Skeleton_blocker_simplifiable_complex.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): David Salinas
4 *
5 * Copyright (C) 2014 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef SKELETON_BLOCKER_SIMPLIFIABLE_COMPLEX_H_
12#define SKELETON_BLOCKER_SIMPLIFIABLE_COMPLEX_H_
13
14#include <gudhi/Skeleton_blocker/Skeleton_blocker_sub_complex.h>
15
16#include <list>
17#include <vector>
18#include <set>
19
20namespace Gudhi {
21
22namespace skeleton_blocker {
23
32template<typename SkeletonBlockerDS>
34 assert(this->contains_blocker(*sigma));
36 build_link_of_blocker(*this, *sigma, link_blocker_sigma);
37 return link_blocker_sigma.is_contractible() == CONTRACTIBLE;
38}
39
44template<typename SkeletonBlockerDS>
46 std::list<Vertex_handle> vertex_to_check;
47 for (auto v : this->vertex_range())
48 vertex_to_check.push_front(v);
49
50 while (!vertex_to_check.empty()) {
51 Vertex_handle v = vertex_to_check.front();
52 vertex_to_check.pop_front();
53
54 bool blocker_popable_found = true;
55 while (blocker_popable_found) {
56 blocker_popable_found = false;
57 for (auto block : this->blocker_range(v)) {
58 if (this->is_popable_blocker(block)) {
59 for (Vertex_handle nv : *block)
60 if (nv != v) vertex_to_check.push_back(nv);
61 this->delete_blocker(block);
62 blocker_popable_found = true;
63 break;
64 }
65 }
66 }
67 }
68}
69
73template<typename SkeletonBlockerDS>
75 bool blocker_popable_found = true;
76 while (blocker_popable_found) {
77 blocker_popable_found = false;
78 for (auto block : this->blocker_range(v)) {
79 if (is_popable_blocker(block)) {
80 this->delete_blocker(block);
81 blocker_popable_found = true;
82 }
83 }
84 }
85}
86
92template<typename SkeletonBlockerDS>
94 std::list<Vertex_handle> vertex_to_check;
95 vertex_to_check.push_front(v);
96
97 while (!vertex_to_check.empty()) {
98 Vertex_handle v = vertex_to_check.front();
99 vertex_to_check.pop_front();
100
101 bool blocker_popable_found = true;
102 while (blocker_popable_found) {
103 blocker_popable_found = false;
104 for (auto block : this->blocker_range(v)) {
105 if (this->is_popable_blocker(block)) {
106 for (Vertex_handle nv : *block)
107 if (nv != v) vertex_to_check.push_back(nv);
108 this->delete_blocker(block);
109 blocker_popable_found = true;
110 break;
111 }
112 }
113 }
114 }
115}
116
120template<typename SkeletonBlockerDS>
122 // we remove the blockers that are not consistent anymore
123 update_blockers_after_remove_star_of_vertex_or_edge(Simplex(v));
124 while (this->degree(v) > 0) {
125 Vertex_handle w(* (adjacent_vertices(v.vertex, this->skeleton).first));
126 this->remove_edge(v, w);
127 }
128 this->remove_vertex(v);
129}
130
136template<typename SkeletonBlockerDS>
138 std::list <Blocker_handle> blockers_to_update;
139 if (simplex_to_be_removed.empty()) return;
140
141 auto v0 = simplex_to_be_removed.first_vertex();
142 for (auto blocker : this->blocker_range(v0)) {
143 if (blocker->contains(simplex_to_be_removed))
144 blockers_to_update.push_back(blocker);
145 }
146
147 for (auto blocker_to_update : blockers_to_update) {
148 Simplex sub_blocker_to_be_added;
149 bool sub_blocker_need_to_be_added =
150 (blocker_to_update->dimension() - simplex_to_be_removed.dimension()) >= 2;
151 if (sub_blocker_need_to_be_added) {
152 sub_blocker_to_be_added = *blocker_to_update;
153 sub_blocker_to_be_added.difference(simplex_to_be_removed);
154 }
155 this->delete_blocker(blocker_to_update);
156 if (sub_blocker_need_to_be_added)
157 this->add_blocker(sub_blocker_to_be_added);
158 }
159}
160
165template<typename SkeletonBlockerDS>
167 update_blockers_after_remove_star_of_vertex_or_edge(Simplex(a, b));
168 // we remove the edge
169 this->remove_edge(a, b);
170}
171
175template<typename SkeletonBlockerDS>
177 return remove_star(this->first_vertex(e), this->second_vertex(e));
178}
179
183template<typename SkeletonBlockerDS>
185 assert(this->contains(sigma));
186 if (sigma.dimension() == 0) {
187 remove_star(sigma.first_vertex());
188 } else if (sigma.dimension() == 1) {
189 remove_star(sigma.first_vertex(), sigma.last_vertex());
190 } else {
191 remove_blocker_containing_simplex(sigma);
192 this->add_blocker(sigma);
193 }
194}
195
196template<typename SkeletonBlockerDS>
198 // to add a simplex s, all blockers included in s are first removed
199 // and then all simplex in the coboundary of s are added as blockers
200 assert(!this->contains(sigma));
201 assert(sigma.dimension() > 1);
202 if (!contains_vertices(sigma)) {
203 std::cerr << "add_simplex: Some vertices were not present in the complex, adding them" << std::endl;
204 size_t num_vertices_to_add = sigma.last_vertex() - this->num_vertices() + 1;
205 for (size_t i = 0; i < num_vertices_to_add; ++i)
206 this->add_vertex();
207 }
208 assert(contains_vertices(sigma));
209 if (!contains_edges(sigma))
210 add_edge(sigma);
211 remove_blocker_include_in_simplex(sigma);
212 add_blockers_after_simplex_insertion(sigma);
213}
214
215template<typename SkeletonBlockerDS>
217 if (sigma.dimension() < 1) return;
218
219 for (auto s : coboundary_range(sigma)) {
220 this->add_blocker(s);
221 }
222}
223
227template<typename SkeletonBlockerDS>
228void Skeleton_blocker_complex<SkeletonBlockerDS>::remove_blocker_containing_simplex(const Simplex& sigma) {
229 std::vector <Blocker_handle> blockers_to_remove;
230 for (auto blocker : this->blocker_range(sigma.first_vertex())) {
231 if (blocker->contains(sigma))
232 blockers_to_remove.push_back(blocker);
233 }
234 for (auto blocker_to_update : blockers_to_remove)
235 this->delete_blocker(blocker_to_update);
236}
237
241template<typename SkeletonBlockerDS>
242void Skeleton_blocker_complex<SkeletonBlockerDS>::remove_blocker_include_in_simplex(const Simplex& sigma) {
243 // TODO(DS): write efficiently by using only superior blockers
244 // eg for all s, check blockers whose vertices are all greater than s
245 std::set <Blocker_handle> blockers_to_remove;
246 for (auto s : sigma) {
247 for (auto blocker : this->blocker_range(s)) {
248 if (sigma.contains(*blocker))
249 blockers_to_remove.insert(blocker);
250 }
251 }
252 for (auto blocker_to_update : blockers_to_remove) {
253 auto s = *blocker_to_update;
254 this->delete_blocker(blocker_to_update);
255 // now if there is a vertex v in the link of s
256 // and v is not included in sigma then v.s is a blocker
257 // (all faces of v.s are there since v belongs to the link of s)
258 for (const auto& b : coboundary_range(s))
259 if (!sigma.contains(b))
260 this->add_blocker(b);
261 }
262}
263
269template<typename SkeletonBlockerDS>
270void Skeleton_blocker_complex<SkeletonBlockerDS>::tip_blockers(Vertex_handle a, Vertex_handle b,
271 std::vector<Simplex> & buffer) const {
272 for (auto const & blocker : this->const_blocker_range(a)) {
273 Simplex beta = (*blocker);
274 beta.remove_vertex(a);
275 buffer.push_back(beta);
276 }
277
278 Simplex n;
279 this->add_neighbours(b, n);
280 this->remove_neighbours(a, n);
281 n.remove_vertex(a);
282
283
284 for (Vertex_handle y : n) {
285 Simplex beta;
286 beta.add_vertex(y);
287 buffer.push_back(beta);
288 }
289}
290
299template<typename SkeletonBlockerDS>
300void
301Skeleton_blocker_complex<SkeletonBlockerDS>::swap_edge(Vertex_handle a, Vertex_handle b, Vertex_handle x) {
302 this->add_edge_without_blockers(a, x);
303 if (this->visitor) this->visitor->on_swaped_edge(a, b, x);
304 this->remove_edge(b, x);
305}
306
307template<typename SkeletonBlockerDS>
308void
309Skeleton_blocker_complex<SkeletonBlockerDS>::delete_blockers_around_vertex(Vertex_handle v) {
310 std::list <Blocker_handle> blockers_to_delete;
311 for (auto blocker : this->blocker_range(v)) {
312 blockers_to_delete.push_back(blocker);
313 }
314 while (!blockers_to_delete.empty()) {
315 this->remove_blocker(blockers_to_delete.back());
316 blockers_to_delete.pop_back();
317 }
318}
319
323template<typename SkeletonBlockerDS>
324void
325Skeleton_blocker_complex<SkeletonBlockerDS>::delete_blockers_around_edge(Vertex_handle a, Vertex_handle b) {
326 std::list<Blocker_handle> blocker_to_delete;
327 for (auto blocker : this->blocker_range(a))
328 if (blocker->contains(b)) blocker_to_delete.push_back(blocker);
329 while (!blocker_to_delete.empty()) {
330 this->delete_blocker(blocker_to_delete.back());
331 blocker_to_delete.pop_back();
332 }
333}
334
340template<typename SkeletonBlockerDS>
341void
343 assert(this->contains_vertex(a));
344 assert(this->contains_vertex(b));
345
346 if (this->contains_edge(a, b))
347 this->add_edge_without_blockers(a, b);
348
349 // if some blockers passes through 'ab', we need to remove them.
350 if (!link_condition(a, b))
351 delete_blockers_around_edge(a, b);
352
353 std::set<Simplex> blockers_to_add;
354
355 get_blockers_to_be_added_after_contraction(a, b, blockers_to_add);
356
357 delete_blockers_around_vertices(a, b);
358
359 update_edges_after_contraction(a, b);
360
361 this->remove_vertex(b);
362
363 notify_changed_edges(a);
364
365 for (auto block : blockers_to_add)
366 this->add_blocker(block);
367
368 assert(this->contains_vertex(a));
369 assert(!this->contains_vertex(b));
370}
371
372template<typename SkeletonBlockerDS>
374 Vertex_handle b,
375 std::set<Simplex>& blockers_to_add) {
376 blockers_to_add.clear();
377
379
380 LinkComplexType link_a(*this, a);
381 LinkComplexType link_b(*this, b);
382
383 std::vector<Simplex> vector_alpha, vector_beta;
384
385 tip_blockers(a, b, vector_alpha);
386 tip_blockers(b, a, vector_beta);
387
388 for (auto alpha = vector_alpha.begin(); alpha != vector_alpha.end(); ++alpha) {
389 for (auto beta = vector_beta.begin(); beta != vector_beta.end(); ++beta) {
390 Simplex sigma = *alpha;
391 sigma.union_vertices(*beta);
392 Root_simplex_handle sigma_id = this->get_id(sigma);
393 if (this->contains(sigma) &&
394 proper_faces_in_union<Skeleton_blocker_complex < SkeletonBlockerDS >> (sigma_id, link_a, link_b)) {
395 // Blocker_handle blocker = new Simplex(sigma);
396 sigma.add_vertex(a);
397 blockers_to_add.insert(sigma);
398 }
399 }
400 }
401}
402
406template<typename SkeletonBlockerDS>
407void
408Skeleton_blocker_complex<SkeletonBlockerDS>::delete_blockers_around_vertices(Vertex_handle a, Vertex_handle b) {
409 std::vector<Blocker_handle> blocker_to_delete;
410 for (auto bl : this->blocker_range(a))
411 blocker_to_delete.push_back(bl);
412 for (auto bl : this->blocker_range(b))
413 blocker_to_delete.push_back(bl);
414 while (!blocker_to_delete.empty()) {
415 this->delete_blocker(blocker_to_delete.back());
416 blocker_to_delete.pop_back();
417 }
418}
419
420template<typename SkeletonBlockerDS>
421void
422Skeleton_blocker_complex<SkeletonBlockerDS>::update_edges_after_contraction(Vertex_handle a, Vertex_handle b) {
423 // We update the set of edges
424 this->remove_edge(a, b);
425
426 // For all edges {b,x} incident to b,
427 // we remove {b,x} and add {a,x} if not already there.
428 while (this->degree(b) > 0) {
429 Vertex_handle x(*(adjacent_vertices(b.vertex, this->skeleton).first));
430 if (!this->contains_edge(a, x))
431 // we 'replace' the edge 'bx' by the edge 'ax'
432 this->swap_edge(a, b, x);
433 else
434 this->remove_edge(b, x);
435 }
436}
437
438template<typename SkeletonBlockerDS>
439void
440Skeleton_blocker_complex<SkeletonBlockerDS>::notify_changed_edges(Vertex_handle a) {
441 // We notify the visitor that all edges incident to 'a' had changed
442 boost_adjacency_iterator v, v_end;
443
444 for (tie(v, v_end) = adjacent_vertices(a.vertex, this->skeleton); v != v_end; ++v)
445 if (this->visitor) this->visitor->on_changed_edge(a, Vertex_handle(*v));
446}
447
448
449} // namespace skeleton_blocker
450
451namespace skbl = skeleton_blocker;
452
453} // namespace Gudhi
454
455#endif // SKELETON_BLOCKER_SIMPLIFIABLE_COMPLEX_H_
Abstract Simplicial Complex represented with a skeleton/blockers pair.
Definition: Skeleton_blocker_complex.h:51
virtual contractible_status is_contractible() const
Test if the complex is reducible using a strategy defined in the class (by default it tests if the co...
Definition: Skeleton_blocker_complex.h:1164
Vertex_handle first_vertex(Edge_handle edge_handle) const
returns the first vertex of an edge
Definition: Skeleton_blocker_complex.h:512
void contract_edge(Edge_handle edge)
Definition: Skeleton_blocker_complex.h:1246
void add_simplex(const Simplex &sigma)
add a simplex and all its faces.
Definition: Skeleton_blocker_simplifiable_complex.h:197
void remove_all_popable_blockers(Vertex_handle v)
Removes all the popable blockers of the complex passing through v and delete them....
Definition: Skeleton_blocker_simplifiable_complex.h:93
void remove_popable_blockers()
Definition: Skeleton_blocker_simplifiable_complex.h:45
virtual void clear()
Definition: Skeleton_blocker_complex.h:311
void remove_star(Vertex_handle v)
Definition: Skeleton_blocker_simplifiable_complex.h:121
bool is_popable_blocker(Blocker_handle sigma) const
Definition: Skeleton_blocker_simplifiable_complex.h:33
boost::graph_traits< Graph >::edge_descriptor Edge_handle
Handle to an edge of the complex.
Definition: Skeleton_blocker_complex.h:114
Abstract simplex used in Skeleton blockers data-structure.
Definition: Skeleton_blocker_simplex.h:38
T first_vertex() const
Definition: Skeleton_blocker_simplex.h:210
T last_vertex() const
Definition: Skeleton_blocker_simplex.h:220
int dimension() const
Definition: Skeleton_blocker_simplex.h:197
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
