reader_utils.h
Go to the documentation of this file.
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Clement Maria, Pawel Dlotko, Clement Jamin
4 *
5 * Copyright (C) 2014 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef READER_UTILS_H_
12#define READER_UTILS_H_
13
15#include <gudhi/Debug_utils.h>
16
17#if BOOST_VERSION < 106600
18# include <boost/function_output_iterator.hpp>
19#else
20# include <boost/iterator/function_output_iterator.hpp>
21#endif
22#include <boost/graph/adjacency_list.hpp>
23
24#include <iostream>
25#include <fstream>
26#include <map>
27#include <limits> // for numeric_limits
28#include <string>
29#include <vector>
30#include <utility> // for pair
31#include <tuple> // for std::make_tuple
32
33namespace Gudhi {
34
35// Keep this file tag for Doxygen to parse the code, otherwise, functions are not documented.
36// It is required for global functions and variables.
37
50inline void read_points(std::string file_name, std::vector<std::vector<double>>& points) {
51 std::ifstream in_file(file_name.c_str(), std::ios::in);
52 if (!in_file.is_open()) {
53 std::cerr << "Unable to open file " << file_name << std::endl;
54 return;
55 }
56
57 std::string line;
58 double x;
59 while (getline(in_file, line)) {
60 std::vector<double> point;
61 std::istringstream iss(line);
62 while (iss >> x) {
63 point.push_back(x);
64 }
65 // Check for empty lines
66 if (!point.empty()) points.push_back(point);
67 }
68 in_file.close();
69}
70
87template <typename Graph_t, typename Filtration_value, typename Vertex_handle>
88Graph_t read_graph(std::string file_name) {
89 std::ifstream in_(file_name.c_str(), std::ios::in);
90 if (!in_.is_open()) {
91 std::string error_str("read_graph - Unable to open file ");
92 error_str.append(file_name);
93 std::cerr << error_str << std::endl;
94 throw std::invalid_argument(error_str);
95 }
96
97 typedef std::pair<Vertex_handle, Vertex_handle> Edge_t;
98 std::vector<Edge_t> edges;
99 std::vector<Filtration_value> edges_fil;
100 std::map<Vertex_handle, Filtration_value> vertices;
101
102 std::string line;
103 int dim;
104 Vertex_handle u, v, max_h = -1;
106 while (getline(in_, line)) {
107 std::istringstream iss(line);
108 while (iss >> dim) {
109 switch (dim) {
110 case 0: {
111 iss >> u;
112 iss >> fil;
113 vertices[u] = fil;
114 if (max_h < u) {
115 max_h = u;
116 }
117 break;
118 }
119 case 1: {
120 iss >> u;
121 iss >> v;
122 iss >> fil;
123 edges.push_back(Edge_t(u, v));
124 edges_fil.push_back(fil);
125 break;
126 }
127 default: { break; }
128 }
129 }
130 }
131 in_.close();
132
133 if ((size_t)(max_h + 1) != vertices.size()) {
134 std::cerr << "Error: vertices must be labeled from 0 to n-1 \n";
135 }
136
137 Graph_t skel_graph(edges.begin(), edges.end(), edges_fil.begin(), vertices.size());
138 auto vertex_prop = boost::get(vertex_filtration_t(), skel_graph);
139
140 typename boost::graph_traits<Graph_t>::vertex_iterator vi, vi_end;
141 auto v_it = vertices.begin();
142 for (std::tie(vi, vi_end) = boost::vertices(skel_graph); vi != vi_end; ++vi, ++v_it) {
143 boost::put(vertex_prop, *vi, v_it->second);
144 }
145
146 return skel_graph;
147}
148
161template <typename Vertex_handle, typename Filtration_value>
162bool read_simplex(std::istream& in_, std::vector<Vertex_handle>& simplex, Filtration_value& fil) {
163 int dim = 0;
164 if (!(in_ >> dim)) return false;
165 Vertex_handle v;
166 for (int i = 0; i < dim + 1; ++i) {
167 if (!(in_ >> v)) return false;
168 simplex.push_back(v);
169 }
170 if (!(in_ >> fil)) return false;
171 in_.ignore((std::numeric_limits<std::streamsize>::max)(), '\n'); // ignore until the carriage return
172 return true;
173}
174
186template <typename Simplex_key, typename Filtration_value>
187bool read_hasse_simplex(std::istream& in_, std::vector<Simplex_key>& boundary, Filtration_value& fil) {
188 int dim;
189 if (!(in_ >> dim)) return false;
190 if (dim == 0) {
191 in_ >> fil;
192 return true;
193 }
194 Simplex_key key;
195 for (int i = 0; i < dim + 1; ++i) {
196 in_ >> key;
197 boundary.push_back(key);
198 }
199 in_ >> fil;
200 return true;
201}
202
223template <typename Filtration_value>
224std::vector<std::vector<Filtration_value>> read_lower_triangular_matrix_from_csv_file(const std::string& filename,
225 const char separator = ';') {
226#ifdef DEBUG_TRACES
227 std::clog << "Using procedure read_lower_triangular_matrix_from_csv_file \n";
228#endif // DEBUG_TRACES
229 std::vector<std::vector<Filtration_value>> result;
230 std::ifstream in;
231 in.open(filename.c_str());
232 if (!in.is_open()) {
233 return result;
234 }
235
236 std::string line;
237
238 // the first line is emtpy, so we ignore it:
239 std::getline(in, line);
240 std::vector<Filtration_value> values_in_this_line;
241 result.push_back(values_in_this_line);
242
243 int number_of_line = 0;
244
245 // first, read the file line by line to a string:
246 while (std::getline(in, line)) {
247 // if line is empty, break
248 if (line.size() == 0) break;
249
250 // if the last element of a string is comma:
251 if (line[line.size() - 1] == separator) {
252 // then shrink the string by one
253 line.pop_back();
254 }
255
256 // replace all commas with spaces
257 std::replace(line.begin(), line.end(), separator, ' ');
258
259 // put the new line to a stream
260 std::istringstream iss(line);
261 // and now read the doubles.
262
263 int number_of_entry = 0;
264 std::vector<Filtration_value> values_in_this_line;
265 while (iss.good()) {
266 double entry;
267 iss >> entry;
268 if (number_of_entry <= number_of_line) {
269 values_in_this_line.push_back(entry);
270 }
271 ++number_of_entry;
272 }
273 if (!values_in_this_line.empty()) result.push_back(values_in_this_line);
274 ++number_of_line;
275 }
276 in.close();
277
278#ifdef DEBUG_TRACES
279 std::clog << "Here is the matrix we read : \n";
280 for (size_t i = 0; i != result.size(); ++i) {
281 for (size_t j = 0; j != result[i].size(); ++j) {
282 std::clog << result[i][j] << " ";
283 }
284 std::clog << std::endl;
285 }
286#endif // DEBUG_TRACES
287
288 return result;
289} // read_lower_triangular_matrix_from_csv_file
290
298template <typename OutputIterator>
299void read_persistence_intervals_and_dimension(std::string const& filename, OutputIterator out) {
300#ifdef DEBUG_TRACES
301 std::clog << "read_persistence_intervals_and_dimension - " << filename << std::endl;
302#endif // DEBUG_TRACES
303 std::ifstream in(filename);
304 if (!in.is_open()) {
305 std::string error_str("read_persistence_intervals_and_dimension - Unable to open file ");
306 error_str.append(filename);
307 std::cerr << error_str << std::endl;
308 throw std::invalid_argument(error_str);
309 }
310
311 while (!in.eof()) {
312 std::string line;
313 getline(in, line);
314 if (line.length() != 0 && line[0] != '#') {
315 double numbers[4];
316 int n = sscanf(line.c_str(), "%lf %lf %lf %lf", &numbers[0], &numbers[1], &numbers[2], &numbers[3]);
317#ifdef DEBUG_TRACES
318 std::clog << "[" << n << "] = ";
319 for (int i = 0; i < n; i++) {
320 std::clog << numbers[i] << ",";
321 }
322 std::clog << std::endl;
323#endif // DEBUG_TRACES
324 if (n >= 2) {
325 int dim = (n >= 3 ? static_cast<int>(numbers[n - 3]) : -1);
326 *out++ = std::make_tuple(dim, numbers[n - 2], numbers[n - 1]);
327 }
328 }
329 }
330}
331
339inline std::map<int, std::vector<std::pair<double, double>>> read_persistence_intervals_grouped_by_dimension(
340 std::string const& filename) {
341 std::map<int, std::vector<std::pair<double, double>>> ret;
343 filename, boost::make_function_output_iterator([&ret](std::tuple<int, double, double> t) {
344 ret[get<0>(t)].push_back(std::make_pair(get<1>(t), get<2>(t)));
345 }));
346 return ret;
347}
348
359inline std::vector<std::pair<double, double>> read_persistence_intervals_in_dimension(std::string const& filename,
360 int only_this_dim = -1) {
361 std::vector<std::pair<double, double>> ret;
363 filename, boost::make_function_output_iterator([only_this_dim, &ret](std::tuple<int, double, double> t) {
364 if (only_this_dim == get<0>(t) || only_this_dim == -1) ret.emplace_back(get<1>(t), get<2>(t));
365 }));
366 return ret;
367}
368
369} // namespace Gudhi
370
371#endif // READER_UTILS_H_
Graph simplicial complex methods.
bool read_hasse_simplex(std::istream &in_, std::vector< Simplex_key > &boundary, Filtration_value &fil)
Read a hasse simplex from a file.
Definition: reader_utils.h:187
Read a graph from a file.
Definition: reader_utils.h:88
std::vector< std::pair< double, double > > read_persistence_intervals_in_dimension(std::string const &filename, int only_this_dim=-1)
Definition: reader_utils.h:359
void read_persistence_intervals_and_dimension(std::string const &filename, OutputIterator out)
Definition: reader_utils.h:299
bool read_simplex(std::istream &in_, std::vector< Vertex_handle > &simplex, Filtration_value &fil)
Read a face from a file.
Definition: reader_utils.h:162
std::vector< std::vector< Filtration_value > > read_lower_triangular_matrix_from_csv_file(const std::string &filename, const char separator=';')
Read a lower triangular distance matrix from a csv file. We assume that the .csv store the whole (squ...
Definition: reader_utils.h:224
void read_points(std::string file_name, std::vector< std::vector< double > > &points)
Read a set of points to turn it into a vector< vector<double> > by filling points.
Definition: reader_utils.h:50
std::map< int, std::vector< std::pair< double, double > > > read_persistence_intervals_grouped_by_dimension(std::string const &filename)
Definition: reader_utils.h:339
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
