example_custom_distance.cpp
#include <gudhi/choose_n_farthest_points.h>
#include <iostream>
#include <vector>
#include <iterator>
typedef unsigned Point;
/* The class Distance contains a distance function defined on the set of points {0, 1, 2, 3}
* and computes a distance according to the matrix:
* 0 1 2 4
* 1 0 4 2
* 2 4 0 1
* 4 2 1 0
class Distance {
private:
std::vector<std::vector<double>> matrix_;
public:
Distance() {
matrix_.push_back({0, 1, 2, 4});
matrix_.push_back({1, 0, 4, 2});
matrix_.push_back({2, 4, 0, 1});
matrix_.push_back({4, 2, 1, 0});
double operator()(Point p1, Point p2) const {
return matrix_[p1][p2];
int main(void) {
std::vector<Point> points = {0, 1, 2, 3};
std::vector<Point> results;
std::back_inserter(results));
std::clog << "Before sparsification: " << points.size() << " points.\n";
std::clog << "After sparsification: " << results.size() << " points.\n";
std::clog << "Result table: {" << results[0] << "," << results[1] << "}\n";
void choose_n_farthest_points(Distance dist, Point_range const &input_pts, std::size_t final_size, std::size_t starting_point, PointOutputIterator output_it, DistanceOutputIterator dist_it={})
Subsample by a greedy strategy of iteratively adding the farthest point from the current chosen point...
Definition: choose_n_farthest_points.h:69
@ random_starting_point
Definition: choose_n_farthest_points.h:34
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
