Constant_function.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Siargey Kachanovich
4 *
5 * Copyright (C) 2019 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef FUNCTIONS_CONSTANT_FUNCTION_H_
12#define FUNCTIONS_CONSTANT_FUNCTION_H_
13
14#include <cstdlib> // for std::size_t
15
16#include <Eigen/Dense>
17
18namespace Gudhi {
19
20namespace coxeter_triangulation {
21
31 Eigen::VectorXd operator()(const Eigen::VectorXd& p) const {
32 return value_;
33 }
34
36 std::size_t amb_d() const { return d_; };
37
39 std::size_t cod_d() const { return k_; };
40
42 Eigen::VectorXd seed() const { throw "Seed invoked on a constant function.\n"; }
43
45
53 Constant_function(std::size_t d, std::size_t k, const Eigen::VectorXd& value) : d_(d), k_(k), value_(value) {}
54
55 private:
56 std::size_t d_, k_;
57 Eigen::VectorXd value_;
58};
59
60} // namespace coxeter_triangulation
61
62} // namespace Gudhi
63
64#endif
A class that encodes a constant function from R^d to R^k. This class does not have any implicit manif...
Definition: Constant_function.h:27
Constant_function(std::size_t d, std::size_t k, const Eigen::VectorXd &value)
Constructor of a constant function from R^d to R^m.
Definition: Constant_function.h:53
No seed point is available. Throws an exception on evocation.
Definition: Constant_function.h:42
Eigen::VectorXd operator()(const Eigen::VectorXd &p) const
Value of the function at a specified point. The value is constant.
Definition: Constant_function.h:31
Returns the codomain dimension. Same as the codimension of the sphere.
Definition: Constant_function.h:39
Returns the domain dimension. Same as the ambient dimension of the sphere.
Definition: Constant_function.h:36
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
