Function_iron_in_R3.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Siargey Kachanovich
4 *
5 * Copyright (C) 2019 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef FUNCTIONS_FUNCTION_IRON_IN_R3_H_
12#define FUNCTIONS_FUNCTION_IRON_IN_R3_H_
13
14#include <cstdlib> // for std::size_t
15#include <cmath> // for std::pow
16
17#include <Eigen/Dense>
18
19namespace Gudhi {
20
21namespace coxeter_triangulation {
22
33 Eigen::VectorXd operator()(const Eigen::VectorXd& p) const {
34 double x = p(0), y = p(1), z = p(2);
35 Eigen::VectorXd result(cod_d());
36 result(0) = -std::pow(x, 6) / 300. - std::pow(y, 6) / 300. - std::pow(z, 6) / 300. + x * y * y * z / 2.1 + y * y +
37 std::pow(z - 2, 4) - 1;
38 return result;
39 }
40
42 std::size_t amb_d() const { return 3; };
43
45 std::size_t cod_d() const { return 1; };
46
48 Eigen::VectorXd seed() const {
49 Eigen::Vector3d result(std::pow(4500, 1. / 6), 0, 0);
50 return result;
51 }
52
59 Function_iron_in_R3(Eigen::Vector3d off = Eigen::Vector3d::Zero()) : off_(off) {}
60
61 private:
62 Eigen::Vector3d off_;
63};
64
65} // namespace coxeter_triangulation
66
67} // namespace Gudhi
68
69#endif
A class that encodes the function, the zero-set of which is a surface embedded in R^3 that ressembles...
Definition: Function_iron_in_R3.h:28
Returns the codomain dimension.
Definition: Function_iron_in_R3.h:45
Returns the domain (ambient) dimension.
Definition: Function_iron_in_R3.h:42
Returns a point on the surface.
Definition: Function_iron_in_R3.h:48
Function_iron_in_R3(Eigen::Vector3d off=Eigen::Vector3d::Zero())
Constructor of the function that defines a surface embedded in R^3 that ressembles an iron.
Definition: Function_iron_in_R3.h:59
Eigen::VectorXd operator()(const Eigen::VectorXd &p) const
Value of the function at a specified point.
Definition: Function_iron_in_R3.h:33
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
