Loading [MathJax]/extensions/tex2jax.js
All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
simple_simplex_tree.cpp
/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
* See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
* Author(s): Vincent Rouvreau
* Copyright (C) 2014 Inria
* Modification(s):
* - YYYY/MM Author: Description of the modification
#include <gudhi/Simplex_tree.h>
#include <iostream>
#include <utility> // for pair
#include <vector>
using Vertex_handle = Simplex_tree::Vertex_handle;
using typeVectorVertex = std::vector<Vertex_handle>;
using typePairSimplexBool = std::pair<Simplex_tree::Simplex_handle, bool>;
int main(int argc, char* const argv[]) {
const Filtration_value FIRST_FILTRATION_VALUE = 0.1;
const Filtration_value SECOND_FILTRATION_VALUE = 0.2;
const Filtration_value THIRD_FILTRATION_VALUE = 0.3;
const Filtration_value FOURTH_FILTRATION_VALUE = 0.4;
// TEST OF INSERTION
std::clog << "********************************************************************" << std::endl;
std::clog << "EXAMPLE OF SIMPLE INSERTION" << std::endl;
// Construct the Simplex Tree
Simplex_tree simplexTree;
/* Simplex to be inserted: */
/* 1 */
/* o */
/* /X\ */
/* o---o---o */
/* 2 0 3 */
// ++ FIRST
std::clog << " * INSERT 0" << std::endl;
typeVectorVertex firstSimplexVector = {0};
typePairSimplexBool returnValue =
simplexTree.insert_simplex(firstSimplexVector, Filtration_value(FIRST_FILTRATION_VALUE));
if (returnValue.second == true) {
std::clog << " + 0 INSERTED" << std::endl;
} else {
std::clog << " - 0 NOT INSERTED" << std::endl;
// ++ SECOND
std::clog << " * INSERT 1" << std::endl;
typeVectorVertex secondSimplexVector = {1};
returnValue = simplexTree.insert_simplex(secondSimplexVector, Filtration_value(FIRST_FILTRATION_VALUE));
std::clog << " + 1 INSERTED" << std::endl;
} else {
std::clog << " - 1 NOT INSERTED" << std::endl;
// ++ THIRD
std::clog << " * INSERT (0,1)" << std::endl;
typeVectorVertex thirdSimplexVector = {0, 1};
returnValue = simplexTree.insert_simplex(thirdSimplexVector, Filtration_value(SECOND_FILTRATION_VALUE));
std::clog << " + (0,1) INSERTED" << std::endl;
} else {
std::clog << " - (0,1) NOT INSERTED" << std::endl;
// ++ FOURTH
std::clog << " * INSERT 2" << std::endl;
typeVectorVertex fourthSimplexVector = {2};
returnValue = simplexTree.insert_simplex(fourthSimplexVector, Filtration_value(FIRST_FILTRATION_VALUE));
std::clog << " + 2 INSERTED" << std::endl;
} else {
std::clog << " - 2 NOT INSERTED" << std::endl;
// ++ FIFTH
std::clog << " * INSERT (2,0)" << std::endl;
typeVectorVertex fifthSimplexVector = {2, 0};
returnValue = simplexTree.insert_simplex(fifthSimplexVector, Filtration_value(SECOND_FILTRATION_VALUE));
std::clog << " + (2,0) INSERTED" << std::endl;
} else {
std::clog << " - (2,0) NOT INSERTED" << std::endl;
// ++ SIXTH
std::clog << " * INSERT (2,1)" << std::endl;
typeVectorVertex sixthSimplexVector = {2, 1};
returnValue = simplexTree.insert_simplex(sixthSimplexVector, Filtration_value(SECOND_FILTRATION_VALUE));
std::clog << " + (2,1) INSERTED" << std::endl;
} else {
std::clog << " - (2,1) NOT INSERTED" << std::endl;
// ++ SEVENTH
std::clog << " * INSERT (2,1,0)" << std::endl;
typeVectorVertex seventhSimplexVector = {2, 1, 0};
returnValue = simplexTree.insert_simplex(seventhSimplexVector, Filtration_value(THIRD_FILTRATION_VALUE));
std::clog << " + (2,1,0) INSERTED" << std::endl;
} else {
std::clog << " - (2,1,0) NOT INSERTED" << std::endl;
// ++ EIGHTH
std::clog << " * INSERT 3" << std::endl;
typeVectorVertex eighthSimplexVector = {3};
returnValue = simplexTree.insert_simplex(eighthSimplexVector, Filtration_value(FIRST_FILTRATION_VALUE));
std::clog << " + 3 INSERTED" << std::endl;
} else {
std::clog << " - 3 NOT INSERTED" << std::endl;
// ++ NINETH
std::clog << " * INSERT (3,0)" << std::endl;
typeVectorVertex ninethSimplexVector = {3, 0};
returnValue = simplexTree.insert_simplex(ninethSimplexVector, Filtration_value(SECOND_FILTRATION_VALUE));
std::clog << " + (3,0) INSERTED" << std::endl;
} else {
std::clog << " - (3,0) NOT INSERTED" << std::endl;
// ++ TENTH
std::clog << " * INSERT 0 (already inserted)" << std::endl;
typeVectorVertex tenthSimplexVector = {0};
// With a different filtration value
returnValue = simplexTree.insert_simplex(tenthSimplexVector, Filtration_value(FOURTH_FILTRATION_VALUE));
} else {
// ++ ELEVENTH
std::clog << " * INSERT (2,1,0) (already inserted)" << std::endl;
typeVectorVertex eleventhSimplexVector = {2, 1, 0};
returnValue = simplexTree.insert_simplex(eleventhSimplexVector, Filtration_value(FOURTH_FILTRATION_VALUE));
} else {
// ++ GENERAL VARIABLE SET
std::clog << "********************************************************************\n";
std::clog << "* The complex contains " << simplexTree.num_simplices() << " simplices\n";
std::clog << " - dimension " << simplexTree.dimension() << "\n";
std::clog << "* Iterator on Simplices in the filtration, with [filtration value]:\n";
for (auto f_simplex : simplexTree.filtration_simplex_range()) {
std::clog << " "
<< "[" << simplexTree.filtration(f_simplex) << "] ";
for (auto vertex : simplexTree.simplex_vertex_range(f_simplex)) std::clog << "(" << vertex << ")";
std::clog << std::endl;
// [0.1] 0
// [0.1] 1
// [0.1] 2
// [0.1] 3
// [0.2] 1 0
// [0.2] 2 0
// [0.2] 2 1
// [0.2] 3 0
// [0.3] 2 1 0
// Find in the simplex_tree
Simplex_tree::Simplex_handle simplexFound = simplexTree.find(secondSimplexVector);
std::clog << "**************IS THE SIMPLEX {1} IN THE SIMPLEX TREE ?\n";
if (simplexFound != simplexTree.null_simplex())
std::clog << "***+ YES IT IS!\n";
else
std::clog << "***- NO IT ISN'T\n";
typeVectorVertex unknownSimplexVector = {15};
simplexFound = simplexTree.find(unknownSimplexVector);
std::clog << "**************IS THE SIMPLEX {15} IN THE SIMPLEX TREE ?\n";
else
simplexFound = simplexTree.find(fifthSimplexVector);
std::clog << "**************IS THE SIMPLEX {2,0} IN THE SIMPLEX TREE ?\n";
else
typeVectorVertex otherSimplexVector = {1, 15};
simplexFound = simplexTree.find(otherSimplexVector);
std::clog << "**************IS THE SIMPLEX {15,1} IN THE SIMPLEX TREE ?\n";
else
typeVectorVertex invSimplexVector = {1, 2, 0};
simplexFound = simplexTree.find(invSimplexVector);
std::clog << "**************IS THE SIMPLEX {1,2,0} IN THE SIMPLEX TREE ?\n";
else
simplexFound = simplexTree.find({0, 1});
std::clog << "**************IS THE SIMPLEX {0,1} IN THE SIMPLEX TREE ?\n";
else
std::clog << "**************COFACES OF {0,1} IN CODIMENSION 1 ARE\n";
for (auto& simplex : simplexTree.cofaces_simplex_range(simplexTree.find({0, 1}), 1)) {
for (auto vertex : simplexTree.simplex_vertex_range(simplex)) std::clog << "(" << vertex << ")";
std::clog << "**************STARS OF {0,1} ARE\n";
for (auto& simplex : simplexTree.star_simplex_range(simplexTree.find({0, 1}))) {
std::clog << "**************BOUNDARIES OF {0,1,2} ARE\n";
for (auto& simplex : simplexTree.boundary_simplex_range(simplexTree.find({0, 1, 2}))) {
return 0;
Options::Filtration_value Filtration_value
Type for the value of the filtration function.
Definition: Simplex_tree.h:82
Cofaces_simplex_range cofaces_simplex_range(const Simplex_handle simplex, int codimension)
Compute the cofaces of a n simplex.
Definition: Simplex_tree.h:993
Dictionary::iterator Simplex_handle
Handle type to a simplex contained in the simplicial complex represented by the simplex tree.
Definition: Simplex_tree.h:149
Filtration_simplex_range const & filtration_simplex_range(Indexing_tag=Indexing_tag())
Returns a range over the simplices of the simplicial complex, in the order of the filtration.
Definition: Simplex_tree.h:262
std::pair< Simplex_handle, bool > insert_simplex(const InputVertexRange &simplex, Filtration_value filtration=0)
Insert a simplex, represented by a range of Vertex_handles, in the simplicial complex.
Definition: Simplex_tree.h:752
Simplex_vertex_range simplex_vertex_range(Simplex_handle sh) const
Returns a range over the vertices of a simplex.
Definition: Simplex_tree.h:273
static Filtration_value filtration(Simplex_handle sh)
Returns the filtration value of a simplex.
Definition: Simplex_tree.h:509
Cofaces_simplex_range star_simplex_range(const Simplex_handle simplex)
Compute the star of a n simplex.
Definition: Simplex_tree.h:982
Simplex_handle find(const InputVertexRange &s)
Given a range of Vertex_handles, returns the Simplex_handle of the simplex in the simplicial complex ...
Definition: Simplex_tree.h:615
Options::Vertex_handle Vertex_handle
Type for the vertex handle.
Definition: Simplex_tree.h:90
Boundary_simplex_range boundary_simplex_range(SimplexHandle sh)
Returns a range over the simplices of the boundary of a simplex.
Definition: Simplex_tree.h:294
int dimension(Simplex_handle sh)
Returns the dimension of a simplex.
Definition: Simplex_tree.h:574
size_t num_simplices()
returns the number of simplices in the simplex_tree.
Definition: Simplex_tree.h:552
static Simplex_handle null_simplex()
Returns a Simplex_handle different from all Simplex_handles associated to the simplices in the simpli...
Definition: Simplex_tree.h:530
Graph simplicial complex methods.
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
