Alpha_kernel_d.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Vincent Rouvreau
4 *
5 * Copyright (C) 2020 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef ALPHA_COMPLEX_ALPHA_KERNEL_D_H_
12#define ALPHA_COMPLEX_ALPHA_KERNEL_D_H_
13
14#include <CGAL/version.h> // for CGAL_VERSION_NR
15
16#include <Eigen/Core> // for EIGEN_VERSION_AT_LEAST
17
18#include <utility> // for std::make_pair
19
20// Make compilation fail - required for external projects - https://github.com/GUDHI/gudhi-devel/issues/10
21#if CGAL_VERSION_NR < 1041101000
22# error Alpha_complex is only available for CGAL >= 4.11
23#endif
24
25#if !EIGEN_VERSION_AT_LEAST(3,1,0)
26# error Alpha_complex is only available for Eigen3 >= 3.1.0 installed with CGAL
27#endif
28
29namespace Gudhi {
30
31namespace alpha_complex {
32
41template < typename Kernel, bool Weighted = false >
43};
44
45// Unweighted Kernel_d version
46template < typename Kernel >
47class Alpha_kernel_d<Kernel, false> {
48 private:
49 // Kernel for functions access.
50 Kernel kernel_;
51 public:
52 // Fake type for compilation to succeed (cf. std::conditional in Alpha_complex.h)
53 using Weighted_point_d = void;
54 using Point_d = typename Kernel::Point_d;
55 // Numeric type of coordinates in the kernel
56 using FT = typename Kernel::FT;
57 // Sphere is a pair of point and squared radius.
58 using Sphere = typename std::pair<Point_d, FT>;
59
60 int get_dimension(const Point_d& p0) const {
61 return kernel_.point_dimension_d_object()(p0);
62 }
63
64 template<class PointIterator>
65 Sphere get_sphere(PointIterator begin, PointIterator end) const {
66 Point_d c = kernel_.construct_circumcenter_d_object()(begin, end);
67 FT r = kernel_.squared_distance_d_object()(c, *begin);
68 return std::make_pair(std::move(c), std::move(r));
69 }
70
71 template<class PointIterator>
72 FT get_squared_radius(PointIterator begin, PointIterator end) const {
73 return kernel_.compute_squared_radius_d_object()(begin, end);
74 }
75
76 FT get_squared_radius(const Sphere& sph) const {
77 return sph.second;
78 }
79
80 bool is_gabriel(const Sphere& circumcenter, const Point_d& point) {
81 return kernel_.squared_distance_d_object()(circumcenter.first, point) >= circumcenter.second;
82 }
83};
84
85// Weighted Kernel_d version
86template < typename Kernel >
87class Alpha_kernel_d<Kernel, true> {
88 private:
89 // Kernel for functions access.
90 Kernel kernel_;
91
92 public:
93 // Fake type for compilation to succeed (cf. std::conditional in Alpha_complex.h)
94 using Point_d = void;
95 using Weighted_point_d = typename Kernel::Weighted_point_d;
96 using Bare_point_d = typename Kernel::Point_d;
97 // Numeric type of coordinates in the kernel
98 using FT = typename Kernel::FT;
99 // Sphere is a weighted point (point + weight [= squared radius]).
100 using Sphere = Weighted_point_d;
101
102 int get_dimension(const Weighted_point_d& p0) const {
103 return kernel_.point_dimension_d_object()(p0.point());
104 }
105
106 template<class PointIterator>
107 Sphere get_sphere(PointIterator begin, PointIterator end) const {
108 // power_center_d_object has been renamed between CGAL 5.1 and 5.2
109#if CGAL_VERSION_NR < 1050200000
110 return kernel_.power_center_d_object()(begin, end);
111#else
112 return kernel_.construct_power_sphere_d_object()(begin, end);
113#endif
114 }
115
116 template<class PointIterator>
117 FT get_squared_radius(PointIterator begin, PointIterator end) const {
118 return kernel_.compute_squared_radius_smallest_orthogonal_sphere_d_object()(begin, end);
119 }
120
121 FT get_squared_radius(const Sphere& sph) const {
122 return sph.weight();
123 }
124
125 bool is_gabriel(const Sphere& circumcenter, const Weighted_point_d& point) {
126 // power_center_d_object has been renamed between CGAL 5.1 and 5.2
127#if CGAL_VERSION_NR < 1050200000
128 return kernel_.power_distance_d_object()(circumcenter, point) >= 0;
129#else
130 return kernel_.compute_power_product_d_object()(circumcenter, point) >= 0;
131#endif
132 }
133};
134
135} // namespace alpha_complex
136
137namespace alphacomplex = alpha_complex;
138
139} // namespace Gudhi
140
141#endif // ALPHA_COMPLEX_ALPHA_KERNEL_D_H_
Alpha complex kernel container.
Definition: Alpha_kernel_d.h:42
