Skeleton_blocker_simplex.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): David Salinas
4 *
5 * Copyright (C) 2014 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef SKELETON_BLOCKER_SKELETON_BLOCKER_SIMPLEX_H_
12#define SKELETON_BLOCKER_SKELETON_BLOCKER_SIMPLEX_H_
13
14#include <cassert>
15#include <iostream>
16#include <set>
17#include <vector>
18#include <initializer_list>
19#include <string>
20#include <algorithm>
21
22namespace Gudhi {
23
24namespace skeleton_blocker {
25
36template<typename T>
37
39 private:
40 std::set<T> simplex_set;
41
42 public:
43 typedef typename T::boost_vertex_handle boost_vertex_handle;
44
45 typedef T Vertex_handle;
46
47 typedef typename std::set<T>::const_iterator Simplex_vertex_const_iterator;
48 typedef typename std::set<T>::iterator Simplex_vertex_iterator;
49
53
54 void clear() {
55 simplex_set.clear();
56 }
57
58 Skeleton_blocker_simplex(std::initializer_list<T>& list) {
59 std::for_each(list.begin(), list.end(), [&] (T const& elt) {
60 add_vertex(elt);
61 });
62 }
63
64 template<typename ... Args>
65 explicit Skeleton_blocker_simplex(Args ... args) {
66 add_vertices(args...);
67 }
68
69 template<typename ... Args>
70 void add_vertices(T v, Args ... args) {
71 add_vertex(v);
72 add_vertices(args...);
73 }
74
75 void add_vertices(T v) {
76 add_vertex(v);
77 }
78
79 void add_vertices() { }
80
84 explicit Skeleton_blocker_simplex(std::string token) {
85 clear();
86 if ((token[0] == '{') && (token[token.size() - 1] == '}')) {
87 token.erase(0, 1);
88 token.erase(token.size() - 1, 1);
89 while (token.size() != 0) {
90 int coma_position = token.find_first_of(',');
91 // cout << "coma_position:"<<coma_position<<endl;
92 std::string n = token.substr(0, coma_position);
93 // cout << "token:"<<token<<endl;
94 token.erase(0, n.size() + 1);
95 add_vertex((T) (atoi(n.c_str())));
96 }
97 }
98 }
99
101
110 void add_vertex(T v) {
111 simplex_set.insert(v);
112 }
113
117 void remove_vertex(T v) {
118 simplex_set.erase(v);
119 }
120
125 std::vector<T> v;
126 v.reserve((std::min)(simplex_set.size(), a.simplex_set.size()));
127
128 set_intersection(simplex_set.begin(), simplex_set.end(),
129 a.simplex_set.begin(), a.simplex_set.end(),
130 std::back_inserter(v));
131 clear();
132 for (auto i : v)
133 simplex_set.insert(i);
134 }
135
140 std::vector<T> v;
141 v.reserve(simplex_set.size());
142
143 set_difference(simplex_set.begin(), simplex_set.end(),
144 a.simplex_set.begin(), a.simplex_set.end(),
145 std::back_inserter(v));
146
147 clear();
148 for (auto i : v)
149 simplex_set.insert(i);
150 }
151
156 std::vector<T> v;
157 v.reserve(simplex_set.size() + a.simplex_set.size());
158
159 set_union(simplex_set.begin(), simplex_set.end(), a.simplex_set.begin(),
160 a.simplex_set.end(), std::back_inserter(v));
161 clear();
162 simplex_set.insert(v.begin(), v.end());
163 }
164
165 typename std::set<T>::const_iterator begin() const {
166 return simplex_set.cbegin();
167 }
168
169 typename std::set<T>::const_iterator end() const {
170 return simplex_set.cend();
171 }
172
173 typename std::set<T>::const_reverse_iterator rbegin() const {
174 return simplex_set.crbegin();
175 }
176
177 typename std::set<T>::const_reverse_iterator rend() const {
178 return simplex_set.crend();
179 }
180
181 typename std::set<T>::iterator begin() {
182 return simplex_set.begin();
183 }
184
185 typename std::set<T>::iterator end() {
186 return simplex_set.end();
187 }
188
190
197 int dimension() const {
198 return (simplex_set.size() - 1);
199 }
200
201 bool empty() const {
202 return simplex_set.empty();
203 }
204
210 T first_vertex() const {
211 assert(!empty());
212 return *(begin());
213 }
214
220 T last_vertex() const {
221 assert(!empty());
222 return *(simplex_set.rbegin());
223 }
224
228 bool contains(const Skeleton_blocker_simplex & a) const {
229 return includes(simplex_set.cbegin(), simplex_set.cend(),
230 a.simplex_set.cbegin(), a.simplex_set.cend());
231 }
232
237 const Skeleton_blocker_simplex& b) const {
238 auto first1 = begin();
239 auto last1 = end();
240
241 auto first2 = a.begin();
242 auto last2 = a.end();
243
244 while (first2 != last2) {
245 // we ignore vertices of b
246 if (b.contains(*first2)) {
247 ++first2;
248 } else {
249 if ((first1 == last1) || (*first2 < *first1))
250 return false;
251 if (!(*first1 < *first2))
252 ++first2;
253 ++first1;
254 }
255 }
256 return true;
257 }
258
263 auto first1 = begin();
264 auto last1 = end();
265
266 auto first2 = a.begin();
267 auto last2 = a.end();
268
269 while (first2 != last2) {
270 // we ignore vertices x
271 if (x == *first2) {
272 ++first2;
273 } else {
274 if ((first1 == last1) || (*first2 < *first1))
275 return false;
276 if (!(*first1 < *first2))
277 ++first2;
278 ++first1;
279 }
280 }
281 return true;
282 }
283
287 bool contains_difference(const Skeleton_blocker_simplex& a, T x, T y) const {
288 auto first1 = begin();
289 auto last1 = end();
290
291 auto first2 = a.begin();
292 auto last2 = a.end();
293
294 while (first2 != last2) {
295 // we ignore vertices of x,y
296 if (x == *first2 || y == *first2) {
297 ++first2;
298 } else {
299 if ((first1 == last1) || (*first2 < *first1))
300 return false;
301 if (!(*first1 < *first2))
302 ++first2;
303 ++first1;
304 }
305 }
306 return true;
307 }
308
309 bool contains(T v) const {
310 return (simplex_set.find(v) != simplex_set.end());
311 }
312
313 bool disjoint(const Skeleton_blocker_simplex& a) const {
314 std::vector<T> v;
315 v.reserve(std::min(simplex_set.size(), a.simplex_set.size()));
316
317 set_intersection(simplex_set.cbegin(), simplex_set.cend(),
318 a.simplex_set.cbegin(), a.simplex_set.cend(),
319 std::back_inserter(v));
320
321 return (v.size() == 0);
322 }
323
324 bool operator==(const Skeleton_blocker_simplex& other) const {
325 return (this->simplex_set == other.simplex_set);
326 }
327
328 bool operator!=(const Skeleton_blocker_simplex& other) const {
329 return (this->simplex_set != other.simplex_set);
330 }
331
332 bool operator<(const Skeleton_blocker_simplex& other) const {
333 return (std::lexicographical_compare(this->simplex_set.begin(),
334 this->simplex_set.end(), other.begin(),
335 other.end()));
336 }
337
339
340 friend std::ostream& operator<<(std::ostream& o,
341 const Skeleton_blocker_simplex & sigma) {
342 bool first = true;
343 o << "{";
344 for (auto i : sigma) {
345 if (first)
346 first = false;
347 else
348 o << ",";
349 o << i;
350 }
351 o << "}";
352 return o;
353 }
354};
355
356} // namespace skeleton_blocker
357
358namespace skbl = skeleton_blocker;
359
360} // namespace Gudhi
361
362#endif // SKELETON_BLOCKER_SKELETON_BLOCKER_SIMPLEX_H_
Abstract simplex used in Skeleton blockers data-structure.
Definition: Skeleton_blocker_simplex.h:38
Definition: Skeleton_blocker_simplex.h:210
bool contains_difference(const Skeleton_blocker_simplex &a, T x, T y) const
Definition: Skeleton_blocker_simplex.h:287
void union_vertices(const Skeleton_blocker_simplex &a)
Definition: Skeleton_blocker_simplex.h:155
bool contains(const Skeleton_blocker_simplex &a) const
Definition: Skeleton_blocker_simplex.h:228
void intersection(const Skeleton_blocker_simplex &a)
Definition: Skeleton_blocker_simplex.h:124
Definition: Skeleton_blocker_simplex.h:84
Definition: Skeleton_blocker_simplex.h:220
Definition: Skeleton_blocker_simplex.h:117
bool contains_difference(const Skeleton_blocker_simplex &a, T x) const
Definition: Skeleton_blocker_simplex.h:262
bool contains_difference(const Skeleton_blocker_simplex &a, const Skeleton_blocker_simplex &b) const
Definition: Skeleton_blocker_simplex.h:236
void difference(const Skeleton_blocker_simplex &a)
Definition: Skeleton_blocker_simplex.h:139
Definition: Skeleton_blocker_simplex.h:197
Definition: Skeleton_blocker_simplex.h:110
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
