Persistence_vectors.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Pawel Dlotko
4 *
5 * Copyright (C) 2016 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef PERSISTENCE_VECTORS_H_
12#define PERSISTENCE_VECTORS_H_
13
14// gudhi include
15#include <gudhi/read_persistence_from_file.h>
16#include <gudhi/common_persistence_representations.h>
18
19#include <fstream>
20#include <cmath>
21#include <algorithm>
22#include <iostream>
23#include <limits>
24#include <functional>
25#include <utility>
26#include <vector>
27
28namespace Gudhi {
29namespace Persistence_representations {
30
31template <typename T>
32struct Maximum_distance {
33 double operator()(const std::pair<T, T>& f, const std::pair<T, T>& s) {
34 return std::max(fabs(f.first - s.first), fabs(f.second - s.second));
35 }
36};
37
53template <typename F>
55 public:
60
65 Vector_distances_in_diagram(const std::vector<std::pair<double, double> >& intervals, size_t where_to_cut);
66
71 Vector_distances_in_diagram(const char* filename, size_t where_to_cut,
72 unsigned dimension = std::numeric_limits<unsigned>::max());
73
77 template <typename K>
78 friend std::ostream& operator<<(std::ostream& out, const Vector_distances_in_diagram<K>& d) {
79 for (size_t i = 0; i != std::min(d.sorted_vector_of_distances.size(), d.where_to_cut); ++i) {
80 out << d.sorted_vector_of_distances[i] << " ";
81 }
82 return out;
83 }
84
88 inline double vector_in_position(size_t position) const {
89 if (position >= this->sorted_vector_of_distances.size())
90 throw("Wrong position in accessing Vector_distances_in_diagram::sorted_vector_of_distances\n");
91 return this->sorted_vector_of_distances[position];
92 }
93
97 inline size_t size() const { return this->sorted_vector_of_distances.size(); }
98
102 void write_to_file(const char* filename) const;
103
107 void print_to_file(const char* filename) const { this->write_to_file(filename); }
108
112 void load_from_file(const char* filename);
113
117 bool operator==(const Vector_distances_in_diagram& second) const {
118 if (this->sorted_vector_of_distances.size() != second.sorted_vector_of_distances.size()) return false;
119 for (size_t i = 0; i != this->sorted_vector_of_distances.size(); ++i) {
120 if (!almost_equal(this->sorted_vector_of_distances[i], second.sorted_vector_of_distances[i])) return false;
121 }
122 return true;
123 }
124
125 bool operator!=(const Vector_distances_in_diagram& second) const { return !(*this == second); }
126
127 // Implementations of functions for various concepts.
135 double project_to_R(int number_of_function) const;
140 size_t number_of_projections_to_R() const { return this->number_of_functions_for_projections_to_reals; }
141
145 std::vector<double> vectorize(int number_of_function) const;
150 size_t number_of_vectorize_functions() const { return this->number_of_functions_for_vectorization; }
151
155 void compute_average(const std::vector<Vector_distances_in_diagram*>& to_average);
156
161 double distance(const Vector_distances_in_diagram& second, double power = 1) const;
162
167 double compute_scalar_product(const Vector_distances_in_diagram& second) const;
168 // end of implementation of functions needed for concepts.
169
173 std::vector<double> output_for_visualization() const { return this->sorted_vector_of_distances; }
174
178 void plot(const char* filename) const {
179 std::stringstream gnuplot_script;
180 gnuplot_script << filename << "_GnuplotScript";
181 std::ofstream out;
182 out.open(gnuplot_script.str().c_str());
183 out << "set style data histogram" << std::endl;
184 out << "set style histogram cluster gap 1" << std::endl;
185 out << "set style fill solid border -1" << std::endl;
186 out << "plot '-' notitle" << std::endl;
187 for (size_t i = 0; i != this->sorted_vector_of_distances.size(); ++i) {
188 out << this->sorted_vector_of_distances[i] << std::endl;
189 }
190 out << std::endl;
191 out.close();
192 std::clog << "To visualize, install gnuplot and type the command: gnuplot -persist -e \"load \'"
193 << gnuplot_script.str().c_str() << "\'\"" << std::endl;
194 }
195
199 std::pair<double, double> get_x_range() const { return std::make_pair(0, this->sorted_vector_of_distances.size()); }
200
204 std::pair<double, double> get_y_range() const {
205 if (this->sorted_vector_of_distances.size() == 0) return std::make_pair(0, 0);
206 return std::make_pair(this->sorted_vector_of_distances[0], 0);
207 }
208
209 // arithmetic operations:
210 template <typename Operation_type>
211 friend Vector_distances_in_diagram operation_on_pair_of_vectors(const Vector_distances_in_diagram& first,
212 const Vector_distances_in_diagram& second,
213 Operation_type opertion) {
215 // Operation_type operation;
216 result.sorted_vector_of_distances.reserve(
217 std::max(first.sorted_vector_of_distances.size(), second.sorted_vector_of_distances.size()));
218 for (size_t i = 0; i != std::min(first.sorted_vector_of_distances.size(), second.sorted_vector_of_distances.size());
219 ++i) {
220 result.sorted_vector_of_distances.push_back(
221 opertion(first.sorted_vector_of_distances[i], second.sorted_vector_of_distances[i]));
222 }
223 if (first.sorted_vector_of_distances.size() ==
224 std::min(first.sorted_vector_of_distances.size(), second.sorted_vector_of_distances.size())) {
225 for (size_t i = std::min(first.sorted_vector_of_distances.size(), second.sorted_vector_of_distances.size());
226 i != std::max(first.sorted_vector_of_distances.size(), second.sorted_vector_of_distances.size()); ++i) {
227 result.sorted_vector_of_distances.push_back(opertion(0, second.sorted_vector_of_distances[i]));
228 }
229 } else {
230 for (size_t i = std::min(first.sorted_vector_of_distances.size(), second.sorted_vector_of_distances.size());
231 i != std::max(first.sorted_vector_of_distances.size(), second.sorted_vector_of_distances.size()); ++i) {
232 result.sorted_vector_of_distances.push_back(opertion(first.sorted_vector_of_distances[i], 0));
233 }
234 }
235 return result;
236 } // operation_on_pair_of_vectors
237
243 result.sorted_vector_of_distances.reserve(this->sorted_vector_of_distances.size());
244 for (size_t i = 0; i != this->sorted_vector_of_distances.size(); ++i) {
245 result.sorted_vector_of_distances.push_back(scalar * this->sorted_vector_of_distances[i]);
246 }
247 return result;
248 } // multiply_by_scalar
249
254 const Vector_distances_in_diagram& second) {
255 return operation_on_pair_of_vectors(first, second, std::plus<double>());
256 }
261 const Vector_distances_in_diagram& second) {
262 return operation_on_pair_of_vectors(first, second, std::minus<double>());
263 }
268 return A.multiply_by_scalar(scalar);
269 }
274 return A.multiply_by_scalar(scalar);
275 }
279 Vector_distances_in_diagram operator*(double scalar) { return this->multiply_by_scalar(scalar); }
284 *this = *this + rhs;
285 return *this;
286 }
291 *this = *this - rhs;
292 return *this;
293 }
298 *this = *this * x;
299 return *this;
300 }
305 if (x == 0) throw("In operator /=, division by 0. Program terminated.");
306 *this = *this * (1 / x);
307 return *this;
308 }
309
310 private:
311 std::vector<std::pair<double, double> > intervals;
312 std::vector<double> sorted_vector_of_distances;
313 size_t number_of_functions_for_vectorization;
314 size_t number_of_functions_for_projections_to_reals;
315 size_t where_to_cut;
316
317 void compute_sorted_vector_of_distances_via_heap(size_t where_to_cut);
318 void compute_sorted_vector_of_distances_via_vector_sorting(size_t where_to_cut);
319
320 Vector_distances_in_diagram(const std::vector<double>& sorted_vector_of_distances_)
321 : sorted_vector_of_distances(sorted_vector_of_distances_) {
322 this->set_up_numbers_of_functions_for_vectorization_and_projections_to_reals();
323 }
324
325 void set_up_numbers_of_functions_for_vectorization_and_projections_to_reals() {
326 // warning, this function can be only called after filling in the intervals vector.
327 this->number_of_functions_for_vectorization = this->sorted_vector_of_distances.size();
328 this->number_of_functions_for_projections_to_reals = this->sorted_vector_of_distances.size();
329 }
330};
331
332template <typename F>
333Vector_distances_in_diagram<F>::Vector_distances_in_diagram(const std::vector<std::pair<double, double> >& intervals_,
334 size_t where_to_cut_)
335 : where_to_cut(where_to_cut_) {
336 std::vector<std::pair<double, double> > i(intervals_);
337 this->intervals = i;
338 // this->compute_sorted_vector_of_distances_via_heap( where_to_cut );
339 this->compute_sorted_vector_of_distances_via_vector_sorting(where_to_cut);
340 this->set_up_numbers_of_functions_for_vectorization_and_projections_to_reals();
341}
342
343template <typename F>
344Vector_distances_in_diagram<F>::Vector_distances_in_diagram(const char* filename, size_t where_to_cut,
345 unsigned dimension)
346 : where_to_cut(where_to_cut) {
347 std::vector<std::pair<double, double> > intervals;
348 if (dimension == std::numeric_limits<unsigned>::max()) {
349 intervals = read_persistence_intervals_in_one_dimension_from_file(filename);
350 } else {
351 intervals = read_persistence_intervals_in_one_dimension_from_file(filename, dimension);
352 }
353 this->intervals = intervals;
354 this->compute_sorted_vector_of_distances_via_heap(where_to_cut);
355 // this->compute_sorted_vector_of_distances_via_vector_sorting( where_to_cut );
356 set_up_numbers_of_functions_for_vectorization_and_projections_to_reals();
357}
358
359template <typename F>
361 bool dbg = false;
362 if (dbg) {
363 std::clog << "Here are the intervals : \n";
364 for (size_t i = 0; i != this->intervals.size(); ++i) {
365 std::clog << this->intervals[i].first << " , " << this->intervals[i].second << std::endl;
366 }
367 }
368 where_to_cut = std::min(
369 where_to_cut, (size_t)(0.5 * this->intervals.size() * (this->intervals.size() - 1) + this->intervals.size()));
370
371 std::vector<double> heap(where_to_cut, std::numeric_limits<int>::max());
372 std::make_heap(heap.begin(), heap.end());
373 F f;
374
375 // for every pair of points in the diagram, compute the minimum of their distance, and distance of those points from
376 // diagonal
377 for (size_t i = 0; i < this->intervals.size(); ++i) {
378 for (size_t j = i + 1; j < this->intervals.size(); ++j) {
379 double value = std::min(
380 f(this->intervals[i], this->intervals[j]),
381 std::min(
382 f(this->intervals[i], std::make_pair(0.5 * (this->intervals[i].first + this->intervals[i].second),
383 0.5 * (this->intervals[i].first + this->intervals[i].second))),
384 f(this->intervals[j], std::make_pair(0.5 * (this->intervals[j].first + this->intervals[j].second),
385 0.5 * (this->intervals[j].first + this->intervals[j].second)))));
386
387 if (dbg) {
388 std::clog << "Value : " << value << std::endl;
389 std::clog << "heap.front() : " << heap.front() << std::endl;
390 getchar();
391 }
392
393 if (-value < heap.front()) {
394 if (dbg) {
395 std::clog << "Replacing : " << heap.front() << " with : " << -value << std::endl;
396 getchar();
397 }
398 // remove the first element from the heap
399 std::pop_heap(heap.begin(), heap.end());
400 // heap.pop_back();
401 // and put value there instead:
402 // heap.push_back(-value);
403 heap[where_to_cut - 1] = -value;
404 std::push_heap(heap.begin(), heap.end());
405 }
406 }
407 }
408
409 // now add distances of all points from diagonal
410 for (size_t i = 0; i < this->intervals.size(); ++i) {
411 double value = f(this->intervals[i], std::make_pair(0.5 * (this->intervals[i].first + this->intervals[i].second),
412 0.5 * (this->intervals[i].first + this->intervals[i].second)));
413 if (-value < heap.front()) {
414 // remove the first element from the heap
415 std::pop_heap(heap.begin(), heap.end());
416 // heap.pop_back();
417 // and put value there instead:
418 // heap.push_back(-value);
419 heap[where_to_cut - 1] = -value;
420 std::push_heap(heap.begin(), heap.end());
421 }
422 }
423
424 std::sort_heap(heap.begin(), heap.end());
425 for (size_t i = 0; i != heap.size(); ++i) {
426 if (heap[i] == std::numeric_limits<int>::max()) {
427 heap[i] = 0;
428 } else {
429 heap[i] *= -1;
430 }
431 }
432
433 if (dbg) {
434 std::clog << "This is the heap after all the operations :\n";
435 for (size_t i = 0; i != heap.size(); ++i) {
436 std::clog << heap[i] << " ";
437 }
438 std::clog << std::endl;
439 }
440
441 this->sorted_vector_of_distances = heap;
442}
443
444template <typename F>
446 std::vector<double> distances;
447 distances.reserve((size_t)(0.5 * this->intervals.size() * (this->intervals.size() - 1) + this->intervals.size()));
448 F f;
449
450 // for every pair of points in the diagram, compute the minimum of their distance, and distance of those points from
451 // diagonal
452 for (size_t i = 0; i < this->intervals.size(); ++i) {
453 // add distance of i-th point in the diagram from the diagonal to the distances vector
454 distances.push_back(
455 f(this->intervals[i], std::make_pair(0.5 * (this->intervals[i].first + this->intervals[i].second),
456 0.5 * (this->intervals[i].first + this->intervals[i].second))));
457 for (size_t j = i + 1; j < this->intervals.size(); ++j) {
458 double value = std::min(
459 f(this->intervals[i], this->intervals[j]),
460 std::min(
461 f(this->intervals[i], std::make_pair(0.5 * (this->intervals[i].first + this->intervals[i].second),
462 0.5 * (this->intervals[i].first + this->intervals[i].second))),
463 f(this->intervals[j], std::make_pair(0.5 * (this->intervals[j].first + this->intervals[j].second),
464 0.5 * (this->intervals[j].first + this->intervals[j].second)))));
465 distances.push_back(value);
466 }
467 }
468 std::sort(distances.begin(), distances.end(), std::greater<double>());
469 if (distances.size() > where_to_cut) distances.resize(where_to_cut);
470
471 this->sorted_vector_of_distances = distances;
472}
473
474// Implementations of functions for various concepts.
475template <typename F>
476double Vector_distances_in_diagram<F>::project_to_R(int number_of_function) const {
477 if ((size_t)number_of_function > this->number_of_functions_for_projections_to_reals)
478 throw "Wrong index of a function in a method Vector_distances_in_diagram<F>::project_to_R";
479 if (number_of_function < 0)
480 throw "Wrong index of a function in a method Vector_distances_in_diagram<F>::project_to_R";
481
482 double result = 0;
483 for (size_t i = 0; i != (size_t)number_of_function; ++i) {
484 result += sorted_vector_of_distances[i];
485 }
486 return result;
487}
488
489template <typename F>
490void Vector_distances_in_diagram<F>::compute_average(const std::vector<Vector_distances_in_diagram*>& to_average) {
491 if (to_average.size() == 0) {
493 return;
494 }
495
496 size_t maximal_length_of_vector = 0;
497 for (size_t i = 0; i != to_average.size(); ++i) {
498 if (to_average[i]->sorted_vector_of_distances.size() > maximal_length_of_vector) {
499 maximal_length_of_vector = to_average[i]->sorted_vector_of_distances.size();
500 }
501 }
502
503 std::vector<double> av(maximal_length_of_vector, 0);
504 for (size_t i = 0; i != to_average.size(); ++i) {
505 for (size_t j = 0; j != to_average[i]->sorted_vector_of_distances.size(); ++j) {
506 av[j] += to_average[i]->sorted_vector_of_distances[j];
507 }
508 }
509
510 for (size_t i = 0; i != maximal_length_of_vector; ++i) {
511 av[i] /= static_cast<double>(to_average.size());
512 }
513 this->sorted_vector_of_distances = av;
514 this->where_to_cut = av.size();
515}
516
517template <typename F>
519 bool dbg = false;
520
521 if (dbg) {
522 std::clog << "Entering double Vector_distances_in_diagram<F>::distance( const Abs_Topological_data_with_distances* "
523 "second , double power ) procedure \n";
524 std::clog << "Power : " << power << std::endl;
525 std::clog << "This : " << *this << std::endl;
526 std::clog << "second : " << second_ << std::endl;
527 }
528
529 double result = 0;
530 for (size_t i = 0; i != std::min(this->sorted_vector_of_distances.size(), second_.sorted_vector_of_distances.size());
531 ++i) {
532 if (power == 1) {
533 if (dbg) {
534 std::clog << "|" << this->sorted_vector_of_distances[i] << " - " << second_.sorted_vector_of_distances[i]
535 << " | : " << fabs(this->sorted_vector_of_distances[i] - second_.sorted_vector_of_distances[i])
536 << std::endl;
537 }
538 result += fabs(this->sorted_vector_of_distances[i] - second_.sorted_vector_of_distances[i]);
539 } else {
540 if (power < std::numeric_limits<double>::max()) {
541 result += std::pow(fabs(this->sorted_vector_of_distances[i] - second_.sorted_vector_of_distances[i]), power);
542 } else {
543 // max norm
544 if (result < fabs(this->sorted_vector_of_distances[i] - second_.sorted_vector_of_distances[i]))
545 result = fabs(this->sorted_vector_of_distances[i] - second_.sorted_vector_of_distances[i]);
546 }
547 if (dbg) {
548 std::clog << "| " << this->sorted_vector_of_distances[i] << " - " << second_.sorted_vector_of_distances[i]
549 << " : " << fabs(this->sorted_vector_of_distances[i] - second_.sorted_vector_of_distances[i])
550 << std::endl;
551 }
552 }
553 }
554 if (this->sorted_vector_of_distances.size() != second_.sorted_vector_of_distances.size()) {
555 if (this->sorted_vector_of_distances.size() > second_.sorted_vector_of_distances.size()) {
556 for (size_t i = second_.sorted_vector_of_distances.size(); i != this->sorted_vector_of_distances.size(); ++i) {
557 result += fabs(this->sorted_vector_of_distances[i]);
558 }
559 } else {
560 // this->sorted_vector_of_distances.size() < second_.sorted_vector_of_distances.size()
561 for (size_t i = this->sorted_vector_of_distances.size(); i != second_.sorted_vector_of_distances.size(); ++i) {
562 result += fabs(second_.sorted_vector_of_distances[i]);
563 }
564 }
565 }
566
567 if (power != 1) {
568 result = std::pow(result, (1.0 / power));
569 }
570 return result;
571}
572
573template <typename F>
574std::vector<double> Vector_distances_in_diagram<F>::vectorize(int number_of_function) const {
575 if ((size_t)number_of_function > this->number_of_functions_for_vectorization)
576 throw "Wrong index of a function in a method Vector_distances_in_diagram<F>::vectorize";
577 if (number_of_function < 0) throw "Wrong index of a function in a method Vector_distances_in_diagram<F>::vectorize";
578
579 std::vector<double> result(std::min((size_t)number_of_function, this->sorted_vector_of_distances.size()));
580 for (size_t i = 0; i != std::min((size_t)number_of_function, this->sorted_vector_of_distances.size()); ++i) {
581 result[i] = this->sorted_vector_of_distances[i];
582 }
583 return result;
584}
585
586template <typename F>
587void Vector_distances_in_diagram<F>::write_to_file(const char* filename) const {
588 std::ofstream out;
589 out.open(filename);
590
591 for (size_t i = 0; i != this->sorted_vector_of_distances.size(); ++i) {
592 out << this->sorted_vector_of_distances[i] << " ";
593 }
594
595 out.close();
596}
597
598template <typename F>
600 std::ifstream in;
601 in.open(filename);
602 // check if the file exist.
603 if (!in.good()) {
604 std::cerr << "The file : " << filename << " do not exist. The program will now terminate \n";
605 throw "The persistence landscape file do not exist. The program will now terminate \n";
606 }
607
608 double number;
609 while (in >> number) {
610 this->sorted_vector_of_distances.push_back(number);
611 }
612 in.close();
613}
614
615template <typename F>
617 double result = 0;
618 for (size_t i = 0;
619 i != std::min(this->sorted_vector_of_distances.size(), second_vector.sorted_vector_of_distances.size()); ++i) {
620 result += this->sorted_vector_of_distances[i] * second_vector.sorted_vector_of_distances[i];
621 }
622 return result;
623}
624
625} // namespace Persistence_representations
626} // namespace Gudhi
627
628#endif // PERSISTENCE_VECTORS_H_
A class implementing persistence vectors.
Definition: Persistence_vectors.h:54
bool operator==(const Vector_distances_in_diagram &second) const
Definition: Persistence_vectors.h:117
Definition: Persistence_vectors.h:88
void plot(const char *filename) const
Definition: Persistence_vectors.h:178
Definition: Persistence_vectors.h:476
Vector_distances_in_diagram operator+=(const Vector_distances_in_diagram &rhs)
Definition: Persistence_vectors.h:283
void compute_average(const std::vector< Vector_distances_in_diagram * > &to_average)
Definition: Persistence_vectors.h:490
double compute_scalar_product(const Vector_distances_in_diagram &second) const
Definition: Persistence_vectors.h:616
std::pair< double, double > get_x_range() const
Definition: Persistence_vectors.h:199
void load_from_file(const char *filename)
Definition: Persistence_vectors.h:599
Vector_distances_in_diagram operator*=(double x)
Definition: Persistence_vectors.h:297
void write_to_file(const char *filename) const
Definition: Persistence_vectors.h:587
std::pair< double, double > get_y_range() const
Definition: Persistence_vectors.h:204
friend std::ostream & operator<<(std::ostream &out, const Vector_distances_in_diagram< K > &d)
Definition: Persistence_vectors.h:78
std::vector< double > output_for_visualization() const
Definition: Persistence_vectors.h:173
void print_to_file(const char *filename) const
Definition: Persistence_vectors.h:107
double distance(const Vector_distances_in_diagram &second, double power=1) const
Definition: Persistence_vectors.h:518
Vector_distances_in_diagram operator/=(double x)
Definition: Persistence_vectors.h:304
Definition: Persistence_vectors.h:140
size_t size() const
Definition: Persistence_vectors.h:97
Definition: Persistence_vectors.h:150
friend Vector_distances_in_diagram operator*(const Vector_distances_in_diagram &A, double scalar)
Definition: Persistence_vectors.h:273
Definition: Persistence_vectors.h:279
friend Vector_distances_in_diagram operator*(double scalar, const Vector_distances_in_diagram &A)
Definition: Persistence_vectors.h:267
friend Vector_distances_in_diagram operator+(const Vector_distances_in_diagram &first, const Vector_distances_in_diagram &second)
Definition: Persistence_vectors.h:253
Vector_distances_in_diagram()
Vector_distances_in_diagram operator-=(const Vector_distances_in_diagram &rhs)
Definition: Persistence_vectors.h:290
Vector_distances_in_diagram multiply_by_scalar(double scalar) const
Definition: Persistence_vectors.h:241
std::vector< double > vectorize(int number_of_function) const
Definition: Persistence_vectors.h:574
friend Vector_distances_in_diagram operator-(const Vector_distances_in_diagram &first, const Vector_distances_in_diagram &second)
Definition: Persistence_vectors.h:260
Global distance functions.
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
