Function_whitney_umbrella_in_R3.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Siargey Kachanovich
4 *
5 * Copyright (C) 2019 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef FUNCTIONS_FUNCTION_WHITNEY_UMBRELLA_IN_R3_H_
12#define FUNCTIONS_FUNCTION_WHITNEY_UMBRELLA_IN_R3_H_
13
14#include <cstdlib> // for std::size_t
15
16#include <Eigen/Dense>
17
18namespace Gudhi {
19
20namespace coxeter_triangulation {
21
32 Eigen::VectorXd operator()(const Eigen::VectorXd& p) const {
33 double x = p(0) - off_[0], y = p(1) - off_[1], z = p(2) - off_[2];
34 Eigen::VectorXd result(cod_d());
35 result(0) = x * x - y * y * z;
36 return result;
37 }
38
40 std::size_t amb_d() const { return 3; };
41
43 std::size_t cod_d() const { return 1; };
44
49 Eigen::VectorXd seed() const {
50 Eigen::Vector3d result(1 + off_[0], 1 + off_[1], 1 + off_[2]);
51 return result;
52 }
53
58 Eigen::VectorXd seed2() const {
59 Eigen::Vector3d result(-1 + off_[0], -1 + off_[1], 1 + off_[2]);
60 return result;
61 }
62
68 Function_whitney_umbrella_in_R3(Eigen::Vector3d off = Eigen::Vector3d::Zero()) : off_(off) {}
69
70 private:
71 Eigen::Vector3d off_;
72};
73
74} // namespace coxeter_triangulation
75
76} // namespace Gudhi
77
78#endif
A class that encodes the function, the zero-set of which is the Whitney umbrella surface embedded in ...
Definition: Function_whitney_umbrella_in_R3.h:27
Returns the codomain dimension.
Definition: Function_whitney_umbrella_in_R3.h:43
Returns a point on the surface. This seed point is only one of two necessary seed points for the mani...
Definition: Function_whitney_umbrella_in_R3.h:49
Function_whitney_umbrella_in_R3(Eigen::Vector3d off=Eigen::Vector3d::Zero())
Constructor of the function that defines the Whitney umbrella in R^3.
Definition: Function_whitney_umbrella_in_R3.h:68
Returns the (ambient) domain dimension.
Definition: Function_whitney_umbrella_in_R3.h:40
Eigen::VectorXd operator()(const Eigen::VectorXd &p) const
Value of the function at a specified point.
Definition: Function_whitney_umbrella_in_R3.h:32
Definition: Function_whitney_umbrella_in_R3.h:58
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
