Gudhi::Persistence_representations::Persistence_landscape_on_grid Member List
This is the complete list of members for Gudhi::Persistence_representations::Persistence_landscape_on_grid, including all inherited members.
abs()Gudhi::Persistence_representations::Persistence_landscape_on_gridinline
add_two_landscapesGudhi::Persistence_representations::Persistence_landscape_on_gridfriend
compute_average(const std::vector< Persistence_landscape_on_grid * > &to_average)Gudhi::Persistence_representations::Persistence_landscape_on_gridinline
compute_distance_of_landscapes_on_gridGudhi::Persistence_representations::Persistence_landscape_on_gridfriend
compute_inner_productGudhi::Persistence_representations::Persistence_landscape_on_gridfriend
compute_integral_of_landscape() constGudhi::Persistence_representations::Persistence_landscape_on_gridinline
compute_integral_of_landscape(size_t level) constGudhi::Persistence_representations::Persistence_landscape_on_gridinline
compute_integral_of_landscape(double p) constGudhi::Persistence_representations::Persistence_landscape_on_gridinline
compute_integral_of_landscape(double p, size_t level) constGudhi::Persistence_representations::Persistence_landscape_on_gridinline
compute_max_norm_distance_of_landscapesGudhi::Persistence_representations::Persistence_landscape_on_gridfriend
compute_maximum() constGudhi::Persistence_representations::Persistence_landscape_on_gridinline
compute_minimum_maximum() constGudhi::Persistence_representations::Persistence_landscape_on_gridinline
compute_norm_of_landscape(double i) constGudhi::Persistence_representations::Persistence_landscape_on_gridinline
compute_scalar_product(const Persistence_landscape_on_grid &second)Gudhi::Persistence_representations::Persistence_landscape_on_gridinline
compute_value_at_a_given_point(unsigned level, double x) constGudhi::Persistence_representations::Persistence_landscape_on_gridinline
distance(const Persistence_landscape_on_grid &second, double power=1) constGudhi::Persistence_representations::Persistence_landscape_on_gridinline
find_max(unsigned lambda) constGudhi::Persistence_representations::Persistence_landscape_on_gridinline
get_x_range(size_t level=0) constGudhi::Persistence_representations::Persistence_landscape_on_gridinline
get_y_range(size_t level=0) constGudhi::Persistence_representations::Persistence_landscape_on_gridinline
load_landscape_from_file(const char *filename)Gudhi::Persistence_representations::Persistence_landscape_on_grid
number_of_nonzero_levels() constGudhi::Persistence_representations::Persistence_landscape_on_gridinline
number_of_projections_to_R() constGudhi::Persistence_representations::Persistence_landscape_on_gridinline
number_of_vectorize_functions() constGudhi::Persistence_representations::Persistence_landscape_on_gridinline
operator!=(const Persistence_landscape_on_grid &rhs) constGudhi::Persistence_representations::Persistence_landscape_on_gridinline
operator()(unsigned level, double x) constGudhi::Persistence_representations::Persistence_landscape_on_gridinline
operator*Gudhi::Persistence_representations::Persistence_landscape_on_gridfriend
operator*=(double x)Gudhi::Persistence_representations::Persistence_landscape_on_gridinline
operator+Gudhi::Persistence_representations::Persistence_landscape_on_gridfriend
operator+=(const Persistence_landscape_on_grid &rhs)Gudhi::Persistence_representations::Persistence_landscape_on_gridinline
operator-Gudhi::Persistence_representations::Persistence_landscape_on_gridfriend
operator-=(const Persistence_landscape_on_grid &rhs)Gudhi::Persistence_representations::Persistence_landscape_on_gridinline
operator/=(double x)Gudhi::Persistence_representations::Persistence_landscape_on_gridinline
operator<<Gudhi::Persistence_representations::Persistence_landscape_on_gridfriend
operator==(const Persistence_landscape_on_grid &rhs) constGudhi::Persistence_representations::Persistence_landscape_on_gridinline
output_for_visualization() constGudhi::Persistence_representations::Persistence_landscape_on_gridinline
Persistence_landscape_on_grid()Gudhi::Persistence_representations::Persistence_landscape_on_gridinline
Persistence_landscape_on_grid(const std::vector< std::pair< double, double > > &p, double grid_min_, double grid_max_, size_t number_of_points_)Gudhi::Persistence_representations::Persistence_landscape_on_grid
Persistence_landscape_on_grid(const std::vector< std::pair< double, double > > &p, double grid_min_, double grid_max_, size_t number_of_points_, unsigned number_of_levels_of_landscape)Gudhi::Persistence_representations::Persistence_landscape_on_grid
Persistence_landscape_on_grid(const char *filename, double grid_min_, double grid_max_, size_t number_of_points_, unsigned number_of_levels_of_landscape, uint16_t dimension_=std::numeric_limits< uint16_t >::max())Gudhi::Persistence_representations::Persistence_landscape_on_grid
Persistence_landscape_on_grid(const char *filename, double grid_min_, double grid_max_, size_t number_of_points_, uint16_t dimension_=std::numeric_limits< uint16_t >::max())Gudhi::Persistence_representations::Persistence_landscape_on_grid
Persistence_landscape_on_grid(const char *filename, size_t number_of_points, unsigned number_of_levels_of_landscape, uint16_t dimension=std::numeric_limits< uint16_t >::max())Gudhi::Persistence_representations::Persistence_landscape_on_grid
Persistence_landscape_on_grid(const char *filename, size_t number_of_points, uint16_t dimension=std::numeric_limits< uint16_t >::max())Gudhi::Persistence_representations::Persistence_landscape_on_grid
plot(const char *filename, size_t from_, size_t to_) constGudhi::Persistence_representations::Persistence_landscape_on_gridinline
plot(const char *filename, double min_x=std::numeric_limits< double >::max(), double max_x=std::numeric_limits< double >::max(), double min_y=std::numeric_limits< double >::max(), double max_y=std::numeric_limits< double >::max(), size_t from_=std::numeric_limits< size_t >::max(), size_t to_=std::numeric_limits< size_t >::max()) constGudhi::Persistence_representations::Persistence_landscape_on_grid
print_to_file(const char *filename) constGudhi::Persistence_representations::Persistence_landscape_on_grid
project_to_R(int number_of_function) constGudhi::Persistence_representations::Persistence_landscape_on_gridinline
size() constGudhi::Persistence_representations::Persistence_landscape_on_gridinline
subtract_two_landscapesGudhi::Persistence_representations::Persistence_landscape_on_gridfriend
vectorize(int number_of_function) constGudhi::Persistence_representations::Persistence_landscape_on_gridinline
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:28 for GUDHI by Doxygen 1.9.2
