc_ptr_->max_radius());
134 }
135
137 Cech_blocker(SimplicialComplexForCech* sc_ptr, Cech_complex* cc_ptr) : sc_ptr_(sc_ptr), cc_ptr_(cc_ptr) {}
138
139 private:
140 SimplicialComplexForCech* sc_ptr_;
141 Cech_complex* cc_ptr_;
142 Kernel kernel_;
143};
144
145} // namespace cech_complex
146
147} // namespace Gudhi
148
149#endif // CECH_COMPLEX_BLOCKER_H_
Cech complex class.
Definition: Cech_complex.h:43
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
unspecified Filtration_value
Definition: SimplicialComplexForCech.h:27
unspecified Simplex_handle
Definition: SimplicialComplexForCech.h:23
