persistence_vectors/plot_persistence_vectors.cpp
/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
* See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
* Author(s): Pawel Dlotko
* Copyright (C) 2016 Inria
* Modification(s):
* - YYYY/MM Author: Description of the modification
#include <gudhi/Persistence_vectors.h>
#include <iostream>
#include <sstream>
int main(int argc, char** argv) {
std::clog << "This program create a Gnuplot script to plot persistence vector. Please call this program with the "
"name of file with persistence vector. \n";
if (argc != 2) {
std::clog << "Wrong number of parameters, the program will now terminate. \n";
return 1;
l.load_from_file(argv[1]);
l.plot(argv[1]);
return 0;
Compute the Euclidean distance between two Points given by a range of coordinates....
Definition: distance_functions.h:34
A class implementing persistence vectors.
Definition: Persistence_vectors.h:54
void plot(const char *filename) const
Definition: Persistence_vectors.h:178
void load_from_file(const char *filename)
Definition: Persistence_vectors.h:599
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
