Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
example_vector_double_points_off_reader.cpp
#include <gudhi/Points_off_io.h>
#include <iostream>
#include <string>
#include <vector>
using Point_d = std::vector<double>;
void usage(char * const progName) {
std::cerr << "Usage: " << progName << " inputFile.off" << std::endl;
exit(-1);
int main(int argc, char **argv) {
if (argc != 2) {
std::cerr << "Error: Number of arguments (" << argc << ") is not correct" << std::endl;
usage(argv[0]);
std::string off_input_file(argv[1]);
// Read the OFF file (input file name given as parameter) and triangulate points
Gudhi::Points_off_reader<Point_d> off_reader(off_input_file);
// Check the read operation was correct
if (!off_reader.is_valid()) {
std::cerr << "Unable to read file " << off_input_file << std::endl;
usage(argv[0]);
// Retrieve the triangulation
std::vector<Point_d> point_cloud = off_reader.get_point_cloud();
std::ofstream output_file(off_input_file + ".txt");
int n {0};
for (auto point : point_cloud) {
output_file << "Point[" << n << "] = ";
for (std::size_t i {0}; i < point.size(); i++)
output_file << point[i] << " ";
output_file << "\n";
++n;
output_file.close();
return 0;
OFF file reader implementation in order to read points from an OFF file.
Definition: Points_off_io.h:122
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
