Multi_field.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Clément Maria
4 *
5 * Copyright (C) 2014 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef PERSISTENT_COHOMOLOGY_MULTI_FIELD_H_
12#define PERSISTENT_COHOMOLOGY_MULTI_FIELD_H_
13
14#include <gmpxx.h>
15
16#include <vector>
17#include <utility>
18
19namespace Gudhi {
20
21namespace persistent_cohomology {
22
32 public:
33 typedef mpz_class Element;
34
36 : prod_characteristics_(0),
37 mult_id_all(0),
38 add_id_all(0) {
39 }
40
41 /* Initialize the multi-field. The generation of prime numbers might fail with
42 * a very small probability.*/
43 void init(int min_prime, int max_prime) {
44 if (max_prime < 2) {
45 std::cerr << "There is no prime less than " << max_prime << std::endl;
46 }
47 if (min_prime > max_prime) {
48 std::cerr << "No prime in [" << min_prime << ":" << max_prime << "]"
49 << std::endl;
50 }
51 // fill the list of prime numbers
52 int curr_prime = min_prime;
53 mpz_t tmp_prime;
54 mpz_init_set_ui(tmp_prime, min_prime);
55 // test if min_prime is prime
56 int is_prime = mpz_probab_prime_p(tmp_prime, 25); // probabilistic primality test
57
58 if (is_prime == 0) { // min_prime is composite
59 mpz_nextprime(tmp_prime, tmp_prime);
60 curr_prime = mpz_get_ui(tmp_prime);
61 }
62
63 while (curr_prime <= max_prime) {
64 primes_.push_back(curr_prime);
65 mpz_nextprime(tmp_prime, tmp_prime);
66 curr_prime = mpz_get_ui(tmp_prime);
67 }
68 mpz_clear(tmp_prime);
69 // set m to primorial(bound_prime)
70 prod_characteristics_ = 1;
71 for (auto p : primes_) {
72 prod_characteristics_ *= p;
73 }
74
75 // Uvect_
76 Element Ui;
77 Element tmp_elem;
78 for (auto p : primes_) {
79 assert(p > 0); // division by zero + non negative values
80 tmp_elem = prod_characteristics_ / p;
81 // Element tmp_elem_bis = 10;
82 mpz_powm_ui(tmp_elem.get_mpz_t(), tmp_elem.get_mpz_t(), p - 1,
83 prod_characteristics_.get_mpz_t());
84 Uvect_.push_back(tmp_elem);
85 }
86 mult_id_all = 0;
87 for (auto uvect : Uvect_) {
88 assert(prod_characteristics_ > 0); // division by zero + non negative values
89 mult_id_all = (mult_id_all + uvect) % prod_characteristics_;
90 }
91 }
92
94 const Element& additive_identity() const {
95 return add_id_all;
96 }
98 const Element& multiplicative_identity() const {
99 return mult_id_all;
100 } // 1 everywhere
101
102 Element multiplicative_identity(Element Q) {
103 if (Q == prod_characteristics_) {
105 }
106
107 assert(prod_characteristics_ > 0); // division by zero + non negative values
108 Element mult_id = 0;
109 for (unsigned int idx = 0; idx < primes_.size(); ++idx) {
110 assert(primes_[idx] > 0); // division by zero + non negative values
111 if ((Q % primes_[idx]) == 0) {
112 mult_id = (mult_id + Uvect_[idx]) % prod_characteristics_;
113 }
114 }
115 return mult_id;
116 }
117
119 Element times(const Element& y, const Element& w) {
120 return plus_times_equal(0, y, w);
121 }
122
123 Element plus_equal(const Element& x, const Element& y) {
124 return plus_times_equal(x, y, (Element)1);
125 }
126
128 const Element& characteristic() const {
129 return prod_characteristics_;
130 }
131
133 std::pair<Element, Element> inverse(Element x, Element QS) {
134 Element QR;
135 mpz_gcd(QR.get_mpz_t(), x.get_mpz_t(), QS.get_mpz_t()); // QR <- gcd(x,QS)
136 if (QR == QS)
137 return std::pair<Element, Element>(additive_identity(), multiplicative_identity()); // partial inverse is 0
138 Element QT = QS / QR;
139 Element inv_qt;
140 mpz_invert(inv_qt.get_mpz_t(), x.get_mpz_t(), QT.get_mpz_t());
141
142 assert(prod_characteristics_ > 0); // division by zero + non negative values
143 return { (inv_qt * multiplicative_identity(QT)) % prod_characteristics_, QT };
144 }
146 Element times_minus(const Element& x, const Element& y) {
147 assert(prod_characteristics_ > 0); // division by zero + non negative values
148 /* This assumes that (x*y)%pc cannot be zero, but Field_Zp has specific code for the 0 case ??? */
149 return prod_characteristics_ - ((x * y) % prod_characteristics_);
150 }
151
153 Element plus_times_equal(const Element& x, const Element& y, const Element& w) {
154 assert(prod_characteristics_ > 0); // division by zero + non negative values
155 Element result = (x + w * y) % prod_characteristics_;
156 if (result < 0)
157 result += prod_characteristics_;
158 return result;
159 }
160
161 Element prod_characteristics_; // product of characteristics of the fields
162 // represented by the multi-field class
163 std::vector<int> primes_; // all the characteristics of the fields
164 std::vector<Element> Uvect_;
165 Element mult_id_all;
166 const Element add_id_all;
167};
168
169} // namespace persistent_cohomology
170
171} // namespace Gudhi
172
173#endif // PERSISTENT_COHOMOLOGY_MULTI_FIELD_H_
Structure representing coefficients in a set of finite fields simultaneously using the chinese remain...
Definition: Multi_field.h:31
const Element & additive_identity() const
Returns the additive idendity of the field.
Definition: Multi_field.h:94
const Element & characteristic() const
Returns the characteristic of the field.
Definition: Multi_field.h:128
std::pair< Element, Element > inverse(Element x, Element QS)
Definition: Multi_field.h:133
Element times(const Element &y, const Element &w)
Definition: Multi_field.h:119
const Element & multiplicative_identity() const
Returns the multiplicative identity of the field.
Definition: Multi_field.h:98
Element plus_times_equal(const Element &x, const Element &y, const Element &w)
Definition: Multi_field.h:153
Element times_minus(const Element &x, const Element &y)
Definition: Multi_field.h:146
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
