distance_functions.h
Go to the documentation of this file.
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Clément Maria
4 *
5 * Copyright (C) 2014 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef DISTANCE_FUNCTIONS_H_
12#define DISTANCE_FUNCTIONS_H_
13
14#include <gudhi/Debug_utils.h>
15
16#include <gudhi/Miniball.hpp>
17
18#include <boost/range/metafunctions.hpp>
19#include <boost/range/size.hpp>
20
21#include <cmath> // for std::sqrt
22#include <type_traits> // for std::decay
23#include <iterator> // for std::begin, std::end
24#include <utility>
25
26namespace Gudhi {
27
35 public:
36 // boost::range_value is not SFINAE-friendly so we cannot use it in the return type
37 template< typename Point >
38 typename std::iterator_traits<typename boost::range_iterator<Point>::type>::value_type
39 operator()(const Point& p1, const Point& p2) const {
40 auto it1 = std::begin(p1);
41 auto it2 = std::begin(p2);
42 typedef typename boost::range_value<Point>::type NT;
43 NT dist = 0;
44 for (; it1 != std::end(p1); ++it1, ++it2) {
45 GUDHI_CHECK(it2 != std::end(p2), "inconsistent point dimensions");
46 NT tmp = *it1 - *it2;
47 dist += tmp*tmp;
48 }
49 GUDHI_CHECK(it2 == std::end(p2), "inconsistent point dimensions");
50 using std::sqrt;
51 return sqrt(dist);
52 }
53 template< typename T >
54 T operator() (const std::pair< T, T >& f, const std::pair< T, T >& s) const {
55 T dx = f.first - s.first;
56 T dy = f.second - s.second;
57 using std::sqrt;
58 return sqrt(dx*dx + dy*dy);
59 }
60};
61
65 public:
75 template< typename Point >
76 typename std::iterator_traits<typename boost::range_iterator<Point>::type>::value_type
77 operator()(const Point& point_1, const Point& point_2) const {
78 return Euclidean_distance()(point_1, point_2) / 2.;
79 }
89 template< typename Point_cloud,
90 typename Point_iterator = typename boost::range_const_iterator<Point_cloud>::type,
91 typename Point = typename std::iterator_traits<Point_iterator>::value_type,
92 typename Coordinate_iterator = typename boost::range_const_iterator<Point>::type,
93 typename Coordinate = typename std::iterator_traits<Coordinate_iterator>::value_type>
94 Coordinate
95 operator()(const Point_cloud& point_cloud) const {
96 using Min_sphere = Miniball::Miniball<Miniball::CoordAccessor<Point_iterator, Coordinate_iterator>>;
97
98 Min_sphere ms(boost::size(*point_cloud.begin()), point_cloud.begin(), point_cloud.end());
99#ifdef DEBUG_TRACES
100 std::clog << "Minimal_enclosing_ball_radius = " << std::sqrt(ms.squared_radius()) << " | nb points = "
101 << boost::size(point_cloud) << " | dimension = "
102 << boost::size(*point_cloud.begin()) << std::endl;
103#endif // DEBUG_TRACES
104
105 return std::sqrt(ms.squared_radius());
106 }
107};
108
109} // namespace Gudhi
110
111#endif // DISTANCE_FUNCTIONS_H_
Compute the Euclidean distance between two Points given by a range of coordinates....
Definition: distance_functions.h:34
Compute the radius of the minimal enclosing ball between Points given by a range of coordinates....
Definition: distance_functions.h:64
std::iterator_traits< typenameboost::range_iterator< Point >::type >::value_type operator()(const Point &point_1, const Point &point_2) const
Minimal_enclosing_ball_radius from two points.
Definition: distance_functions.h:77
Coordinate operator()(const Point_cloud &point_cloud) const
Minimal_enclosing_ball_radius from a point cloud.
Definition: distance_functions.h:95
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
