Hasse_diagram_cell.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Pawel Dlotko
4 *
5 * Copyright (C) 2017 Swansea University UK
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef HASSE_DIAGRAM_CELL_H
12#define HASSE_DIAGRAM_CELL_H
13
14#include <vector>
15#include <utility> // for std::pair
16#include <ostream>
17#include <string>
18#include <type_traits> // for std::is_same
19#include <cstdlib> // for std::size_t
20
21namespace Gudhi {
22namespace Hasse_diagram {
23
24template <typename Cell_type>
25class Hasse_diagram;
26
48template <typename Incidence_type_, typename Filtration_type_, typename Additional_information_ = void>
50 public:
51 typedef Incidence_type_ Incidence_type;
52 typedef Filtration_type_ Filtration_type;
53 typedef Additional_information_ Additional_information;
54 using Cell_range = std::vector<std::pair<Hasse_diagram_cell*, Incidence_type> >;
55
59 Hasse_diagram_cell() : dimension(0), position(0), deleted_(false) {}
60
64 Hasse_diagram_cell(int dim) : dimension(dim), position(0), deleted_(false) {}
65
69 Hasse_diagram_cell(int dim, Filtration_type filt_)
70 : dimension(dim), position(0), deleted_(false), filtration(filt_) {}
71
75 Hasse_diagram_cell(const Cell_range& boundary_, int dim)
76 : dimension(dim), boundary(boundary_), position(0), deleted_(false) {}
77
81 Hasse_diagram_cell(const Cell_range& boundary_, const Cell_range& coboundary_, int dim)
82 : dimension(dim), boundary(boundary_), coBoundary(coboundary_), position(0), deleted_(false) {}
83
88 Hasse_diagram_cell(const Cell_range& boundary_, const Cell_range& coboundary_, const Additional_information& ai,
89 int dim)
90 : dimension(dim),
91 boundary(boundary_),
92 coBoundary(coboundary_),
93 additional_info(ai),
94 position(0),
95 deleted_(false) {}
96
100 Hasse_diagram_cell(Additional_information ai, int dim)
101 : dimension(dim), additional_info(ai), position(0), deleted_(false) {}
102
108 inline Cell_range& get_boundary() { return this->boundary; }
109
115 inline Cell_range& get_coBoundary() { return this->coBoundary; }
116
120 inline int& get_dimension() { return this->dimension; }
121
125 inline Additional_information& get_additional_information() { return this->additional_info; }
126
133 inline unsigned& get_position() { return this->position; }
134
138 inline Filtration_type& get_filtration() {
139 // std::cout << "Accessing the filtration of a cell : " << *this << std::endl;
140 return this->filtration;
141 }
142
148 inline bool deleted() { return this->deleted_; }
149
150 template <typename Cell_type>
151 friend class Hasse_diagram;
152
153 template <typename Cell_type>
154 friend class is_before_in_filtration;
155
156 template <typename Complex_type, typename Cell_type>
157 friend std::vector<Cell_type*> convert_to_vector_of_Cell_type(Complex_type& cmplx);
158
164 Cell_range new_boundary;
165 new_boundary.reserve(this->boundary.size());
166 for (std::size_t bd = 0; bd != this->boundary.size(); ++bd) {
167 if (!this->boundary[bd].first->deleted()) {
168 new_boundary.push_back(this->boundary[bd]);
169 }
170 }
171 this->boundary.swap(new_boundary);
172
173 Cell_range new_coBoundary;
174 new_coBoundary.reserve(this->coBoundary.size());
175 for (std::size_t cbd = 0; cbd != this->coBoundary.size(); ++cbd) {
176 if (!this->coBoundary[cbd].first->deleted()) {
177 new_coBoundary.push_back(this->coBoundary[cbd]);
178 }
179 }
180 this->coBoundary.swap(new_coBoundary);
181 }
182
186 friend std::ostream& operator<<(
188 // cout << "position : " << c.position << ", dimension : " << c.dimension << ", filtration: " << c.filtration << ",
189 // size of boudary : " << c.boundary.size() << "\n";
190 out << c.position << " " << c.dimension << " " << c.filtration << std::endl;
191 for (std::size_t bd = 0; bd != c.boundary.size(); ++bd) {
192 // do not write out the cells that has been deleted
193 if (c.boundary[bd].first->deleted()) continue;
194 out << c.boundary[bd].first->position << " " << c.boundary[bd].second << " ";
195 }
196 out << std::endl;
197 return out;
198 }
199
203 inline std::vector<Hasse_diagram_cell*> get_list_of_boundary_elements() {
204 std::vector<Hasse_diagram_cell*> result;
205 std::size_t size_of_boundary = this->boundary.size();
206 result.reserve(size_of_boundary);
207 for (std::size_t bd = 0; bd != size_of_boundary; ++bd) {
208 result.push_back(this->boundary[bd].first);
209 }
210 return result;
211 }
212
216 inline std::vector<unsigned> get_list_of_positions_of_boundary_elements() {
217 std::vector<unsigned> result;
218 std::size_t size_of_boundary = this->boundary.size();
219 result.reserve(size_of_boundary);
220 for (std::size_t bd = 0; bd != size_of_boundary; ++bd) {
221 result.push_back(this->boundary[bd].first->position);
222 }
223 return result;
224 }
225
231 std::string result;
232 result += "dimension: ";
233 result += std::to_string(this->dimension);
234 result += " filtration: ";
235 result += std::to_string(this->filtration);
236 result += " position: ";
237 result += std::to_string(this->position);
238 result += " deleted_: ";
239 result += std::to_string(this->deleted_);
240
241 // if the Additional_information is not void, add them to
242 // the signature as well.
243 if (std::is_same<Additional_information, void>::value) {
244 result += " Additional_information: ";
245 result += std::to_string(this->additional_info);
246 }
247 result += " boundary ";
248 for (std::size_t bd = 0; bd != this->boundary.size(); ++bd) {
249 result += "( " + std::to_string(this->boundary[bd].first->position);
250 result += " " + std::to_string(this->boundary[bd].second);
251 result += ") ";
252 }
253
254 result += " coBoundary ";
255 for (std::size_t cbd = 0; cbd != this->coBoundary.size(); ++cbd) {
256 result += "( " + std::to_string(this->coBoundary[cbd].first->position);
257 result += " " + std::to_string(this->coBoundary[cbd].second);
258 result += ") ";
259 }
260
261 return result;
262 }
263
264 protected:
265 Cell_range boundary;
266 Cell_range coBoundary;
267 int dimension;
268 Additional_information additional_info;
269 unsigned position;
270 bool deleted_;
271 Filtration_type filtration;
272
279 void delete_cell() { this->deleted_ = true; }
280}; // Hasse_diagram_cell
281
282} // namespace Hasse_diagram
283} // namespace Gudhi
284
285#endif // CELL_H
Data structure to store a cell in a Hasse diagram.
Definition: Hasse_diagram_cell.h:49
Filtration_type & get_filtration()
Definition: Hasse_diagram_cell.h:138
Additional_information & get_additional_information()
Definition: Hasse_diagram_cell.h:125
bool deleted()
Definition: Hasse_diagram_cell.h:148
Cell_range & get_coBoundary()
Definition: Hasse_diagram_cell.h:115
std::vector< unsigned > get_list_of_positions_of_boundary_elements()
Definition: Hasse_diagram_cell.h:216
Definition: Hasse_diagram_cell.h:64
Definition: Hasse_diagram_cell.h:69
void remove_deleted_elements_from_boundary_and_coboundary()
Definition: Hasse_diagram_cell.h:163
Definition: Hasse_diagram_cell.h:100
Definition: Hasse_diagram_cell.h:59
Cell_range & get_boundary()
Definition: Hasse_diagram_cell.h:108
Hasse_diagram_cell(const Cell_range &boundary_, const Cell_range &coboundary_, const Additional_information &ai, int dim)
Definition: Hasse_diagram_cell.h:88
int & get_dimension()
Definition: Hasse_diagram_cell.h:120
friend std::ostream & operator<<(std::ostream &out, const Hasse_diagram_cell< Incidence_type, Filtration_type, Additional_information > &c)
Definition: Hasse_diagram_cell.h:186
Hasse_diagram_cell(const Cell_range &boundary_, int dim)
Definition: Hasse_diagram_cell.h:75
std::vector< Hasse_diagram_cell * > get_list_of_boundary_elements()
Definition: Hasse_diagram_cell.h:203
unsigned & get_position()
Definition: Hasse_diagram_cell.h:133
Hasse_diagram_cell(const Cell_range &boundary_, const Cell_range &coboundary_, int dim)
Definition: Hasse_diagram_cell.h:81
std::string full_signature_of_the_structure()
Definition: Hasse_diagram_cell.h:230
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
