Cell_complex.h
1/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2 * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3 * Author(s): Siargey Kachanovich
4 *
5 * Copyright (C) 2019 Inria
6 *
7 * Modification(s):
8 * - YYYY/MM Author: Description of the modification
9 */
10
11#ifndef CELL_COMPLEX_H_
12#define CELL_COMPLEX_H_
13
14#include <Eigen/Dense>
15
16#include <vector>
17#include <map>
18#include <utility> // for std::make_pair
19
20#include <gudhi/IO/output_debug_traces_to_html.h> // for DEBUG_TRACES
21#include <gudhi/Permutahedral_representation/Simplex_comparator.h>
22#include <gudhi/Coxeter_triangulation/Cell_complex/Hasse_diagram_cell.h> // for Hasse_cell
23
24namespace Gudhi {
25
26namespace coxeter_triangulation {
27
37template <class Out_simplex_map_>
39 public:
43 using Simplex_handle = typename Out_simplex_map_::key_type;
54 using Simplex_cell_map = std::map<Simplex_handle, Hasse_cell*, Simplex_comparator<Simplex_handle> >;
58 using Simplex_cell_maps = std::vector<Simplex_cell_map>;
59
63 using Cell_simplex_map = std::map<Hasse_cell*, Simplex_handle>;
64
68 using Cell_point_map = std::map<Hasse_cell*, Eigen::VectorXd>;
69
70 private:
71 Hasse_cell* insert_cell(const Simplex_handle& simplex, std::size_t cell_d, bool is_boundary) {
72 Simplex_cell_maps& simplex_cell_maps = (is_boundary ? boundary_simplex_cell_maps_ : interior_simplex_cell_maps_);
73#ifdef DEBUG_TRACES
74 CC_detail_list& cc_detail_list =
75 (is_boundary ? cc_boundary_detail_lists[cell_d] : cc_interior_detail_lists[cell_d]);
76 cc_detail_list.emplace_back(simplex);
77#endif
78 Simplex_cell_map& simplex_cell_map = simplex_cell_maps[cell_d];
79 auto map_it = simplex_cell_map.find(simplex);
80 if (map_it == simplex_cell_map.end()) {
81 hasse_cells_.push_back(new Hasse_cell(is_boundary, cell_d));
82 Hasse_cell* new_cell = hasse_cells_.back();
83 simplex_cell_map.emplace(simplex, new_cell);
84 cell_simplex_map_.emplace(new_cell, simplex);
85#ifdef DEBUG_TRACES
86 cc_detail_list.back().status_ = CC_detail_info::Result_type::inserted;
87#endif
88 return new_cell;
89 }
90#ifdef DEBUG_TRACES
91 CC_detail_info& cc_info = cc_detail_list.back();
92 cc_info.trigger_ = to_string(map_it->first);
93 cc_info.status_ = CC_detail_info::Result_type::self;
94#endif
95 return map_it->second;
96 }
97
98 void expand_level(std::size_t cell_d) {
99 bool is_manifold_with_boundary = boundary_simplex_cell_maps_.size() > 0;
100 for (auto& sc_pair : interior_simplex_cell_maps_[cell_d - 1]) {
101 const Simplex_handle& simplex = sc_pair.first;
102 Hasse_cell* cell = sc_pair.second;
103 for (Simplex_handle coface : simplex.coface_range(cod_d_ + cell_d)) {
104 Hasse_cell* new_cell = insert_cell(coface, cell_d, false);
105 new_cell->get_boundary().emplace_back(cell, 1);
106 }
107 }
108
109 if (is_manifold_with_boundary) {
110 for (auto& sc_pair : boundary_simplex_cell_maps_[cell_d - 1]) {
111 const Simplex_handle& simplex = sc_pair.first;
112 Hasse_cell* cell = sc_pair.second;
113 if (cell_d != intr_d_)
114 for (Simplex_handle coface : simplex.coface_range(cod_d_ + cell_d + 1)) {
115 Hasse_cell* new_cell = insert_cell(coface, cell_d, true);
116 new_cell->get_boundary().emplace_back(cell, 1);
117 }
118 auto map_it = interior_simplex_cell_maps_[cell_d].find(simplex);
119 if (map_it == interior_simplex_cell_maps_[cell_d].end())
120 std::cerr << "Cell_complex::expand_level error: A boundary cell does not have an interior counterpart.\n";
121 else {
122 Hasse_cell* i_cell = map_it->second;
123 i_cell->get_boundary().emplace_back(cell, 1);
124 }
125 }
126 }
127 }
128
129 void construct_complex_(const Out_simplex_map_& out_simplex_map) {
130#ifdef DEBUG_TRACES
131 cc_interior_summary_lists.resize(interior_simplex_cell_maps_.size());
132 cc_interior_prejoin_lists.resize(interior_simplex_cell_maps_.size());
133 cc_interior_detail_lists.resize(interior_simplex_cell_maps_.size());
134#endif
135 for (auto& os_pair : out_simplex_map) {
136 const Simplex_handle& simplex = os_pair.first;
137 const Eigen::VectorXd& point = os_pair.second;
138 Hasse_cell* new_cell = insert_cell(simplex, 0, false);
139 cell_point_map_.emplace(new_cell, point);
140 }
141 for (std::size_t cell_d = 1;
142 cell_d < interior_simplex_cell_maps_.size() && !interior_simplex_cell_maps_[cell_d - 1].empty(); ++cell_d) {
143 expand_level(cell_d);
144 }
145 }
146
147 void construct_complex_(const Out_simplex_map_& interior_simplex_map, const Out_simplex_map_& boundary_simplex_map) {
148#ifdef DEBUG_TRACES
149 cc_interior_summary_lists.resize(interior_simplex_cell_maps_.size());
150 cc_interior_prejoin_lists.resize(interior_simplex_cell_maps_.size());
151 cc_interior_detail_lists.resize(interior_simplex_cell_maps_.size());
152 cc_boundary_summary_lists.resize(boundary_simplex_cell_maps_.size());
153 cc_boundary_prejoin_lists.resize(boundary_simplex_cell_maps_.size());
154 cc_boundary_detail_lists.resize(boundary_simplex_cell_maps_.size());
155#endif
156 for (auto& os_pair : boundary_simplex_map) {
157 const Simplex_handle& simplex = os_pair.first;
158 const Eigen::VectorXd& point = os_pair.second;
159 Hasse_cell* new_cell = insert_cell(simplex, 0, true);
160 cell_point_map_.emplace(new_cell, point);
161 }
162 for (auto& os_pair : interior_simplex_map) {
163 const Simplex_handle& simplex = os_pair.first;
164 const Eigen::VectorXd& point = os_pair.second;
165 Hasse_cell* new_cell = insert_cell(simplex, 0, false);
166 cell_point_map_.emplace(new_cell, point);
167 }
168#ifdef DEBUG_TRACES
169 for (const auto& sc_pair : interior_simplex_cell_maps_[0])
170 cc_interior_summary_lists[0].push_back(CC_summary_info(sc_pair));
171 for (const auto& sc_pair : boundary_simplex_cell_maps_[0])
172 cc_boundary_summary_lists[0].push_back(CC_summary_info(sc_pair));
173#endif
174
175 for (std::size_t cell_d = 1;
176 cell_d < interior_simplex_cell_maps_.size() && !interior_simplex_cell_maps_[cell_d - 1].empty(); ++cell_d) {
177 expand_level(cell_d);
178
179#ifdef DEBUG_TRACES
180 for (const auto& sc_pair : interior_simplex_cell_maps_[cell_d])
181 cc_interior_summary_lists[cell_d].push_back(CC_summary_info(sc_pair));
182 if (cell_d < boundary_simplex_cell_maps_.size())
183 for (const auto& sc_pair : boundary_simplex_cell_maps_[cell_d])
184 cc_boundary_summary_lists[cell_d].push_back(CC_summary_info(sc_pair));
185#endif
186 }
187 }
188
189 public:
199 void construct_complex(const Out_simplex_map_& out_simplex_map) {
200 interior_simplex_cell_maps_.resize(intr_d_ + 1);
201 if (!out_simplex_map.empty()) cod_d_ = out_simplex_map.begin()->first.dimension();
202 construct_complex_(out_simplex_map);
203 }
204
216 void construct_complex(const Out_simplex_map_& out_simplex_map, std::size_t limit_dimension) {
217 interior_simplex_cell_maps_.resize(limit_dimension + 1);
218 if (!out_simplex_map.empty()) cod_d_ = out_simplex_map.begin()->first.dimension();
219 construct_complex_(out_simplex_map);
220 }
221
234 void construct_complex(const Out_simplex_map_& interior_simplex_map, const Out_simplex_map_& boundary_simplex_map) {
235 interior_simplex_cell_maps_.resize(intr_d_ + 1);
236 boundary_simplex_cell_maps_.resize(intr_d_);
237 if (!interior_simplex_map.empty()) cod_d_ = interior_simplex_map.begin()->first.dimension();
238 construct_complex_(interior_simplex_map, boundary_simplex_map);
239 }
240
255 void construct_complex(const Out_simplex_map_& interior_simplex_map, const Out_simplex_map_& boundary_simplex_map,
256 std::size_t limit_dimension) {
257 interior_simplex_cell_maps_.resize(limit_dimension + 1);
258 boundary_simplex_cell_maps_.resize(limit_dimension);
259 if (!interior_simplex_map.empty()) cod_d_ = interior_simplex_map.begin()->first.dimension();
260 construct_complex_(interior_simplex_map, boundary_simplex_map);
261 }
262
266 std::size_t intrinsic_dimension() const { return intr_d_; }
267
273 const Simplex_cell_maps& interior_simplex_cell_maps() const { return interior_simplex_cell_maps_; }
274
280 const Simplex_cell_maps& boundary_simplex_cell_maps() const { return boundary_simplex_cell_maps_; }
281
289 const Simplex_cell_map& interior_simplex_cell_map(std::size_t cell_d) const {
290 return interior_simplex_cell_maps_[cell_d];
291 }
292
300 const Simplex_cell_map& boundary_simplex_cell_map(std::size_t cell_d) const {
301 return boundary_simplex_cell_maps_[cell_d];
302 }
303
309 const Cell_simplex_map& cell_simplex_map() const { return cell_simplex_map_; }
310
315 const Cell_point_map& cell_point_map() const { return cell_point_map_; }
316
323
324 ~Cell_complex() {
325 for (Hasse_cell* hs_ptr : hasse_cells_) delete hs_ptr;
326 }
327
328 private:
329 std::size_t intr_d_, cod_d_;
330 Simplex_cell_maps interior_simplex_cell_maps_, boundary_simplex_cell_maps_;
331 Cell_simplex_map cell_simplex_map_;
332 Cell_point_map cell_point_map_;
333 std::vector<Hasse_cell*> hasse_cells_;
334};
335
336} // namespace coxeter_triangulation
337
338} // namespace Gudhi
339
340#endif
Data structure to store a cell in a Hasse diagram.
Definition: Hasse_diagram_cell.h:49
A class that constructs the cell complex from the output provided by the class Gudhi::coxeter_triangu...
Definition: Cell_complex.h:38
const Cell_point_map & cell_point_map() const
Returns a map from the vertex cells in the cell complex of type Gudhi::Hasse_cell to their Cartesian ...
Definition: Cell_complex.h:315
std::map< Hasse_cell *, Eigen::VectorXd > Cell_point_map
Type of a map from vertex cells in the cell complex to the permutahedral representations of their Car...
Definition: Cell_complex.h:68
void construct_complex(const Out_simplex_map_ &out_simplex_map, std::size_t limit_dimension)
Constructs the skeleton of the cell complex that approximates an -dimensional manifold without bounda...
Definition: Cell_complex.h:216
const Simplex_cell_maps & interior_simplex_cell_maps() const
Returns a vector of maps from the cells of various dimensions in the interior of the cell complex of ...
Definition: Cell_complex.h:273
std::map< Hasse_cell *, Simplex_handle > Cell_simplex_map
Type of a map from cells in the cell complex to the permutahedral representations of the correspondin...
Definition: Cell_complex.h:63
const Simplex_cell_map & interior_simplex_cell_map(std::size_t cell_d) const
Returns a map from the cells of a given dimension in the interior of the cell complex of type Gudhi::...
Definition: Cell_complex.h:289
Cell_complex(std::size_t intrinsic_dimension)
Constructor for the class Cell_complex.
Definition: Cell_complex.h:322
void construct_complex(const Out_simplex_map_ &interior_simplex_map, const Out_simplex_map_ &boundary_simplex_map)
Constructs the the cell complex that approximates an -dimensional manifold with boundary embedded in ...
Definition: Cell_complex.h:234
const Simplex_cell_maps & boundary_simplex_cell_maps() const
Returns a vector of maps from the cells of various dimensions on the boundary of the cell complex of ...
Definition: Cell_complex.h:280
Gudhi::Hasse_diagram::Hasse_diagram_cell< int, double, bool > Hasse_cell
Type of a cell in the cell complex. Always is Gudhi::Hasse_cell from the Hasse diagram module....
Definition: Cell_complex.h:49
void construct_complex(const Out_simplex_map_ &out_simplex_map)
Constructs the the cell complex that approximates an -dimensional manifold without boundary embedded ...
Definition: Cell_complex.h:199
const Cell_simplex_map & cell_simplex_map() const
Returns a map from the cells in the cell complex of type Gudhi::Hasse_cell to the permutahedral repre...
Definition: Cell_complex.h:309
std::vector< Simplex_cell_map > Simplex_cell_maps
Type of a vector of maps from permutahedral representations of simplices in the ambient triangulation...
Definition: Cell_complex.h:58
typename Out_simplex_map_::key_type Simplex_handle
Type of a simplex in the ambient triangulation. Is a model of the concept SimplexInCoxeterTriangulati...
Definition: Cell_complex.h:43
void construct_complex(const Out_simplex_map_ &interior_simplex_map, const Out_simplex_map_ &boundary_simplex_map, std::size_t limit_dimension)
Constructs the skeleton of the cell complex that approximates an -dimensional manifold with boundary ...
Definition: Cell_complex.h:255
std::map< Simplex_handle, Hasse_cell *, Simplex_comparator< Simplex_handle > > Simplex_cell_map
Type of a map from permutahedral representations of simplices in the ambient triangulation to the cor...
Definition: Cell_complex.h:54
const Simplex_cell_map & boundary_simplex_cell_map(std::size_t cell_d) const
Returns a map from the cells of a given dimension on the boundary of the cell complex of type Gudhi::...
Definition: Cell_complex.h:300
Returns the dimension of the cell complex.
Definition: Cell_complex.h:266
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:27 for GUDHI by Doxygen 1.9.2
