Skeleton_blockers_blockers_iterators.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): David Salinas
4 *
5 * Copyright (C) 2014 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef SKELETON_BLOCKER_ITERATORS_SKELETON_BLOCKERS_BLOCKERS_ITERATORS_H_
12#define SKELETON_BLOCKER_ITERATORS_SKELETON_BLOCKERS_BLOCKERS_ITERATORS_H_
13
14#include <boost/iterator/iterator_facade.hpp>
15
16namespace Gudhi {
17
18namespace skeleton_blocker {
19
23// ReturnType = const Simplex* or Simplex*
24// MapIteratorType = BlockerMapConstIterator or BlockerMapIterator
25
26template<typename MapIteratorType, typename ReturnType>
27class Blocker_iterator_internal : public boost::iterator_facade<
28Blocker_iterator_internal<MapIteratorType, ReturnType>,
29ReturnType,
30boost::forward_traversal_tag,
31ReturnType
32> {
33 private:
34 MapIteratorType current_position;
35 MapIteratorType end_of_map;
36
37 public:
38 Blocker_iterator_internal() : current_position() { }
39
40 Blocker_iterator_internal(MapIteratorType position, MapIteratorType end_of_map_) :
41 current_position(position), end_of_map(end_of_map_) { }
42
43 bool equal(const Blocker_iterator_internal& other) const {
44 return current_position == other.current_position;
45 }
46
47 void increment() {
48 goto_next_blocker();
49 }
50
51 ReturnType dereference() const {
52 return (current_position->second);
53 }
54
55 private:
61 void goto_next_blocker() {
62 do {
63 ++current_position;
64 } while (!(current_position == end_of_map) && !first_time_blocker_is_seen());
65 }
66
67 bool first_time_blocker_is_seen() const {
68 return current_position->first == current_position->second->first_vertex();
69 }
70};
71
75// ReturnType = const Simplex* or Simplex*
76// MapIteratorType = BlockerMapConstIterator or BlockerMapIterator
77
78template<typename MapIteratorType, typename ReturnType>
79class Blocker_iterator_around_vertex_internal : public boost::iterator_facade<
80Blocker_iterator_around_vertex_internal<MapIteratorType, ReturnType>,
81ReturnType,
82boost::forward_traversal_tag,
83ReturnType
84> {
85 private:
86 MapIteratorType current_position_;
87
88 public:
89 Blocker_iterator_around_vertex_internal() : current_position_() { }
90
91 Blocker_iterator_around_vertex_internal(MapIteratorType position) :
92 current_position_(position) { }
93
95 this->current_position_ = other.current_position_;
96 return *this;
97 }
98
99 bool equal(const Blocker_iterator_around_vertex_internal& other) const {
100 return current_position_ == other.current_position_;
101 }
102
103 void increment() {
104 current_position_++;
105 }
106
107 ReturnType dereference() const {
108 return (current_position_->second);
109 }
110
111 MapIteratorType current_position() {
112 return this->current_position_;
113 }
114};
115
116} // namespace skeleton_blocker
117
118namespace skbl = skeleton_blocker;
119
120} // namespace Gudhi
121
122#endif // SKELETON_BLOCKER_ITERATORS_SKELETON_BLOCKERS_BLOCKERS_ITERATORS_H_
Iterator through the blockers of a vertex.
Definition: Skeleton_blockers_blockers_iterators.h:84
Definition: Skeleton_blockers_blockers_iterators.h:32
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
