writing_persistence_to_file.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Pawel Dlotko
4 *
5 * Copyright (C) 2017 Swansea University, UK
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef WRITING_PERSISTENCE_TO_FILE_H_
12#define WRITING_PERSISTENCE_TO_FILE_H_
13
14#include <iostream>
15#include <string>
16#include <limits>
17
18namespace Gudhi {
19
25template <typename Filtration_type, typename Coefficient_field>
27 public:
31 Persistence_interval_common(Filtration_type birth, Filtration_type death)
32 : birth_(birth),
33 death_(death),
34 dimension_(std::numeric_limits<unsigned>::max()),
35 arith_element_(std::numeric_limits<Coefficient_field>::max()) {}
36
40 Persistence_interval_common(Filtration_type birth, Filtration_type death, unsigned dim)
41 : birth_(birth), death_(death), dimension_(dim), arith_element_(std::numeric_limits<Coefficient_field>::max()) {}
42
47 Persistence_interval_common(Filtration_type birth, Filtration_type death, unsigned dim, Coefficient_field field)
48 : birth_(birth), death_(death), dimension_(dim), arith_element_(field) {}
49
56 return ((this->birth_ == i2.birth_) && (this->death_ == i2.death_) && (this->dimension_ == i2.dimension_) &&
57 (this->arith_element_ == i2.arith_element_));
58 }
59
63 bool operator!=(const Persistence_interval_common& i2) const { return (!((*this) == i2)); }
64
70 bool operator<(const Persistence_interval_common& i2) const {
71 return fabs(this->death_ - this->birth_) < fabs(i2.death_ - i2.birth_);
72 }
73
74 friend std::ostream& operator<<(std::ostream& out, const Persistence_interval_common& it) {
75 if (it.arith_element_ != std::numeric_limits<Coefficient_field>::max()) {
76 out << it.arith_element_ << " ";
77 }
78 if (it.dimension_ != std::numeric_limits<unsigned>::max()) {
79 out << it.dimension_ << " ";
80 }
81 out << it.birth_ << " " << it.death_ << " ";
82 return out;
83 }
84
85 private:
86 Filtration_type birth_;
87 Filtration_type death_;
88 unsigned dimension_;
89 Coefficient_field arith_element_;
90};
91
95template <typename Persistence_interval_range>
96void write_persistence_intervals_to_stream(const Persistence_interval_range& intervals,
97 std::ostream& out = std::cout) {
98 for (auto interval : intervals) {
99 out << interval << "\n";
100 }
101}
102
103} // namespace Gudhi
104
105#endif // WRITING_PERSISTENCE_TO_FILE_H_
Definition: writing_persistence_to_file.h:26
bool operator==(const Persistence_interval_common &i2) const
Definition: writing_persistence_to_file.h:55
bool operator!=(const Persistence_interval_common &i2) const
Definition: writing_persistence_to_file.h:63
bool operator<(const Persistence_interval_common &i2) const
Definition: writing_persistence_to_file.h:70
Definition: writing_persistence_to_file.h:31
Definition: writing_persistence_to_file.h:40
Definition: writing_persistence_to_file.h:47
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
