persistence_intervals/compute_birth_death_range_in_persistence_diagram.cpp
/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
* See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
* Author(s): Pawel Dlotko
* Copyright (C) 2016 Inria
* Modification(s):
* - YYYY/MM Author: Description of the modification
#include <gudhi/Persistence_intervals.h>
#include <iostream>
#include <vector>
#include <limits>
#include <utility>
int main(int argc, char** argv) {
std::clog << "This program computes the range of birth and death times of persistence pairs in diagrams provided as "
<< "an input.\n"
<< "The first parameter is the dimension of persistence to be used to create persistence intervals. "
<< "If your file contains the information about dimension of persistence pairs, please provide here the "
<< "dimension of persistence pairs you want to use. "
<< "If your input files consist only of birth-death pairs, please set this first parameter to -1.\n"
<< "The remaining parameters of the program are the names of files with persistence diagrams.\n";
if (argc < 3) {
std::clog << "Wrong parameter list, the program will now terminate \n";
return 1;
unsigned dimension = std::numeric_limits<unsigned>::max();
int dim = atoi(argv[1]);
if (dim >= 0) {
dimension = (unsigned)dim;
std::vector<const char*> filenames;
for (int i = 2; i < argc; ++i) {
filenames.push_back(argv[i]);
double min_ = std::numeric_limits<double>::max();
double max_ = -std::numeric_limits<double>::max();
for (size_t file_no = 0; file_no != filenames.size(); ++file_no) {
std::clog << "Creating diagram based on a file : " << filenames[file_no] << std::endl;
Persistence_intervals p(filenames[file_no], dimension);
std::pair<double, double> min_max_ = p.get_x_range();
if (min_max_.first < min_) min_ = min_max_.first;
if (min_max_.second > max_) max_ = min_max_.second;
std::clog << "Birth-death range : min: " << min_ << ", max: " << max_ << std::endl;
return 0;
Definition: Persistence_intervals.h:37
std::pair< double, double > get_x_range() const
Definition: Persistence_intervals.h:59
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
