add_blocker(const Root_simplex_handle &blocker_root) | Gudhi::skeleton_blocker::Skeleton_blocker_sub_complex< ComplexType > | inline |
Gudhi::skeleton_blocker::Skeleton_blocker_complex::add_blocker(const Simplex &blocker) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
add_edge(Vertex_handle a, Vertex_handle b) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
add_edge(const Simplex &s) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
add_edge_without_blockers(Root_vertex_handle v1_root, Root_vertex_handle v2_root) | Gudhi::skeleton_blocker::Skeleton_blocker_sub_complex< ComplexType > | inline |
Gudhi::skeleton_blocker::Skeleton_blocker_complex::add_edge_without_blockers(Vertex_handle a, Vertex_handle b) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
Gudhi::skeleton_blocker::Skeleton_blocker_complex::add_edge_without_blockers(Simplex s) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
add_simplex(const Simplex &sigma) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | |
add_vertex(Root_vertex_handle global) | Gudhi::skeleton_blocker::Skeleton_blocker_sub_complex< ComplexType > | inline |
Gudhi::skeleton_blocker::Skeleton_blocker_complex::add_vertex() | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
blocker_range(Vertex_handle v) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
blocker_range() | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
build_link(const ComplexType &parent_complex, const Simplex &alpha_parent_adress, bool is_alpha_blocker=false, bool only_vertices=false) | Gudhi::skeleton_blocker::Skeleton_blocker_link_complex< ComplexType > | inline |
build_link_of_blocker | Gudhi::skeleton_blocker::Skeleton_blocker_link_complex< ComplexType > | friend |
clear() | Gudhi::skeleton_blocker::Skeleton_blocker_sub_complex< ComplexType > | inlinevirtual |
coboundary_range(const Simplex &s) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
Complex_coboundary_range typedef | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | |
Complex_simplex_around_vertex_range typedef | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | |
complex_simplex_range() const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
const_blocker_range(Vertex_handle v) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
const_blocker_range() const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
contains(const Simplex &s) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inlinevirtual |
contains_blocker(const Blocker_handle s) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
contains_blocker(const Simplex &s) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
contains_edge(Vertex_handle a, Vertex_handle b) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
contains_edges(const Simplex &sigma) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
contains_vertices(const Simplex &sigma) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
contract_edge(Edge_handle edge) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
contract_edge(Vertex_handle a, Vertex_handle b) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | |
convert_handle_from_another_complex(const Skeleton_blocker_complex &other, Vertex_handle vh_in_other) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
degree(Vertex_handle local) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
delete_blocker(Blocker_handle sigma) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
edge_range() const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
edge_range(Vertex_handle v) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
first_vertex(Edge_handle edge_handle) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
get_address(Root_vertex_handle global) const | Gudhi::skeleton_blocker::Skeleton_blocker_sub_complex< ComplexType > | inline |
Gudhi::skeleton_blocker::Skeleton_blocker_complex::get_address(Root_vertex_handle id) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inlinevirtual |
get_addresses(const Root_simplex_handle &s) const | Gudhi::skeleton_blocker::Skeleton_blocker_sub_complex< ComplexType > | inline |
get_id(Vertex_handle local) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
get_id(const Simplex &local_simplex) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
get_simplex_address(const Root_simplex_handle &s) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
get_vertices(Edge_handle edge_handle) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
Graph_edge typedef | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | |
Graph_vertex typedef | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | |
is_cone() const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
is_contractible() const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inlinevirtual |
is_popable_blocker(Blocker_handle sigma) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | |
keep_only_vertices() | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
link(Vertex_handle v) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
link(Edge_handle edge) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
link(const Simplex &simplex) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
link_condition(Vertex_handle a, Vertex_handle b, bool ignore_popable_blockers=false) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
link_condition(Edge_handle e, bool ignore_popable_blockers=false) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
make_restricted_complex(const ComplexType &parent_complex, const Simplex &simplex) | Gudhi::skeleton_blocker::Skeleton_blocker_sub_complex< ComplexType > | inline |
num_connected_components() const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
operator==(const Skeleton_blocker_complex &other) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
operator[](Root_vertex_handle global) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
operator[](Vertex_handle address) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
operator[](Vertex_handle address) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
operator[](const std::pair< Vertex_handle, Vertex_handle > &ab) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
operator[](Edge_handle edge_handle) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
operator[](Edge_handle edge_handle) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
remove_all_popable_blockers(Vertex_handle v) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | |
remove_blocker(const Blocker_handle sigma) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
remove_blockers() | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
remove_edge(Vertex_handle a, Vertex_handle b) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inlinevirtual |
remove_edge(Edge_handle edge) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
remove_popable_blockers() | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | |
remove_popable_blockers(Vertex_handle v) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | |
remove_star(Vertex_handle v) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | |
remove_star(Vertex_handle a, Vertex_handle b) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | |
remove_star(Edge_handle e) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | |
remove_star(const Simplex &sigma) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | |
remove_vertex(Vertex_handle address) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
second_vertex(Edge_handle edge_handle) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
set_visitor(Visitor *other_visitor) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
Skeleton_blocker_complex(size_t num_vertices_=0, Visitor *visitor_=NULL) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inlineexplicit |
Skeleton_blocker_complex(SimpleHandleOutputIterator simplices_begin, SimpleHandleOutputIterator simplices_end, bool is_flag_complex=false, Visitor *visitor_=NULL) | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
Skeleton_blocker_link_complex(const ComplexType &parent_complex, const Simplex &alpha_parent_adress, bool only_superior_vertices=false, bool only_vertices=false) | Gudhi::skeleton_blocker::Skeleton_blocker_link_complex< ComplexType > | inline |
Skeleton_blocker_link_complex(const ComplexType &parent_complex, Vertex_handle a_parent_adress, bool only_superior_vertices=false) | Gudhi::skeleton_blocker::Skeleton_blocker_link_complex< ComplexType > | inline |
Skeleton_blocker_link_complex(const ComplexType &parent_complex, Edge_handle edge, bool only_superior_vertices=false) | Gudhi::skeleton_blocker::Skeleton_blocker_link_complex< ComplexType > | inline |
star_simplex_range(Vertex_handle v) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
triangle_range(Vertex_handle v) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
triangle_range() const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
vertex_range() const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
vertex_range(Vertex_handle v) const | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inline |
~Skeleton_blocker_complex() | Gudhi::skeleton_blocker::Skeleton_blocker_complex< SkeletonBlockerDS > | inlinevirtual |
