counter.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Pawel Dlotko
4 *
5 * Copyright (C) 2015 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef BITMAP_CUBICAL_COMPLEX_COUNTER_H_
12#define BITMAP_CUBICAL_COMPLEX_COUNTER_H_
13
14#include <iostream>
15#include <vector>
16#include <cstddef>
17
18namespace Gudhi {
19
20namespace cubical_complex {
21
32class counter {
33 public:
38 counter(const std::vector<unsigned>& endd) : begin(endd.size(), 0), end(endd), current(endd.size(), 0) { }
39
44 counter(const std::vector< unsigned >& beginn, const std::vector< unsigned >& endd) : begin(beginn), end(endd), current(endd.size(), 0) {
45 if (beginn.size() != endd.size())
46 throw "In constructor of a counter, begin and end vectors do not have the same size. Program terminate";
47 }
48
54 bool increment() {
55 std::size_t i = 0;
56 while ((i != this->end.size()) && (this->current[i] == this->end[i])) {
57 ++i;
58 }
59
60 if (i == this->end.size())return false;
61 ++this->current[i];
62 for (std::size_t j = 0; j != i; ++j) {
63 this->current[j] = this->begin[j];
64 }
65 return true;
66 }
67
71 bool isFinal() {
72 for (std::size_t i = 0; i != this->current.size(); ++i) {
73 if (this->current[i] == this->end[i])return true;
74 }
75 return false;
76 }
77
83 std::vector< unsigned > find_opposite(const std::vector< bool >& directionsForPeriodicBCond) {
84 std::vector< unsigned > result;
85 for (std::size_t i = 0; i != this->current.size(); ++i) {
86 if ((this->current[i] == this->end[i]) && (directionsForPeriodicBCond[i] == true)) {
87 result.push_back(this->begin[i]);
88 } else {
89 result.push_back(this->current[i]);
90 }
91 }
92 return result;
93 }
94
98 std::vector< bool > directions_of_finals() {
99 std::vector< bool > result;
100 for (std::size_t i = 0; i != this->current.size(); ++i) {
101 if (this->current[i] == this->end[i]) {
102 result.push_back(true);
103 } else {
104 result.push_back(false);
105 }
106 }
107 return result;
108 }
109
113 friend std::ostream& operator<<(std::ostream& out, const counter& c) {
114 // std::cerr << "c.current.size() : " << c.current.size() << endl;
115 for (std::size_t i = 0; i != c.current.size(); ++i) {
116 out << c.current[i] << " ";
117 }
118 return out;
119 }
120
121 private:
122 std::vector< unsigned > begin;
123 std::vector< unsigned > end;
124 std::vector< unsigned > current;
125};
126
127} // namespace cubical_complex
128
129namespace Cubical_complex = cubical_complex;
130
131} // namespace Gudhi
132
133#endif // BITMAP_CUBICAL_COMPLEX_COUNTER_H_
This is an implementation of a counter being a vector of integers.
Definition: counter.h:32
std::vector< unsigned > find_opposite(const std::vector< bool > &directionsForPeriodicBCond)
Definition: counter.h:83
Definition: counter.h:98
friend std::ostream & operator<<(std::ostream &out, const counter &c)
Definition: counter.h:113
counter(const std::vector< unsigned > &endd)
Definition: counter.h:38
counter(const std::vector< unsigned > &beginn, const std::vector< unsigned > &endd)
Definition: counter.h:44
bool increment()
Definition: counter.h:54
bool isFinal()
Definition: counter.h:71
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
