Persistence_diagram.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author: François Godi
4 *
5 * Copyright (C) 2015 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef CONCEPT_BOTTLENECK_DISTANCE_PERSISTENCE_DIAGRAM_H_
12#define CONCEPT_BOTTLENECK_DISTANCE_PERSISTENCE_DIAGRAM_H_
13
14namespace Gudhi {
15
16namespace persistence_diagram {
17
25struct DiagramPoint{};
26
33
34} // namespace persistence_diagram
35
36} // namespace Gudhi
37
38#endif // CONCEPT_BOTTLENECK_DISTANCE_PERSISTENCE_DIAGRAM_H_
Concept of point in a persistence diagram. std::get<0>(point) must return the birth of the correspond...
Definition: Persistence_diagram.h:25
Concept of persistence diagram. It is a range of DiagramPoint. std::begin(diagram) and std::end(diagr...
Definition: Persistence_diagram.h:32
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
