Function_lemniscate_revolution_in_R3.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Siargey Kachanovich
4 *
5 * Copyright (C) 2019 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef FUNCTIONS_FUNCTION_LEMNISCATE_REVOLUTION_IN_R3_H_
12#define FUNCTIONS_FUNCTION_LEMNISCATE_REVOLUTION_IN_R3_H_
13
14#include <cstdlib> // for std::size_t
15#include <cmath> // for std::sqrt
16
17#include <Eigen/Dense>
18
19namespace Gudhi {
20
21namespace coxeter_triangulation {
22
33 Eigen::VectorXd operator()(const Eigen::VectorXd& p) const {
34 double x = p(0) - off_[0], y = p(1) - off_[1], z = p(2) - off_[2];
35 Eigen::VectorXd result(cod_d());
36 double x2 = x * x, y2 = y * y, z2 = z * z, a2 = a_ * a_;
37 double t1 = x2 + y2 + z2;
38 result(0) = t1 * t1 - 2 * a2 * (x2 - y2 - z2);
39 return result;
40 }
41
43 std::size_t amb_d() const { return 3; };
44
46 std::size_t cod_d() const { return 1; };
47
52 Eigen::VectorXd seed() const {
53 Eigen::Vector3d result(std::sqrt(2 * a_) + off_[0], off_[1], off_[2]);
54 return result;
55 }
56
61 Eigen::VectorXd seed2() const {
62 Eigen::Vector3d result(-std::sqrt(2 * a_) + off_[0], off_[1], off_[2]);
63 return result;
64 }
65
73 Function_lemniscate_revolution_in_R3(double a = 1, Eigen::Vector3d off = Eigen::Vector3d::Zero())
74 : a_(a), off_(off) {}
75
76 private:
77 double a_;
78 Eigen::Vector3d off_;
79};
80
81} // namespace coxeter_triangulation
82
83} // namespace Gudhi
84
85#endif
A class that encodes the function, the zero-set of which is a surface of revolution around the x axis...
Definition: Function_lemniscate_revolution_in_R3.h:28
Function_lemniscate_revolution_in_R3(double a=1, Eigen::Vector3d off=Eigen::Vector3d::Zero())
Constructor of the function that defines a surface of revolution around the x axis based on the lemni...
Definition: Function_lemniscate_revolution_in_R3.h:73
Returns a point on the surface. This seed point is only one of two necessary seed points for the mani...
Definition: Function_lemniscate_revolution_in_R3.h:52
Returns the codomain dimension.
Definition: Function_lemniscate_revolution_in_R3.h:46
Definition: Function_lemniscate_revolution_in_R3.h:61
Eigen::VectorXd operator()(const Eigen::VectorXd &p) const
Value of the function at a specified point.
Definition: Function_lemniscate_revolution_in_R3.h:33
Returns the (ambient) domain dimension.
Definition: Function_lemniscate_revolution_in_R3.h:43
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
