All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Alpha_complex.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Vincent Rouvreau
4 *
5 * Copyright (C) 2015 Inria
6 *
7 * Modification(s):
8 * - 2019/08 Vincent Rouvreau: Fix issue #10 for CGAL and Eigen3
9 * - YYYY/MM Author: Description of the modification
10 */
11
12#ifndef ALPHA_COMPLEX_H_
13#define ALPHA_COMPLEX_H_
14
15#include <gudhi/Alpha_complex/Alpha_kernel_d.h>
16#include <gudhi/Debug_utils.h>
17// to construct Alpha_complex from a OFF file of points
18#include <gudhi/Points_off_io.h>
19
20#include <stdlib.h>
21#include <math.h> // isnan, fmax
22#include <memory> // for std::unique_ptr
23#include <cstddef> // for std::size_t
24
25#include <CGAL/Delaunay_triangulation.h>
26#include <CGAL/Regular_triangulation.h> // aka. Weighted Delaunay triangulation
27#include <CGAL/Epeck_d.h> // For EXACT or SAFE version
28#include <CGAL/Epick_d.h> // For FAST version
29#include <CGAL/Spatial_sort_traits_adapter_d.h>
30#include <CGAL/property_map.h> // for CGAL::Identity_property_map
31#include <CGAL/version.h> // for CGAL_VERSION_NR
32#include <CGAL/NT_converter.h>
33
34#include <Eigen/src/Core/util/Macros.h> // for EIGEN_VERSION_AT_LEAST
35
36#include <boost/range/size.hpp>
37#include <boost/range/combine.hpp>
38#include <boost/range/adaptor/transformed.hpp>
39
40#include <iostream>
41#include <vector>
42#include <string>
43#include <limits> // NaN
44#include <map>
45#include <utility> // std::pair
46#include <stdexcept>
47#include <numeric> // for std::iota
48
49// Make compilation fail - required for external projects - https://github.com/GUDHI/gudhi-devel/issues/10
50#if CGAL_VERSION_NR < 1041101000
51# error Alpha_complex is only available for CGAL >= 4.11
52#endif
53
54#if !EIGEN_VERSION_AT_LEAST(3,1,0)
55# error Alpha_complex is only available for Eigen3 >= 3.1.0 installed with CGAL
56#endif
57
58namespace Gudhi {
59
60namespace alpha_complex {
61
62template<typename D> struct Is_Epeck_D { static const bool value = false; };
63template<typename D> struct Is_Epeck_D<CGAL::Epeck_d<D>> { static const bool value = true; };
64
102template<class Kernel = CGAL::Epeck_d<CGAL::Dynamic_dimension_tag>, bool Weighted = false>
104 public:
106 using Geom_traits = std::conditional_t<Weighted, CGAL::Regular_triangulation_traits_adapter<Kernel>, Kernel>;
107
108 // Add an int in TDS to save point index in the structure
109 using TDS = CGAL::Triangulation_data_structure<typename Geom_traits::Dimension,
110 CGAL::Triangulation_vertex<Geom_traits, std::ptrdiff_t>,
111 CGAL::Triangulation_full_cell<Geom_traits> >;
112
114 using Triangulation = std::conditional_t<Weighted, CGAL::Regular_triangulation<Kernel, TDS>,
115 CGAL::Delaunay_triangulation<Kernel, TDS>>;
116
119
120 // Numeric type of coordinates in the kernel
121 using FT = typename A_kernel_d::FT;
122
126 using Sphere = typename A_kernel_d::Sphere;
127
129 using Point_d = typename Geom_traits::Point_d;
130
131 private:
132 // Vertex_iterator type from CGAL.
133 using CGAL_vertex_iterator = typename Triangulation::Vertex_iterator;
134
135 // size_type type from CGAL.
136 using size_type = typename Triangulation::size_type;
137
138 // Structure to switch from simplex tree vertex handle to CGAL vertex iterator.
139 using Vector_vertex_iterator = std::vector< CGAL_vertex_iterator >;
140
141 private:
144 Vector_vertex_iterator vertex_handle_to_iterator_;
146 std::unique_ptr<Triangulation> triangulation_;
148 A_kernel_d kernel_;
149
151 std::vector<Sphere> cache_, old_cache_;
152
153 public:
163 Alpha_complex(const std::string& off_file_name) {
164 Gudhi::Points_off_reader<Point_d> off_reader(off_file_name);
165 if (!off_reader.is_valid()) {
166 std::cerr << "Alpha_complex - Unable to read file " << off_file_name << "\n";
167 exit(-1); // ----- >>
168 }
169
170 init_from_range(off_reader.get_point_cloud());
171 }
172
183 template<typename InputPointRange >
184 Alpha_complex(const InputPointRange& points) {
185 init_from_range(points);
186 }
187
200 template <typename InputPointRange, typename WeightRange>
201 Alpha_complex(const InputPointRange& points, WeightRange weights) {
202 static_assert(Weighted, "This constructor is not available for non-weighted versions of Alpha_complex");
203 // FIXME: this test is only valid if we have a forward range
204 GUDHI_CHECK(boost::size(weights) == boost::size(points),
205 std::invalid_argument("Points number in range different from weights range number"));
206 auto weighted_points = boost::range::combine(points, weights)
207 | boost::adaptors::transformed([](auto const&t){return Point_d(boost::get<0>(t), boost::get<1>(t));});
208 init_from_range(weighted_points);
209 }
210
211 // Forbid copy/move constructor/assignment operator
212 Alpha_complex(const Alpha_complex& other) = delete;
213 Alpha_complex& operator= (const Alpha_complex& other) = delete;
214 Alpha_complex (Alpha_complex&& other) = delete;
215 Alpha_complex& operator= (Alpha_complex&& other) = delete;
216
219 std::size_t num_vertices() const {
220 if (triangulation_ == nullptr)
221 return 0;
222 else
223 return triangulation_->number_of_vertices();
224 }
225
232 const Point_d& get_point(std::size_t vertex) const {
233 return vertex_handle_to_iterator_.at(vertex)->point();
234 }
235
236 private:
237 template<typename InputPointRange >
238 void init_from_range(const InputPointRange& points) {
239 #if CGAL_VERSION_NR < 1050000000
240 if (Is_Epeck_D<Kernel>::value)
241 std::cerr << "It is strongly advised to use a CGAL version >= 5.0 with Epeck_d Kernel for performance reasons."
242 << std::endl;
243 #endif
244
245#if CGAL_VERSION_NR < 1050101000
246 // Make compilation fail if weighted and CGAL < 5.1
247 static_assert(!Weighted, "Weighted Alpha_complex is only available for CGAL >= 5.1");
248#endif
249
250 auto first = std::begin(points);
251 auto last = std::end(points);
252
253 if (first != last) {
254 // Delaunay triangulation init with point dimension.
255 triangulation_ = std::make_unique<Triangulation>(kernel_.get_dimension(*first));
256
257 std::vector<Point_d> point_cloud(first, last);
258
259 // Creates a vector {0, 1, ..., N-1}
260 std::vector<std::ptrdiff_t> indices(boost::counting_iterator<std::ptrdiff_t>(0),
261 boost::counting_iterator<std::ptrdiff_t>(point_cloud.size()));
262
263 using Point_property_map = boost::iterator_property_map<typename std::vector<Point_d>::iterator,
264 CGAL::Identity_property_map<std::ptrdiff_t>>;
265 using Search_traits_d = CGAL::Spatial_sort_traits_adapter_d<Geom_traits, Point_property_map>;
266
267 CGAL::spatial_sort(indices.begin(), indices.end(), Search_traits_d(std::begin(point_cloud)));
268
269 typename Triangulation::Full_cell_handle hint;
270 for (auto index : indices) {
271 typename Triangulation::Vertex_handle pos = triangulation_->insert(point_cloud[index], hint);
272 if (pos != nullptr) {
273 // Save index value as data to retrieve it after insertion
274 pos->data() = index;
275 hint = pos->full_cell();
276 }
277 }
278 // --------------------------------------------------------------------------------------------
279 // structure to retrieve CGAL points from vertex handle - one vertex handle per point.
280 // Needs to be constructed before as vertex handles arrives in no particular order.
281 vertex_handle_to_iterator_.resize(point_cloud.size());
282 // Loop on triangulation vertices list
283 for (CGAL_vertex_iterator vit = triangulation_->vertices_begin(); vit != triangulation_->vertices_end(); ++vit) {
284 if (!triangulation_->is_infinite(*vit)) {
285#ifdef DEBUG_TRACES
286 std::clog << "Vertex insertion - " << vit->data() << " -> " << vit->point() << std::endl;
287#endif // DEBUG_TRACES
288 vertex_handle_to_iterator_[vit->data()] = vit;
289 }
290 }
291 // --------------------------------------------------------------------------------------------
292 }
293 }
294
301 const Point_d& get_point_(std::size_t vertex) const {
302 return vertex_handle_to_iterator_[vertex]->point();
303 }
304
306 template<class SimplicialComplexForAlpha>
307 auto& get_cache(SimplicialComplexForAlpha& cplx, typename SimplicialComplexForAlpha::Simplex_handle s) {
308 auto k = cplx.key(s);
309 if(k==cplx.null_key()){
310 k = cache_.size();
311 cplx.assign_key(s, k);
312 // Using a transform_range is slower, currently.
313 thread_local std::vector<Point_d> v;
314 v.clear();
315 for (auto vertex : cplx.simplex_vertex_range(s))
316 v.push_back(get_point_(vertex));
317 cache_.emplace_back(kernel_.get_sphere(v.cbegin(), v.cend()));
318 }
319 return cache_[k];
320 }
321
323 template<class SimplicialComplexForAlpha>
324 auto radius(SimplicialComplexForAlpha& cplx, typename SimplicialComplexForAlpha::Simplex_handle s) {
325 auto k = cplx.key(s);
326 if(k!=cplx.null_key())
327 return kernel_.get_squared_radius(old_cache_[k]);
328 // Using a transform_range is slower, currently.
329 thread_local std::vector<Point_d> v;
330 v.clear();
331 for (auto vertex : cplx.simplex_vertex_range(s))
332 v.push_back(get_point_(vertex));
333 return kernel_.get_squared_radius(v.cbegin(), v.cend());
334 }
335
336 public:
360 template <typename SimplicialComplexForAlpha,
363 Filtration_value max_alpha_square = std::numeric_limits<Filtration_value>::infinity(),
364 bool exact = false,
365 bool default_filtration_value = false) {
366 // From SimplicialComplexForAlpha type required to insert into a simplicial complex (with or without subfaces).
368 using Simplex_handle = typename SimplicialComplexForAlpha::Simplex_handle;
369 using Vector_vertex = std::vector<Vertex_handle>;
370
371 if (triangulation_ == nullptr) {
372 std::cerr << "Alpha_complex cannot create_complex from a NULL triangulation\n";
373 return false; // ----- >>
374 }
375 if (triangulation_->maximal_dimension() < 1) {
376 std::cerr << "Alpha_complex cannot create_complex from a zero-dimension triangulation\n";
377 return false; // ----- >>
378 }
379 if (complex.num_vertices() > 0) {
380 std::cerr << "Alpha_complex create_complex - complex is not empty\n";
381 return false; // ----- >>
382 }
383
384 // --------------------------------------------------------------------------------------------
385 // Simplex_tree construction from loop on triangulation finite full cells list
386 if (num_vertices() > 0) {
387 for (auto cit = triangulation_->finite_full_cells_begin();
388 cit != triangulation_->finite_full_cells_end();
389 ++cit) {
390 Vector_vertex vertexVector;
391#ifdef DEBUG_TRACES
392 std::clog << "Simplex_tree insertion ";
393#endif // DEBUG_TRACES
394 for (auto vit = cit->vertices_begin(); vit != cit->vertices_end(); ++vit) {
395 if (*vit != nullptr) {
396#ifdef DEBUG_TRACES
397 std::clog << " " << (*vit)->data();
398#endif // DEBUG_TRACES
399 // Vector of vertex construction for simplex_tree structure
400 vertexVector.push_back((*vit)->data());
401 }
402 }
403#ifdef DEBUG_TRACES
404 std::clog << std::endl;
405#endif // DEBUG_TRACES
406 // Insert each simplex and its subfaces in the simplex tree - filtration is NaN
407 complex.insert_simplex_and_subfaces(vertexVector, std::numeric_limits<double>::quiet_NaN());
408 }
409 }
410 // --------------------------------------------------------------------------------------------
411
412 if (!default_filtration_value) {
413 CGAL::NT_converter<FT, Filtration_value> cgal_converter;
414 // --------------------------------------------------------------------------------------------
415 // ### For i : d -> 0
416 for (int decr_dim = triangulation_->maximal_dimension(); decr_dim >= 0; decr_dim--) {
417 // ### Foreach Sigma of dim i
418 for (Simplex_handle f_simplex : complex.skeleton_simplex_range(decr_dim)) {
419 int f_simplex_dim = complex.dimension(f_simplex);
420 if (decr_dim == f_simplex_dim) {
421 // ### If filt(Sigma) is NaN : filt(Sigma) = alpha(Sigma)
422 if (std::isnan(complex.filtration(f_simplex))) {
423 Filtration_value alpha_complex_filtration = 0.0;
424 // No need to compute squared_radius on a non-weighted single point - alpha is 0.0
425 if (Weighted || f_simplex_dim > 0) {
426 auto const& sqrad = radius(complex, f_simplex);
427#if CGAL_VERSION_NR >= 1050000000
428 if(exact) CGAL::exact(sqrad);
429#endif
430 alpha_complex_filtration = cgal_converter(sqrad);
431 }
432 complex.assign_filtration(f_simplex, alpha_complex_filtration);
433#ifdef DEBUG_TRACES
434 std::clog << "filt(Sigma) is NaN : filt(Sigma) =" << complex.filtration(f_simplex) << std::endl;
435#endif // DEBUG_TRACES
436 }
437 // No need to propagate further, unweighted points all have value 0
438 if (decr_dim > !Weighted)
439 propagate_alpha_filtration(complex, f_simplex);
440 }
441 }
442 old_cache_ = std::move(cache_);
443 cache_.clear();
444 }
445 // --------------------------------------------------------------------------------------------
446
447 // --------------------------------------------------------------------------------------------
448 if (!exact)
449 // As Alpha value is an approximation, we have to make filtration non decreasing while increasing the dimension
450 // Only in not exact version, cf. https://github.com/GUDHI/gudhi-devel/issues/57
452 // Remove all simplices that have a filtration value greater than max_alpha_square
453 complex.prune_above_filtration(max_alpha_square);
454 // --------------------------------------------------------------------------------------------
455 }
456 return true;
457 }
458
459 private:
460 template <typename SimplicialComplexForAlpha, typename Simplex_handle>
461 void propagate_alpha_filtration(SimplicialComplexForAlpha& complex, Simplex_handle f_simplex) {
462 // From SimplicialComplexForAlpha type required to assign filtration values.
464
465 // ### Foreach Tau face of Sigma
466 for (auto face_opposite_vertex : complex.boundary_opposite_vertex_simplex_range(f_simplex)) {
467 auto f_boundary = face_opposite_vertex.first;
468#ifdef DEBUG_TRACES
469 std::clog << " | --------------------------------------------------\n";
470 std::clog << " | Tau ";
471 for (auto vertex : complex.simplex_vertex_range(f_boundary)) {
472 std::clog << vertex << " ";
473 }
474 std::clog << "is a face of Sigma\n";
475 std::clog << " | isnan(complex.filtration(Tau)=" << std::isnan(complex.filtration(f_boundary)) << std::endl;
476#endif // DEBUG_TRACES
477 // ### If filt(Tau) is not NaN
478 if (!std::isnan(complex.filtration(f_boundary))) {
479 // ### filt(Tau) = fmin(filt(Tau), filt(Sigma))
480 Filtration_value alpha_complex_filtration = fmin(complex.filtration(f_boundary),
481 complex.filtration(f_simplex));
482 complex.assign_filtration(f_boundary, alpha_complex_filtration);
483#ifdef DEBUG_TRACES
484 std::clog << " | filt(Tau) = fmin(filt(Tau), filt(Sigma)) = " << complex.filtration(f_boundary) << std::endl;
485#endif // DEBUG_TRACES
486 // ### Else
487 } else {
488 auto const& cache=get_cache(complex, f_boundary);
489 bool is_gab = kernel_.is_gabriel(cache, get_point_(face_opposite_vertex.second));
490#ifdef DEBUG_TRACES
491 std::clog << " | Tau is_gabriel(Sigma)=" << is_gab << " - vertexForGabriel=" << face_opposite_vertex.second << std::endl;
492#endif // DEBUG_TRACES
493 // ### If Tau is not Gabriel of Sigma
494 if (false == is_gab) {
495 // ### filt(Tau) = filt(Sigma)
496 Filtration_value alpha_complex_filtration = complex.filtration(f_simplex);
497 complex.assign_filtration(f_boundary, alpha_complex_filtration);
498#ifdef DEBUG_TRACES
499 std::clog << " | filt(Tau) = filt(Sigma) = " << complex.filtration(f_boundary) << std::endl;
500#endif // DEBUG_TRACES
501 }
502 }
503 }
504 }
505};
506
507} // namespace alpha_complex
508
509namespace alphacomplex = alpha_complex;
510
511} // namespace Gudhi
512
513#endif // ALPHA_COMPLEX_H_
OFF file reader implementation in order to read points from an OFF file.
Definition: Points_off_io.h:122
const std::vector< Point_d > & get_point_cloud() const
Point cloud getter.
Definition: Points_off_io.h:158
bool is_valid() const
Returns if the OFF file read operation was successful or not.
Definition: Points_off_io.h:150
Alpha complex data structure.
Definition: Alpha_complex.h:103
bool create_complex(SimplicialComplexForAlpha &complex, Filtration_value max_alpha_square=std::numeric_limits< Filtration_value >::infinity(), bool exact=false, bool default_filtration_value=false)
Inserts all Delaunay triangulation into the simplicial complex. It also computes the filtration value...
Definition: Alpha_complex.h:362
std::conditional_t< Weighted, CGAL::Regular_triangulation< Kernel, TDS >, CGAL::Delaunay_triangulation< Kernel, TDS > > Triangulation
A (Weighted or not) Delaunay triangulation of a set of points in .
Definition: Alpha_complex.h:115
typename A_kernel_d::Sphere Sphere
Sphere is a std::pair<Kernel::Point_d, Kernel::FT> (aka. circurmcenter and squared radius)....
Definition: Alpha_complex.h:126
Alpha_complex(const InputPointRange &points, WeightRange weights)
Alpha_complex constructor from a list of points and weights.
Definition: Alpha_complex.h:201
std::conditional_t< Weighted, CGAL::Regular_triangulation_traits_adapter< Kernel >, Kernel > Geom_traits
Geometric traits class that provides the geometric types and predicates needed by the triangulations.
Definition: Alpha_complex.h:106
const Point_d & get_point(std::size_t vertex) const
get_point returns the point corresponding to the vertex given as parameter.
Definition: Alpha_complex.h:232
Alpha_complex(const std::string &off_file_name)
Alpha_complex constructor from an OFF file name.
Definition: Alpha_complex.h:163
typename Geom_traits::Point_d Point_d
A point, or a weighted point in Euclidean space.
Definition: Alpha_complex.h:129
Returns the number of finite vertices in the triangulation.
Definition: Alpha_complex.h:219
Alpha_complex(const InputPointRange &points)
Alpha_complex constructor from a list of points.
Definition: Alpha_complex.h:184
Alpha complex kernel container.
Definition: Alpha_kernel_d.h:42
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
The concept SimplicialComplexForAlpha describes the requirements for a type to implement a simplicial...
Definition: SimplicialComplexForAlpha.h:21
Skeleton_simplex_range skeleton_simplex_range
Returns a range over the simplices of the skeleton of the simplicial complex, for a given dimension.
Definition: SimplicialComplexForAlpha.h:70
int assign_filtration(Simplex_handle simplex, Filtration_value filtration)
void prune_above_filtration(Filtration_value filtration)
Simplex_vertex_range simplex_vertex_range(Simplex_handle const &simplex)
Returns a range over vertices of a given simplex.
void insert_simplex_and_subfaces(std::vector< Vertex_handle > const &vertex_range, Filtration_value filtration)
Inserts a simplex with vertices from a given simplex (represented by a vector of Vertex_handle) in th...
unspecified Simplex_handle
Definition: SimplicialComplexForAlpha.h:23
unspecified Vertex_handle
Definition: SimplicialComplexForAlpha.h:25
unspecified Filtration_value
Definition: SimplicialComplexForAlpha.h:27
Handle type for the vertices of a cell complex.
Definition: VertexHandle.h:15
