Persistence_heat_maps.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Pawel Dlotko and Mathieu Carriere
4 *
5 * Modifications:
6 * - 2018/04 MC: Add discrete/non-discrete mechanism and non-discrete version
7 *
8 * Copyright (C) 2019 Inria
9 *
10 * Modification(s):
11 * - YYYY/MM Author: Description of the modification
12 */
13
14#ifndef PERSISTENCE_HEAT_MAPS_H_
15#define PERSISTENCE_HEAT_MAPS_H_
16
17// gudhi include
18#include <gudhi/read_persistence_from_file.h>
19#include <gudhi/common_persistence_representations.h>
20
21// standard include
22#include <vector>
23#include <sstream>
24#include <iostream>
25#include <cmath>
26#include <limits>
27#include <algorithm>
28#include <utility>
29#include <string>
30#include <functional>
31
32namespace Gudhi {
33namespace Persistence_representations {
34
39std::vector<std::vector<double> > create_Gaussian_filter(size_t pixel_radius, double sigma) {
40 bool dbg = false;
41 // we are computing the kernel mask to 2 standard deviations away from the center. We discretize it in a grid of a
42 // size 2*pixel_radius times 2*pixel_radius.
43
44 double r = 0;
45 double sigma_sqr = sigma * sigma;
46
47 // sum is for normalization
48 double sum = 0;
49
50 // initialization of a kernel:
51 std::vector<std::vector<double> > kernel(2 * pixel_radius + 1);
52 for (size_t i = 0; i != kernel.size(); ++i) {
53 std::vector<double> v(2 * pixel_radius + 1, 0);
54 kernel[i] = v;
55 }
56
57 if (dbg) {
58 std::clog << "Kernel initialize \n";
59 std::clog << "pixel_radius : " << pixel_radius << std::endl;
60 std::clog << "kernel.size() : " << kernel.size() << std::endl;
61 getchar();
62 }
63
64 for (int x = -pixel_radius; x <= static_cast<int>(pixel_radius); x++) {
65 for (int y = -pixel_radius; y <= static_cast<int>(pixel_radius); y++) {
66 double real_x = 2 * sigma * x / pixel_radius;
67 double real_y = 2 * sigma * y / pixel_radius;
68 r = std::sqrt(real_x * real_x + real_y * real_y);
69 kernel[x + pixel_radius][y + pixel_radius] = (exp(-(r * r) / sigma_sqr)) / (3.141592 * sigma_sqr);
70 sum += kernel[x + pixel_radius][y + pixel_radius];
71 }
72 }
73
74 // normalize the kernel
75 for (size_t i = 0; i != kernel.size(); ++i) {
76 for (size_t j = 0; j != kernel[i].size(); ++j) {
77 kernel[i][j] /= sum;
78 }
79 }
80
81 if (dbg) {
82 std::clog << "Here is the kernel : \n";
83 for (size_t i = 0; i != kernel.size(); ++i) {
84 for (size_t j = 0; j != kernel[i].size(); ++j) {
85 std::clog << kernel[i][j] << " ";
86 }
87 std::clog << std::endl;
88 }
89 }
90 return kernel;
91}
92
93/*
94 * There are various options to scale the points depending on their location. One can for instance:
95 * (1) do nothing (scale all of them with the weight 1), as in the function constant_function
96 * (2) Scale them by the distance to the diagonal. This is implemented in function
97 * (3) Scale them with the square of their distance to diagonal. This is implemented in function
98 * (4) Scale them with
99 */
100
107 public:
108 double operator()(const std::pair<double, double>& point_in_diagram) { return 1; }
109};
110
117 public:
118 double operator()(const std::pair<double, double>& point_in_diagram) {
119 // (point_in_diagram.first+point_in_diagram.second)/2.0
120 return std::sqrt(std::pow((point_in_diagram.first - (point_in_diagram.first + point_in_diagram.second) / 2.0), 2) +
121 std::pow((point_in_diagram.second - (point_in_diagram.first + point_in_diagram.second) / 2.0), 2));
122 }
123};
124
131 public:
132 double operator()(const std::pair<double, double>& point_in_diagram) {
133 return std::pow((point_in_diagram.first - (point_in_diagram.first + point_in_diagram.second) / 2.0), 2) +
134 std::pow((point_in_diagram.second - (point_in_diagram.first + point_in_diagram.second) / 2.0), 2);
135 }
136};
137
144 public:
145 double operator()(const std::pair<double, double>& point_in_diagram) {
146 return atan(point_in_diagram.second - point_in_diagram.first);
147 }
148};
149
158 public:
159 weight_by_setting_maximal_interval_to_have_length_one(double len) : length_of_maximal_interval(len) {}
160 double operator()(const std::pair<double, double>& point_in_diagram) {
161 return (point_in_diagram.second - point_in_diagram.first) / this->length_of_maximal_interval;
162 }
163
164 private:
165 double length_of_maximal_interval;
166};
167
175// This class implements the following concepts: Vectorized_topological_data, Topological_data_with_distances,
176// Real_valued_topological_data, Topological_data_with_averages, Topological_data_with_scalar_product
177template <typename Scalling_of_kernels = constant_scaling_function>
179 public:
185 Scalling_of_kernels f;
186 this->f = f;
187 this->erase_below_diagonal = false;
188 this->min_ = this->max_ = 0;
189 this->set_up_parameters_for_basic_classes();
190 }
191
205 Persistence_heat_maps(const std::vector<std::pair<double, double> >& interval,
206 std::vector<std::vector<double> > filter = create_Gaussian_filter(5, 1),
207 bool erase_below_diagonal = false, size_t number_of_pixels = 1000,
208 double min_ = std::numeric_limits<double>::max(),
209 double max_ = std::numeric_limits<double>::max());
210
232 Persistence_heat_maps(const char* filename, std::vector<std::vector<double> > filter = create_Gaussian_filter(5, 1),
233 bool erase_below_diagonal = false, size_t number_of_pixels = 1000,
234 double min_ = std::numeric_limits<double>::max(),
235 double max_ = std::numeric_limits<double>::max(),
236 unsigned dimension = std::numeric_limits<unsigned>::max());
237
242 Persistence_heat_maps(const std::vector<std::pair<double, double> >& interval,
243 const std::function<double(std::pair<double, double>, std::pair<double, double>)>& kernel,
244 size_t number_of_x_pixels, size_t number_of_y_pixels, double min_x = 0, double max_x = 1,
245 double min_y = 0, double max_y = 1);
246
250 Persistence_heat_maps(const std::vector<std::pair<double, double> >& interval,
251 const std::function<double(std::pair<double, double>, std::pair<double, double>)>& kernel);
252
258 void compute_mean(const std::vector<Persistence_heat_maps*>& maps);
259
265 void compute_median(const std::vector<Persistence_heat_maps*>& maps);
266
270 void compute_percentage_of_active(const std::vector<Persistence_heat_maps*>& maps, size_t cutoff = 1);
271
272 // put to file subroutine
278 void print_to_file(const char* filename) const;
279
284 void load_from_file(const char* filename);
285
289 inline bool check_if_the_same(const Persistence_heat_maps& second) const {
290 bool dbg = false;
291 if (this->heat_map.size() != second.heat_map.size()) {
292 if (dbg)
293 std::clog << "this->heat_map.size() : " << this->heat_map.size()
294 << " \n second.heat_map.size() : " << second.heat_map.size() << std::endl;
295 return false;
296 }
297 if (this->min_ != second.min_) {
298 if (dbg) std::clog << "this->min_ : " << this->min_ << ", second.min_ : " << second.min_ << std::endl;
299 return false;
300 }
301 if (this->max_ != second.max_) {
302 if (dbg) std::clog << "this->max_ : " << this->max_ << ", second.max_ : " << second.max_ << std::endl;
303 return false;
304 }
305 // in the other case we may assume that the persistence images are defined on the same domain.
306 return true;
307 }
308
312 inline double get_min() const { return this->min_; }
313
317 inline double get_max() const { return this->max_; }
318
322 bool operator==(const Persistence_heat_maps& rhs) const {
323 bool dbg = false;
324 if (!this->check_if_the_same(rhs)) {
325 if (dbg) std::clog << "The domains are not the same \n";
326 return false; // in this case, the domains are not the same, so the maps cannot be the same.
327 }
328 for (size_t i = 0; i != this->heat_map.size(); ++i) {
329 for (size_t j = 0; j != this->heat_map[i].size(); ++j) {
330 if (!almost_equal(this->heat_map[i][j], rhs.heat_map[i][j])) {
331 if (dbg) {
332 std::clog << "this->heat_map[" << i << "][" << j << "] = " << this->heat_map[i][j] << std::endl;
333 std::clog << "rhs.heat_map[" << i << "][" << j << "] = " << rhs.heat_map[i][j] << std::endl;
334 }
335 return false;
336 }
337 }
338 }
339 return true;
340 }
341
345 bool operator!=(const Persistence_heat_maps& rhs) const { return !((*this) == rhs); }
346
350 void plot(const char* filename) const;
351
352 template <typename Operation_type>
353 friend Persistence_heat_maps operation_on_pair_of_heat_maps(const Persistence_heat_maps& first,
354 const Persistence_heat_maps& second,
355 Operation_type operation) {
356 // first check if the heat maps are compatible
357 if (!first.check_if_the_same(second)) {
358 std::cerr << "Sizes of the heat maps are not compatible. The program will now terminate \n";
359 throw "Sizes of the heat maps are not compatible. The program will now terminate \n";
360 }
362 result.min_ = first.min_;
363 result.max_ = first.max_;
364 result.heat_map.reserve(first.heat_map.size());
365 for (size_t i = 0; i != first.heat_map.size(); ++i) {
366 std::vector<double> v;
367 v.reserve(first.heat_map[i].size());
368 for (size_t j = 0; j != first.heat_map[i].size(); ++j) {
369 v.push_back(operation(first.heat_map[i][j], second.heat_map[i][j]));
370 }
371 result.heat_map.push_back(v);
372 }
373 return result;
374 } // operation_on_pair_of_heat_maps
375
382 result.min_ = this->min_;
383 result.max_ = this->max_;
384 result.heat_map.reserve(this->heat_map.size());
385 for (size_t i = 0; i != this->heat_map.size(); ++i) {
386 std::vector<double> v;
387 v.reserve(this->heat_map[i].size());
388 for (size_t j = 0; j != this->heat_map[i].size(); ++j) {
389 v.push_back(this->heat_map[i][j] * scalar);
390 }
391 result.heat_map.push_back(v);
392 }
393 return result;
394 }
395
400 return operation_on_pair_of_heat_maps(first, second, std::plus<double>());
401 }
406 return operation_on_pair_of_heat_maps(first, second, std::minus<double>());
407 }
411 friend Persistence_heat_maps operator*(double scalar, const Persistence_heat_maps& A) {
412 return A.multiply_by_scalar(scalar);
413 }
417 friend Persistence_heat_maps operator*(const Persistence_heat_maps& A, double scalar) {
418 return A.multiply_by_scalar(scalar);
419 }
423 Persistence_heat_maps operator*(double scalar) { return this->multiply_by_scalar(scalar); }
428 *this = *this + rhs;
429 return *this;
430 }
435 *this = *this - rhs;
436 return *this;
437 }
442 *this = *this * x;
443 return *this;
444 }
449 if (x == 0) throw("In operator /=, division by 0. Program terminated.");
450 *this = *this * (1 / x);
451 return *this;
452 }
453
454 // Implementations of functions for various concepts.
455
460 std::vector<double> vectorize(int number_of_function) const;
465 size_t number_of_vectorize_functions() const { return this->number_of_functions_for_vectorization; }
466
474 double project_to_R(int number_of_function) const;
479 size_t number_of_projections_to_R() const { return this->number_of_functions_for_projections_to_reals; }
480
487 double distance(const Persistence_heat_maps& second_, double power = 1) const;
488
493 void compute_average(const std::vector<Persistence_heat_maps*>& to_average);
494
500 double compute_scalar_product(const Persistence_heat_maps& second_) const;
501
502 // end of implementation of functions needed for concepts.
503
507 std::pair<double, double> get_x_range() const { return std::make_pair(this->min_, this->max_); }
508
512 std::pair<double, double> get_y_range() const { return this->get_x_range(); }
513
514 protected:
515 // private methods
516 std::vector<std::vector<double> > check_and_initialize_maps(const std::vector<Persistence_heat_maps*>& maps);
517 size_t number_of_functions_for_vectorization;
518 size_t number_of_functions_for_projections_to_reals;
519 void construct(const std::vector<std::pair<double, double> >& intervals_,
520 std::vector<std::vector<double> > filter = create_Gaussian_filter(5, 1),
521 bool erase_below_diagonal = false, size_t number_of_pixels = 1000,
522 double min_ = std::numeric_limits<double>::max(), double max_ = std::numeric_limits<double>::max());
523
524 void set_up_parameters_for_basic_classes() {
525 this->number_of_functions_for_vectorization = 1;
526 this->number_of_functions_for_projections_to_reals = 1;
527 }
528
529 // Boolean indicating if we are computing persistence image (true) or persistence weighted gaussian kernel (false)
530 bool discrete = true;
531 std::function<double(std::pair<double, double>, std::pair<double, double>)> kernel;
532 std::vector<std::pair<double, double> > interval;
533 std::vector<double> weights;
534
535 // data
536 Scalling_of_kernels f;
537 bool erase_below_diagonal;
538 double min_;
539 double max_;
540 std::vector<std::vector<double> > heat_map;
541};
542
543template <typename Scalling_of_kernels>
545 const std::vector<std::pair<double, double> >& interval,
546 const std::function<double(std::pair<double, double>, std::pair<double, double>)>& kernel,
547 size_t number_of_x_pixels, size_t number_of_y_pixels, double min_x, double max_x, double min_y, double max_y) {
548 this->discrete = true;
549 this->min_ = min_x;
550 this->max_ = max_x;
551 this->heat_map.resize(number_of_y_pixels);
552 double step_x = (max_x - min_x) / (number_of_x_pixels - 1);
553 double step_y = (max_y - min_y) / (number_of_y_pixels - 1);
554
555 int num_pts = interval.size();
556 for (size_t i = 0; i < number_of_y_pixels; i++) {
557 double y = min_y + i * step_y;
558 this->heat_map[i].reserve(number_of_x_pixels);
559 for (size_t j = 0; j < number_of_x_pixels; j++) {
560 double x = min_x + j * step_x;
561 std::pair<double, double> grid_point(x, y);
562 double pixel_value = 0;
563 for (int k = 0; k < num_pts; k++) pixel_value += this->f(interval[k]) * kernel(interval[k], grid_point);
564 this->heat_map[i].push_back(pixel_value);
565 }
566 }
567 this->set_up_parameters_for_basic_classes();
568}
569
570template <typename Scalling_of_kernels>
572 const std::vector<std::pair<double, double> >& interval,
573 const std::function<double(std::pair<double, double>, std::pair<double, double>)>& kernel) {
574 this->discrete = false;
575 this->interval = interval;
576 this->kernel = kernel;
577 int num_pts = this->interval.size();
578 for (int i = 0; i < num_pts; i++) this->weights.push_back(this->f(this->interval[i]));
579 this->set_up_parameters_for_basic_classes();
580}
581
582// if min_ == max_, then the program is requested to set up the values itself based on persistence intervals
583template <typename Scalling_of_kernels>
584void Persistence_heat_maps<Scalling_of_kernels>::construct(const std::vector<std::pair<double, double> >& intervals_,
585 std::vector<std::vector<double> > filter,
586 bool erase_below_diagonal, size_t number_of_pixels,
587 double min_, double max_) {
588 bool dbg = false;
589 if (dbg) std::clog << "Entering construct procedure \n";
590 Scalling_of_kernels f;
591 this->f = f;
592
593 if (dbg) std::clog << "min and max passed to construct() procedure: " << min_ << " " << max_ << std::endl;
594
595 if (min_ == max_) {
596 if (dbg) std::clog << "min and max parameters will be determined based on intervals \n";
597 // in this case, we want the program to set up the min_ and max_ values by itself.
598 min_ = std::numeric_limits<int>::max();
599 max_ = -std::numeric_limits<int>::max();
600
601 for (size_t i = 0; i != intervals_.size(); ++i) {
602 if (intervals_[i].first < min_) min_ = intervals_[i].first;
603 if (intervals_[i].second > max_) max_ = intervals_[i].second;
604 }
605 // now we have the structure filled in, and moreover we know min_ and max_ values of the interval, so we know the
606 // range.
607
608 // add some more space:
609 min_ -= fabs(max_ - min_) / 100;
610 max_ += fabs(max_ - min_) / 100;
611 }
612
613 if (dbg) {
614 std::clog << "min_ : " << min_ << std::endl;
615 std::clog << "max_ : " << max_ << std::endl;
616 std::clog << "number_of_pixels : " << number_of_pixels << std::endl;
617 getchar();
618 }
619
620 this->min_ = min_;
621 this->max_ = max_;
622
623 // initialization of the structure heat_map
624 std::vector<std::vector<double> > heat_map_;
625 for (size_t i = 0; i != number_of_pixels; ++i) {
626 std::vector<double> v(number_of_pixels, 0);
627 heat_map_.push_back(v);
628 }
629 this->heat_map = heat_map_;
630
631 if (dbg) std::clog << "Done creating of the heat map, now we will fill in the structure \n";
632
633 for (size_t pt_nr = 0; pt_nr != intervals_.size(); ++pt_nr) {
634 // compute the value of intervals_[pt_nr] in the grid:
635 int x_grid =
636 static_cast<int>((intervals_[pt_nr].first - this->min_) / (this->max_ - this->min_) * number_of_pixels);
637 int y_grid =
638 static_cast<int>((intervals_[pt_nr].second - this->min_) / (this->max_ - this->min_) * number_of_pixels);
639
640 if (dbg) {
641 std::clog << "point : " << intervals_[pt_nr].first << " , " << intervals_[pt_nr].second << std::endl;
642 std::clog << "x_grid : " << x_grid << std::endl;
643 std::clog << "y_grid : " << y_grid << std::endl;
644 }
645
646 // x_grid and y_grid gives a center of the kernel. We want to have its lower left corner. To get this, we need to
647 // shift x_grid and y_grid by a grid diameter.
648 x_grid -= filter.size() / 2;
649 y_grid -= filter.size() / 2;
650 // note that the numbers x_grid and y_grid may be negative.
651
652 if (dbg) {
653 std::clog << "After shift : \n";
654 std::clog << "x_grid : " << x_grid << std::endl;
655 std::clog << "y_grid : " << y_grid << std::endl;
656 }
657
658 double scaling_value = this->f(intervals_[pt_nr]);
659
660 for (size_t i = 0; i != filter.size(); ++i) {
661 for (size_t j = 0; j != filter.size(); ++j) {
662 // if the point (x_grid+i,y_grid+j) is the correct point in the grid.
663 if (((x_grid + i) >= 0) && (x_grid + i < this->heat_map.size()) && ((y_grid + j) >= 0) &&
664 (y_grid + j < this->heat_map.size())) {
665 if (dbg) {
666 std::clog << y_grid + j << " " << x_grid + i << std::endl;
667 }
668 this->heat_map[y_grid + j][x_grid + i] += scaling_value * filter[i][j];
669 if (dbg) {
670 std::clog << "Position : (" << x_grid + i << "," << y_grid + j
671 << ") got increased by the value : " << filter[i][j] << std::endl;
672 }
673 }
674 }
675 }
676 }
677
678 // now it remains to cut everything below diagonal if the user wants us to.
679 if (erase_below_diagonal) {
680 for (size_t i = 0; i != this->heat_map.size(); ++i) {
681 for (size_t j = i; j != this->heat_map.size(); ++j) {
682 this->heat_map[i][j] = 0;
683 }
684 }
685 }
686} // construct
687
688template <typename Scalling_of_kernels>
690 const std::vector<std::pair<double, double> >& interval, std::vector<std::vector<double> > filter,
691 bool erase_below_diagonal, size_t number_of_pixels, double min_, double max_) {
692 this->construct(interval, filter, erase_below_diagonal, number_of_pixels, min_, max_);
693 this->set_up_parameters_for_basic_classes();
694}
695
696template <typename Scalling_of_kernels>
698 std::vector<std::vector<double> > filter,
699 bool erase_below_diagonal, size_t number_of_pixels,
700 double min_, double max_, unsigned dimension) {
701 std::vector<std::pair<double, double> > intervals_;
702 if (dimension == std::numeric_limits<unsigned>::max()) {
703 intervals_ = read_persistence_intervals_in_one_dimension_from_file(filename);
704 } else {
705 intervals_ = read_persistence_intervals_in_one_dimension_from_file(filename, dimension);
706 }
707 this->construct(intervals_, filter, erase_below_diagonal, number_of_pixels, min_, max_);
708 this->set_up_parameters_for_basic_classes();
709}
710
711template <typename Scalling_of_kernels>
713 const std::vector<Persistence_heat_maps*>& maps) {
714 // checking if all the heat maps are of the same size:
715 for (size_t i = 0; i != maps.size(); ++i) {
716 if (maps[i]->heat_map.size() != maps[0]->heat_map.size()) {
717 std::cerr << "Sizes of Persistence_heat_maps are not compatible. The program will terminate now \n";
718 throw "Sizes of Persistence_heat_maps are not compatible. The program will terminate now \n";
719 }
720 if (maps[i]->heat_map[0].size() != maps[0]->heat_map[0].size()) {
721 std::cerr << "Sizes of Persistence_heat_maps are not compatible. The program will terminate now \n";
722 throw "Sizes of Persistence_heat_maps are not compatible. The program will terminate now \n";
723 }
724 }
725 std::vector<std::vector<double> > heat_maps(maps[0]->heat_map.size());
726 for (size_t i = 0; i != maps[0]->heat_map.size(); ++i) {
727 std::vector<double> v(maps[0]->heat_map[0].size(), 0);
728 heat_maps[i] = v;
729 }
730 return heat_maps;
731}
732
733template <typename Scalling_of_kernels>
734void Persistence_heat_maps<Scalling_of_kernels>::compute_median(const std::vector<Persistence_heat_maps*>& maps) {
735 std::vector<std::vector<double> > heat_maps = this->check_and_initialize_maps(maps);
736
737 std::vector<double> to_compute_median(maps.size());
738 for (size_t i = 0; i != heat_maps.size(); ++i) {
739 for (size_t j = 0; j != heat_maps[i].size(); ++j) {
740 for (size_t map_no = 0; map_no != maps.size(); ++map_no) {
741 to_compute_median[map_no] = maps[map_no]->heat_map[i][j];
742 }
743 std::nth_element(to_compute_median.begin(), to_compute_median.begin() + to_compute_median.size() / 2,
744 to_compute_median.end());
745 heat_maps[i][j] = to_compute_median[to_compute_median.size() / 2];
746 }
747 }
748 this->heat_map = heat_maps;
749 this->min_ = maps[0]->min_;
750 this->max_ = maps[0]->max_;
751}
752
753template <typename Scalling_of_kernels>
754void Persistence_heat_maps<Scalling_of_kernels>::compute_mean(const std::vector<Persistence_heat_maps*>& maps) {
755 std::vector<std::vector<double> > heat_maps = this->check_and_initialize_maps(maps);
756 for (size_t i = 0; i != heat_maps.size(); ++i) {
757 for (size_t j = 0; j != heat_maps[i].size(); ++j) {
758 double mean = 0;
759 for (size_t map_no = 0; map_no != maps.size(); ++map_no) {
760 mean += maps[map_no]->heat_map[i][j];
761 }
762 heat_maps[i][j] = mean / static_cast<double>(maps.size());
763 }
764 }
765 this->heat_map = heat_maps;
766 this->min_ = maps[0]->min_;
767 this->max_ = maps[0]->max_;
768}
769
770template <typename Scalling_of_kernels>
772 const std::vector<Persistence_heat_maps*>& maps, size_t cutoff) {
773 std::vector<std::vector<double> > heat_maps = this->check_and_initialize_maps(maps);
774
775 for (size_t i = 0; i != heat_maps.size(); ++i) {
776 for (size_t j = 0; j != heat_maps[i].size(); ++j) {
777 size_t number_of_active_levels = 0;
778 for (size_t map_no = 0; map_no != maps.size(); ++map_no) {
779 if (maps[map_no]->heat_map[i][j]) number_of_active_levels++;
780 }
781 if (number_of_active_levels > cutoff) {
782 heat_maps[i][j] = number_of_active_levels;
783 } else {
784 heat_maps[i][j] = 0;
785 }
786 }
787 }
788 this->heat_map = heat_maps;
789 this->min_ = maps[0]->min_;
790 this->max_ = maps[0]->max_;
791}
792
793template <typename Scalling_of_kernels>
794void Persistence_heat_maps<Scalling_of_kernels>::plot(const char* filename) const {
795 std::ofstream out;
796 std::stringstream gnuplot_script;
797 gnuplot_script << filename << "_GnuplotScript";
798
799 out.open(gnuplot_script.str().c_str());
800 out << "plot '-' matrix with image" << std::endl;
801 for (size_t i = 0; i != this->heat_map.size(); ++i) {
802 for (size_t j = 0; j != this->heat_map[i].size(); ++j) {
803 out << this->heat_map[i][j] << " ";
804 }
805 out << std::endl;
806 }
807 out.close();
808 std::clog << "To visualize, install gnuplot and type the command: gnuplot -persist -e \"load \'"
809 << gnuplot_script.str().c_str() << "\'\"" << std::endl;
810}
811
812template <typename Scalling_of_kernels>
814 std::ofstream out;
815 out.open(filename);
816
817 // First we store this->min_ and this->max_ values:
818 out << this->min_ << " " << this->max_ << std::endl;
819 for (size_t i = 0; i != this->heat_map.size(); ++i) {
820 for (size_t j = 0; j != this->heat_map[i].size(); ++j) {
821 out << this->heat_map[i][j] << " ";
822 }
823 out << std::endl;
824 }
825 out.close();
826}
827
828template <typename Scalling_of_kernels>
830 bool dbg = false;
831
832 std::ifstream in;
833 in.open(filename);
834
835 // checking if the file exist / if it was open.
836 if (!in.good()) {
837 std::cerr << "The file : " << filename << " do not exist. The program will now terminate \n";
838 throw "The persistence landscape file do not exist. The program will now terminate \n";
839 }
840
841 // now we read the file one by one.
842
843 in >> this->min_ >> this->max_;
844 if (dbg) {
845 std::clog << "Reading the following values of min and max : " << this->min_ << " , " << this->max_ << std::endl;
846 }
847
848 std::string temp;
849 std::getline(in, temp);
850 while (in.good()) {
851 std::getline(in, temp);
852 std::stringstream lineSS;
853 lineSS << temp;
854
855 std::vector<double> line_of_heat_map;
856 while (lineSS.good()) {
857 double point;
858
859 lineSS >> point;
860 line_of_heat_map.push_back(point);
861 if (dbg) {
862 std::clog << point << " ";
863 }
864 }
865 if (dbg) {
866 std::clog << std::endl;
867 getchar();
868 }
869
870 if (in.good()) this->heat_map.push_back(line_of_heat_map);
871 }
872 in.close();
873 if (dbg) std::clog << "Done \n";
874}
875
876// Concretizations of virtual methods:
877template <typename Scalling_of_kernels>
878std::vector<double> Persistence_heat_maps<Scalling_of_kernels>::vectorize(int number_of_function) const {
879 std::vector<double> result;
880 if (!discrete) {
881 std::cerr << "No vectorize method in case of infinite dimensional vectorization" << std::endl;
882 return result;
883 }
884
885 // convert this->heat_map into one large vector:
886 size_t size_of_result = 0;
887 for (size_t i = 0; i != this->heat_map.size(); ++i) {
888 size_of_result += this->heat_map[i].size();
889 }
890
891 result.reserve(size_of_result);
892
893 for (size_t i = 0; i != this->heat_map.size(); ++i) {
894 for (size_t j = 0; j != this->heat_map[i].size(); ++j) {
895 result.push_back(this->heat_map[i][j]);
896 }
897 }
898
899 return result;
900}
901
902template <typename Scalling_of_kernels>
904 if (this->discrete) {
905 // first we need to check if (*this) and second are defined on the same domain and have the same dimensions:
906 if (!this->check_if_the_same(second)) {
907 std::cerr << "The persistence images are of non compatible sizes. We cannot therefore compute distance between "
908 "them. The program will now terminate";
909 throw "The persistence images are of non compatible sizes. The program will now terminate";
910 }
911
912 // if we are here, we know that the two persistence images are defined on the same domain, so we can start
913 // computing their distances:
914
915 double distance = 0;
916 if (power < std::numeric_limits<double>::max()) {
917 for (size_t i = 0; i != this->heat_map.size(); ++i) {
918 for (size_t j = 0; j != this->heat_map[i].size(); ++j) {
919 distance += std::pow(std::fabs(this->heat_map[i][j] - second.heat_map[i][j]), power);
920 }
921 }
922 } else {
923 // in this case, we compute max norm distance
924 for (size_t i = 0; i != this->heat_map.size(); ++i) {
925 for (size_t j = 0; j != this->heat_map[i].size(); ++j) {
926 if (distance < std::fabs(this->heat_map[i][j] - second.heat_map[i][j])) {
927 distance = std::fabs(this->heat_map[i][j] - second.heat_map[i][j]);
928 }
929 }
930 }
931 }
932 return distance;
933 } else {
934 return std::sqrt(this->compute_scalar_product(*this) + second.compute_scalar_product(second) -
935 2 * this->compute_scalar_product(second));
936 }
937}
938
939template <typename Scalling_of_kernels>
941 double result = 0;
942 for (size_t i = 0; i != this->heat_map.size(); ++i) {
943 for (size_t j = 0; j != this->heat_map[i].size(); ++j) {
944 result += this->heat_map[i][j];
945 }
946 }
947 return result;
948}
949
950template <typename Scalling_of_kernels>
952 const std::vector<Persistence_heat_maps*>& to_average) {
953 this->compute_mean(to_average);
954}
955
956template <typename Scalling_of_kernels>
958 if (discrete) {
959 // first we need to check if (*this) and second are defined on the same domain and have the same dimensions:
960 if (!this->check_if_the_same(second)) {
961 std::cerr << "The persistence images are of non compatible sizes. We cannot therefore compute distance between "
962 "them. The program will now terminate";
963 throw "The persistence images are of non compatible sizes. The program will now terminate";
964 }
965
966 // if we are here, we know that the two persistence images are defined on the same domain, so we can start computing
967 // their scalar product:
968 double scalar_prod = 0;
969 for (size_t i = 0; i != this->heat_map.size(); ++i) {
970 for (size_t j = 0; j != this->heat_map[i].size(); ++j) {
971 scalar_prod += this->heat_map[i][j] * second.heat_map[i][j];
972 }
973 }
974 return scalar_prod;
975 } else {
976 int num_pts1 = this->interval.size();
977 int num_pts2 = second.interval.size();
978 double kernel_val = 0;
979 for (int i = 0; i < num_pts1; i++) {
980 std::pair<double, double> pi = this->interval[i];
981 for (int j = 0; j < num_pts2; j++) {
982 std::pair<double, double> pj = second.interval[j];
983 kernel_val += this->weights[i] * second.weights[j] * this->kernel(pi, pj);
984 }
985 }
986 return kernel_val;
987 }
988}
989
990} // namespace Persistence_representations
991} // namespace Gudhi
992
993#endif // PERSISTENCE_HEAT_MAPS_H_
A class implementing persistence heat maps.
Definition: Persistence_heat_maps.h:178
Definition: Persistence_heat_maps.h:465
void compute_mean(const std::vector< Persistence_heat_maps * > &maps)
Definition: Persistence_heat_maps.h:754
bool check_if_the_same(const Persistence_heat_maps &second) const
Definition: Persistence_heat_maps.h:289
std::vector< double > vectorize(int number_of_function) const
Definition: Persistence_heat_maps.h:878
friend Persistence_heat_maps operator*(const Persistence_heat_maps &A, double scalar)
Definition: Persistence_heat_maps.h:417
friend Persistence_heat_maps operator*(double scalar, const Persistence_heat_maps &A)
Definition: Persistence_heat_maps.h:411
Persistence_heat_maps operator/=(double x)
Definition: Persistence_heat_maps.h:448
std::pair< double, double > get_y_range() const
Definition: Persistence_heat_maps.h:512
Definition: Persistence_heat_maps.h:423
bool operator!=(const Persistence_heat_maps &rhs) const
Definition: Persistence_heat_maps.h:345
Persistence_heat_maps operator-=(const Persistence_heat_maps &rhs)
Definition: Persistence_heat_maps.h:434
void print_to_file(const char *filename) const
Definition: Persistence_heat_maps.h:813
Persistence_heat_maps(const char *filename, std::vector< std::vector< double > > filter=create_Gaussian_filter(5, 1), bool erase_below_diagonal=false, size_t number_of_pixels=1000, double min_=std::numeric_limits< double >::max(), double max_=std::numeric_limits< double >::max(), unsigned dimension=std::numeric_limits< unsigned >::max())
Definition: Persistence_heat_maps.h:697
Persistence_heat_maps multiply_by_scalar(double scalar) const
Definition: Persistence_heat_maps.h:380
Persistence_heat_maps operator*=(double x)
Definition: Persistence_heat_maps.h:441
Persistence_heat_maps(const std::vector< std::pair< double, double > > &interval, std::vector< std::vector< double > > filter=create_Gaussian_filter(5, 1), bool erase_below_diagonal=false, size_t number_of_pixels=1000, double min_=std::numeric_limits< double >::max(), double max_=std::numeric_limits< double >::max())
Definition: Persistence_heat_maps.h:689
void compute_percentage_of_active(const std::vector< Persistence_heat_maps * > &maps, size_t cutoff=1)
Definition: Persistence_heat_maps.h:771
Definition: Persistence_heat_maps.h:479
bool operator==(const Persistence_heat_maps &rhs) const
Definition: Persistence_heat_maps.h:322
Definition: Persistence_heat_maps.h:940
friend Persistence_heat_maps operator-(const Persistence_heat_maps &first, const Persistence_heat_maps &second)
Definition: Persistence_heat_maps.h:405
Persistence_heat_maps()
Definition: Persistence_heat_maps.h:184
void compute_average(const std::vector< Persistence_heat_maps * > &to_average)
Definition: Persistence_heat_maps.h:951
Persistence_heat_maps(const std::vector< std::pair< double, double > > &interval, const std::function< double(std::pair< double, double >, std::pair< double, double >)> &kernel, size_t number_of_x_pixels, size_t number_of_y_pixels, double min_x=0, double max_x=1, double min_y=0, double max_y=1)
Definition: Persistence_heat_maps.h:544
std::pair< double, double > get_x_range() const
Definition: Persistence_heat_maps.h:507
Definition: Persistence_heat_maps.h:312
Definition: Persistence_heat_maps.h:317
double distance(const Persistence_heat_maps &second_, double power=1) const
Definition: Persistence_heat_maps.h:903
void load_from_file(const char *filename)
Definition: Persistence_heat_maps.h:829
Persistence_heat_maps(const std::vector< std::pair< double, double > > &interval, const std::function< double(std::pair< double, double >, std::pair< double, double >)> &kernel)
Definition: Persistence_heat_maps.h:571
void compute_median(const std::vector< Persistence_heat_maps * > &maps)
Definition: Persistence_heat_maps.h:734
Persistence_heat_maps operator+=(const Persistence_heat_maps &rhs)
Definition: Persistence_heat_maps.h:427
void plot(const char *filename) const
Definition: Persistence_heat_maps.h:794
double compute_scalar_product(const Persistence_heat_maps &second_) const
Definition: Persistence_heat_maps.h:957
friend Persistence_heat_maps operator+(const Persistence_heat_maps &first, const Persistence_heat_maps &second)
Definition: Persistence_heat_maps.h:399
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
